Air Flow Meter and Code 31
Old Apr 14, 2005 | 10:44 PM
JoKEpLaYeR's Avatar
My truck backfired the other day and started running funny - wouldn't rev past 4k and hardly idled. I jumper'd the computer and code 31 came up. Checked the FSM and it said Air Flow Meter and some ways to test it. I tested it and had infinite resistance on all but one test. I cut the silicone and opened the cover to find the black plastic arm snapped in half, 3 soldered connections broken loose, and the copper contact arm bent upward just slightly enough to not make contact.
Well, some solder on those contacts, bending the arm back down just slightly, and some super glue on the plastic did the trick. No more check engine light and the motor runs fine.
Just an FYI if you are having the same problems. I'll post a picture this weekend.
Old Apr 15, 2005 | 03:55 AM
waskillywabbit's Avatar
My AFM was acting up, needed replacing, got an aftermarket one w/ a LIFETIME warranty for a 1/3 of what the dealer wanted, truck runs like new again...
Old Apr 15, 2005 | 08:56 AM
JoKEpLaYeR's Avatar
Cool, I'll keep that in mind if mine acts up again. So far so good though.
Old Apr 15, 2005 | 10:45 AM
mt_goat's Avatar
Where did you get it at?
smthwsn357
May 1, 2024 07:28 AM
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
smiley52
Jul 11, 2015 05:16 AM
