60,000 maintenance, done
Old Dec 30, 2004 | 10:33 PM
boogyman's Avatar
Talking 60,000 maintenance, done
well, my 2000 taco hit 60k the other day, so i figured it was time to do the 60k maintenance..
changed spark plugs
changed oil & filter
replaced air filter
replaced pcv valve
replaced fuel filter
flushed coolant & core
replaced oil in rear diff, front diff, transfer case, & transmission
...besides the timing belt (which I'll take to a shop for) think I missed anything?
-Russell
Old Dec 30, 2004 | 10:56 PM
superjoe83's Avatar
grease u-joints
kevin444's Avatar
lube the driveshaft, check tire pressure, clean out throttle body.
Old Dec 30, 2004 | 11:32 PM
boogyman's Avatar
Talking
ahh, i did adjust the tire pressure and cleaned out the throttle body as well (did that when the intake was off for the spark plugs..)
boogyman's Avatar
Talking
thanks for the reminder! I actually got under the truck with my grease gun and I was out of grease.. so I need to go get some more..
anything else?
Old Dec 31, 2004 | 01:52 AM
pat2724's Avatar
I am going to flush my Tacoma 2.4 radiator out and I bout the kit from prestone.Where did you put the T? Can I run the red antifreeze in it? i heard it was better.. I bought the 50/50 prestone.
Thanks
Old Dec 31, 2004 | 09:03 AM
boogyman's Avatar
Talking
I didn't buy a kit or anything to flush the radiator. I just bought the toyota red coolant and followed the directions on the bottle to flush everything out. ..basically you can just stick a garden hose in there and run it until water comes out clear. (you may have to hook into the heater tube as well to flush out the core). Then drain everything out. add the coolant, and top off with water.
-Russelll
Old Dec 31, 2004 | 01:04 PM
pat2724's Avatar
How much red coolent did you buy? You stick the garden hose in the radiator?
How much for the red stuff?
Old Dec 31, 2004 | 04:08 PM
boogyman's Avatar
Talking
I just bought one coolant container from the local dealer.. (maybe 1.5 gallons?) ..and yes, i just use the garden hose.. i'll probably get lectured for it, but it works fine, and i've never had a problem in the 3 cars i've done it with. finally, the red stuff cost me like $12 i think at the dealer..
Old Jan 1, 2005 | 11:51 PM
schlopecki's Avatar
Timing belt at 60K ?
Old Jan 2, 2005 | 12:15 AM
kyle_22r's Avatar
i'm in the middle of my 320,000 maintenance...
new radiator
new engine(stepping up to a 22R, finished the longblock tonight)
new(old) transmission, getting rid of the L43 4 speed for an L52 5 speed
new clutch and clutch hydraulics
Old Jan 2, 2005 | 12:16 AM
r0cky's Avatar
i need a new radiator as well ... are they very expensive??
Old Jan 2, 2005 | 09:17 AM
boogyman's Avatar
Talking
i thought that was part of the 60k maintenance list at the dealer.. am i wrong?
Old Jan 2, 2005 | 09:21 AM
Bob_98SR5's Avatar
boogy,
look in the maintenance section and look at the stickied link up at the top. theres a maintenance search engine that willtell you exactly wht needs to be done
bob
Old Jan 2, 2005 | 09:26 AM
boogyman's Avatar
Talking
Originally Posted by Bob_98SR5
boogy,
bob
cool, thanks
-Russell
Old Jan 2, 2005 | 11:06 AM
X2and4X's Avatar
toyota red from my dealer was 8 bucks.. thats what is in the MR2 and will be in the 4runner also.
Old Jan 2, 2005 | 12:32 PM
bulldog-yota's Avatar
what do you guys do with the old coolant and fluid that comes out with the flush?
If you plan to do the timing belt, you might as well look at the serpentine bely and the hoses as well. might as well replace them if they are coming off.
Old Jan 3, 2005 | 07:07 AM
schlopecki's Avatar
Here is what Toyota.com says for 60K / 48 months:
http://smg.toyotapartsandservice.com...vice_01_47.pdf
But I found the timing belt replacement at 90K / 72 months:
http://smg.toyotapartsandservice.com...vice_01_51.pdf
Note:
Clicked through "Service + Maintenance" @ http://www.toyota.com/html/owners/
Old Jan 3, 2005 | 09:05 AM
boogyman's Avatar
Talking
yeah, i saw the timing belt at 90k when i looked on that site. thanks for the heads up
-Russell
Old Jan 7, 2005 | 09:34 AM
CynicX's Avatar
dump it in the sewer, woods, flush down the toilet...etc
hehe i know a guy at a dealership, he dumped it for me...
