- Need advice on timing belt replacement...
- fuel injectors
- 3VZE running slughish
- problems starting/ starter motor q's
- Vehicle Vibration (Yes it's still there)....Need copy of Service Bulletin....
- Check Engine Light??
- REALLY annoying problem
- Tight turns, and a horrible, horrible sound.
- transfer case problem?
- CV boot clamps....
- Vacuum line??
- Auto tranny acts funny ...PLEASE HELP!
- fuel pump not getting power 87
- Does anyone know where this ground attaches
- Gasket - Part # ?
- My tach is a liar!
- I need help with Clutch Replacement
- changing gear oil for the first time
- Turn Signal and Breaking
- Interior cleaning and?
- a/c recarge problem
- Anyone have problems w/Ceramic Brakes
- Anyone using 85 Octane? I don't think I hear knocking, am i missing something?
- Replace drivers side injector w/out pulling plenum?
- Deckplate =Check engine light?
- Header and High flow exhaust
- Need Help!!!! White smoke and very rough idling
- o2 sensor
- Air Flow Meter and Code 31
- Yet anothe HG ?
- project help please?!
- Whistle noise from engine
- Does this O2 sensor look shot?
- Air Intake question w/ PIC
- idle sucks
- what can this mean???
- brake problem, again!
- possible starter problem??help
- Power mirror problem
- Need info from FSM or Toyota Camry expert
- Rebuilt my Idler Arm today
- location of a few parts
- 2q's idle smoke and high milage additive
- what is your idle at?
- help truck wont start
- Removing axle hub bolts/studs
- Rod and Main bolt torque needed!!
- Headgasket update.
- Knock issue
- Success! No more diesel sounding engine
- Tapping at Idle
- Can someone explain this CEL code for me.
- 22re egr gasket material
- 92 Runner speed sensor wire diagram
- Intake Manifold
- Ignition System Maintenance
- How To Check Dash Warning Lights??
- brake job rotor turning question
- Windshield Wiper problem.
- HELP! Upper Control Arm Disassembly
- water Pump write up?
- '92 Pickup Front End Rebuild
- 1990 V6, No rev beyond 3k, no fuel. At my wits end.
- can you identify this component? think i need a new one.
- Any suggestions for a catalytic converter in Canada?
- leaking frnt dif/loose axle...
- P0171 won't go away... HELP!!!
- Noisy tailgate
- Part name
- 92 Toyota Long Bed / Brake Issue.
- stalling out and unable to restart the engine
- Oxygen Sensor Question
- losing coolant, no visable leaks
- Oily Engine
- engine belt/timing belt replacement question
- throttle thingy removal
- tailgate seal is loose - ideas? (pic)
- help code 51 and truck wont go
- Stripped wheel studs
- Black Spots on Window
- 22re timing chain replacement
- Anyone replace their inner tie-rods?
- 3rd Gen Hub Nut Removal HELP
- hard pedal
- 4cyl and V6 IFS parts compatability
- Broken key in ignition
- Line info needed
- Broke a bolt off the cold starter injector mount
- Anyone know about power windows?
- 4runner overdrive
- antenea removal
- Noisy engine, I thinnk it is the crankshaft
- Power door locks dead
- Throttle body help on a 22re...what hose goes here????
- flywheel torque, and clutch face direction on 3.slow
- Auto Tranny Problems - Newby
- source for fuel and brake line?
- another 3.0 problem
- Opinions on Flywheel
- Low fuel light comes on and flickers randomly!!!
- Rough idle, missing... what could it be?
- Leaking fron differential?
- 300km drive, any suggestions for quick tune up?
- check engine light!!!
- Dear God Please Help Me!!!!
- driveline vibrations questions
- Re-Feeding Good Antenna Mast
- Fly wheels
- water leaking in a 3.0
- Tundra Brakes - 17" wheels vs 16" wheels
- Warped Rotor Obvious to the Naked Eye?
- Q's concerning my Yota's problems...
- knock in my 3vzfe...oh what could it be?
- 3.0 temp sending gauge unit
- New Motor Won't Run / ECU Codes
- Knock Sensor CEL 86 SR5 22RE
- Engine Paint
- Check Engine Light Again :(
- hot weather car care?
- Idling too high
- tacoma MT second gear
- Do you think i went overboard
- my first leak :( t-case is dripping
- she's dead again, folks...
- CA smog on a 1st gen
- how soon after fresh paint can I zaino ???
- CLAYBAR...use it..NOW
- Shifter Boot Replacement: 87 Runner
- 3.4 Tacoma Stalling while in neutral....help!
- 2005 4wd 4 runner engin light
- What kind of grease?
- help with clutch replacement
- Power Steering leak?
- One Wiper works...
- Timing Belt Replacement
- Brake Rotors
- Urgent help RE: wheel bearing/hub
- Answer needed ASAP
- 94 140,000 miles valve adjustment ?
- Fuel Injector Service vs. BG44K
- TE1? Not that I can see...
- Radiator Neck Crack
- '90 4Runner Fuel Line Removal & Replacement
- Ever seen a bad wheel bearing?
- total power steering fluid quantity 2nd gen
- Speedo Whine and whoopie cushions
- alternator going out?
- Does anybody know what those connections are?
- Re-torque what...-- service Question (yes i searched)
- 22RE motor mounts
- Radiator replacement... HOW TO (pics)
- Help, my 4Runner's bleeding
- Brake overhaul
- 1995 3.0 check engine light
- Oil filters
- Dealer told me I need a power steering flush?
- mirror removal
- *'92 4RUNNER AUTO Trans. O.D. Problem"
- 94 Toyota Idle Problem
- Sporadic crunching noises during startup.. not starter though...
- Wobbly ride over 90km/hr (55mph).... very tight lug nuts...
- Rocker Arm question
- 2nd gen 4Runner drivers mirror help please
- parking brake flashing
- Tune Up cost?
- Really Weird, PLZ help me
- 2nd Gen Water leak
- Grrr.. 89 Yota Frustration.
- Non Toyota OBDII code help.
- A/C cut off relay location / 4 runner
- positive or negative cable?
- Painting over two-tone. Do I color sand now?
- 90k-100k maintence
- 2wd 4runner driveshaft bolt torque specs?
- 01, 2.7 screw in PCV valve
- Serious steering shaft binding problem
- 3.0 Not Idling worth a damn since I installed headers/exhaust.
- What would cause the rear passenger wheel to seize up
- belt tensioner info.
- Have Tacomas changed much?
- Where can I get a good radiator in Canada? suggestions please...
- $500 fair to charge for a clutch replacement
- Key stuck will not go past acc problem solved.
- Radiator repair...help please...
- Replaced Fuel pump...takes longer to start now
- Intermittant on/off CEL?
- Will '88 V6 work in a '90 SR5?
- serp belt replacement
- '99 4Runner Rattles
- w56 Transmission Removal
- 05 4runner with creaking sound in rear passenger area?
- Running hot with heater on
- tune up questions
- Power steering fluid
- Cv Axle replacement
- Replaced front O2: +4 mpg
- 3vze wont run
- Clear Coat Gone from original wheels
- Prepartation before going Synthetic?
- Motive Power bleeder, how much pressure needed?
- 1997 Rear Bumper replacement
- Try Bleeding brakes on 4th gen but messed up
- Starter Rebuild Kits!
- TRD Air Filter Sale!
- Rear Wheel bearing ?? Help
- Brake & fuel replacement lines - 89 Truck
- Electrical short??
- Different Grades of Oil
- Cancerous Bed
- interesting article about engine oil
- Oil for Manual tranny
- MAF Cleaner Question
- 95 4 runner transfer case fluid question
- Major Maintenance report!
- Replace CV's?
- Fluctuating RPMs at idle.
- Shouldn't we replace these
- A Couple Different Sounds
- Leather advice...is there anything I can get from a local parts store?
- master cylinder ran dry
- i need a full lubing
- 88' 3.0 V6 4-runner problem starting cold
- Single lube for 99 4Runner Chassis?
- Black stuff in Intake Chamber??
- Part needed
- Brake parts cleaner on intake sensors
- problems with power steering
- 02 Sienna whining/chirping noise under hood
- Comments on Fram Oil Filters
- best plugs and wires
- Help with a tune up
- Mobil 1 vs. MOBIL 1 EP fuel economy
- best tire shine
- Rear window problem
- sudden power loss
- Pure Power Lubricants
- Where do you guys recommend for a tranny flush?
- Penzoil Platinum Synth motor oil?
- Markers not flashing... Help please...
- couple questions about my 93 22re
- How to change spark plugs
- Taco feels like it downshifts after its stopped
- Problem with the family truckster!!!
- steering rack
- Spark plugs
- Factory Recommended Maintenance, 3rd gen pickup
- What battery for a 3rd Gen Runner?
- cleaning small toyota lettering?
- coolant flush detergent
- 87 4runner paint code
