Headgasket update.
Old Apr 12, 2005 | 02:51 PM
Mikronized's Avatar
Headgasket update.
well... they have the block apart... it was the head gasket... so they're fixing that.
also they are doing a valve job, they said that some of the valves weren't closing all the way and were starting to burn and warp... so that's gonna add and extra $400 to the job....
so I'm going to be without the 4runner for like 2 weeks total, and out a butt load of money...... :cry:
Old Apr 12, 2005 | 02:53 PM
jimbo74's Avatar
an extra $400 for a valave job? you are getting shafted?! i had my 22r head machined down, cleaned, pressure tested, all the valve seals replaced and a valve job done for $180
Old Apr 12, 2005 | 02:55 PM
Bassinfool's Avatar
Yeah, $400 for a valve job? I think you're getting forked. Sorry to hear about the HG, too. At least it's not something worse, I guess.
Old Apr 12, 2005 | 02:56 PM
Mikronized's Avatar
really?! dang, I'll call them today.
Old Apr 12, 2005 | 03:00 PM
Yamaha+Toyota=Fun's Avatar
22r/re is alot different that a 3vze head. More valves to replace in the v6, more of a PITA to work on, harder to adjust vavles, etc. A friend of mine just had his heads rebuild and it costed him about $400 for a reputable machine shop.
I know how much it sucks to have your truck crap out on ya, today I think i found out my truck has a burnt valve. How much is the whole thing gonna cost you?
Old Apr 12, 2005 | 03:08 PM
Mikronized's Avatar
I don't even really know what the cost is at this point... it was $1100 for the headgasket, and that $1100 was assuming I didn't need to replace any other engine components... and now $350-400 for the valve job... so $1450 if i'm hella lucky... but it will most likely be like 1600 or so...
Old Apr 12, 2005 | 03:11 PM
jimbo74's Avatar
1100 for the head gasket and they werent going to do any of the head work?! dang... i sepnt $400 on my 22r, and i got a whole factory toyota gasket kit, had the machine work done and did the work myself... i know its a v6... but it still seems like he is getting shafted...... thats 4 times the cost and mine was only half the amount of work....
Old Apr 12, 2005 | 03:25 PM
Robinhood150's Avatar
If you haven't already, you might want them to replace the waterpump, timing belt and idler pully thingy.
Since you're throwing around money as it is...
Welcome to the wonderful world of the 3.0.
Old Apr 12, 2005 | 03:30 PM
Mikronized's Avatar
I already replaced those 3 items like 2 months ago....
next time this thing craps out I'm swapping the engine.
Old Apr 12, 2005 | 04:14 PM
KING's Avatar
Folks, you are all comparing two different machines.
A 22R/22RE is nothing like a 3VZ-E.
Four hundred bones for a valve job does sound reasonable to me.
I have been quoted seven hundred bones for valve adjustment.
It is a time consuming and delicate job.
Old Apr 12, 2005 | 04:58 PM
kyle_22r's Avatar
doesn't the 3VZE use lifters and shims to adjust the valves? ugh...
Old Apr 12, 2005 | 08:17 PM
Finally someone realizes.....
Old Apr 12, 2005 | 08:25 PM
Cebby's Avatar
This is the path I could have gone down. All that money......and it's still the 3.slow.
Old Apr 13, 2005 | 09:16 AM
Mikronized's Avatar
I'd love to swap it out, but I can't have my truck out of commission that long.
Old Apr 13, 2005 | 09:28 AM
Amir904's Avatar
why cant you buy a new head with all new valves etc from engnbldr.com????? wouldnt it cost about the same?
Old Apr 13, 2005 | 04:23 PM
Bumpin' Yota's Avatar
After successfully adjusting my valve trains, I can say that I FULLY understand why they would charge 400 to do it.... My engine is sooooooo much quieter now too! Now the loudest thing under the hood besides the fan are the 6 injectors all making that wonderful sound of 'TICKTICKTICK....' at idle. Lost a little power, but I expected that as now the duration of lift is a little shorter on 9 of the 12 injectors, but now they are in spec. Before, those 9 were not... (Maybe I didn't loose power as I did get used to driving a 318ci v8 Ramcharger...LOL)
TheBFA
Feb 15, 2020 06:55 AM
alimant100
Jan 20, 2016 05:58 PM
_Nicco_
Sep 21, 2015 03:06 PM
defrag4
Jul 31, 2015 10:50 AM
toofly1999
Jul 25, 2015 07:09 PM
