Mixing Trans fluid
Old Oct 26, 2004 | 07:00 AM
h7009's Avatar
Mixing Trans fluid
Hey to all, asked a question reference Transmission fluid changing and learned a lot. the question I now have is, If I don't want or trust the "jiffy lubes" and I don't want to go to the "stealorship" can I do a drain and fill and mix synthetic into the existing ATF? will they mix? and if so will there be an improvement in trans life? thanks in advance. EDH
Old Oct 27, 2004 | 03:27 PM
Tacoma Dude's Avatar
I did some research on this later and a couple people had said that they are compatible and you shouldn't run into any problems...
Old Oct 28, 2004 | 03:39 AM
h7009's Avatar
Tacoma Dude, thanks, I'm sure I could do the complete flush in the garage, but with only 51K on my 2000 it seems the more effiecent way would to be drain (just the pan) and refil with synthetic. Also if I do it every 25K or so eventually I'll be running full synthetic. thanks again. EDH
Old Oct 28, 2004 | 10:20 AM
tomstin's Avatar
Follow these steps and go most of it out. http://www.amsoil.com/faqs/faq8.htm
VT2LAB
Sep 10, 2015 09:36 AM
old87yota
Sep 9, 2015 12:39 PM
an1mal_69
Sep 8, 2015 09:40 AM
eggens
Sep 5, 2015 12:16 AM
Scatterbrain
Sep 3, 2015 06:46 PM
