Starter Rebuild Kits!
Old Mar 28, 2005 | 02:34 PM
Strap22's Avatar
Sponsoring Vendor
We place a lot of demands on our starters, and occasionally they do wear out. Rebuilding your starter not only makes economic sense, but gives you a sense of satisfaction by 'doing it yourself'. Starter rebuilds are a relatively simple job requiring only the most basic of hand tools.
Here is a breakdown of the components. Each engine has one of two different starters, they are usually marked with either the part number or the kw.
Fits:
2.7L (1.4kw) starter P/N: 28100-0C010-84 (non-cold spec)
2.7L (1.8kw) starter P/N: 28100-75140-84 (cold spec)
1. (Required) Contact P/N: 28226-74070 ($8.22)
2. (Required) Contact P/N (non-cold spec): 28226-54340 ($4.37) or Contact P/N (cold spec): 28226-22050 ($5.81)
3. (Recommended) Plunger P/N: 28235-54380 ($16.65)
4. (Optional, if needed) Clutch P/N: 28011-26042 ($58.14)
Fits:
3.4L (1.4kw) starter P/N: 28100-07010-84 (non-cold spec) *Regular cab & Extra Cab may be cold spec or non-cold spec
3.4L (1.8kw) starter P/N: 28100-62030-84 (cold spec) *All Double Cabs should have cold spec
2. (Required) Contact P/N (non-cold spec): 28226-16130 ($8.22) or Contact P/N (cold spec): 28226-54340 ($4.37)
3. (Recommended) Plunger P/N: 28235-55050 (non-cold spec) 28235-54380 (cold spec) both $16.65
Part numbers and or Prices are subject to change with out notice, please contact info@trdparts4u.com to verify. Prices do not include shipping. Citizens of the Republic of Texas must add sales tax.
bigjstang
Jun 2, 2025 03:56 PM
dumpster84
Apr 30, 2016 06:03 AM
jerusry
Oct 19, 2015 05:28 PM
shisha1999
Sep 21, 2015 08:22 PM
clok
Aug 1, 2015 09:42 PM
