Really Weird, PLZ help me
Old Apr 1, 2005 | 11:48 AM
93cagedyota's Avatar
My 3vze is running on cylindders 1,3,5. 2,4,6 are dead. What would cause this to happen.
Old Apr 1, 2005 | 01:06 PM
Robinhood150's Avatar
We're going to need more info than this. How did you diagnose the cylinders? Any work done recently? etc.
Old Apr 1, 2005 | 01:07 PM
cylinders 2,4 and 6 have spark. Can it be a fuel problem?
Old Apr 1, 2005 | 01:11 PM
i put a new timing belt, distributor, and the truck ran good. I drove the truck around my block and parked it because it is running straight headers and i need to save money to get the exhaust done. I went to fire it yesteray and only one side of the motor is running. I checked spark on cylinder 2,4,6 and they were good. What is my next step?
Old Apr 1, 2005 | 05:15 PM
eric-the-red's Avatar
Looking at the wiring diagrams the injectors for 2, 4 & 6 have a common feed, most likely your problem is they aren't getting power. It shows a white wire coming from the computer for those 3 injectors, either 2nd or 3rd pin from one end. According to the manual there should be 9 -14 volts at that pin with the ignition on. If you've got that voltage at the pin there's probably a broken wire somewhere. If not that's may mean a dead computer.
Old Apr 1, 2005 | 06:25 PM
It is kind of funny but i changed the spark plugs and the truck runs great. I dont know if in the process i moved a wire to where it's suposed to be, but it works. Thanks for the help guys
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
PBRaddict#1
Sep 22, 2015 07:50 AM
JamesDINAN
Sep 22, 2015 05:37 AM
Bill854x4
Sep 20, 2015 04:32 PM
