stalling out and unable to restart the engine
Old Apr 10, 2005 | 08:33 PM
calrockx's Avatar
i went wheelin today at rowher flats and came to a really steep downhill, off-camber section when i was crawling down and my steering ended up fully turned driver side and the engine stalled out. i tried restarting, but it just wasn't happening. the truck was pointed downhill and a pretty steep angle and i was a bit off camber to the passenger side. i had my friend turn the key so i could wrestle the steering to the right and i crawled down a bit more and got to more level ground. then, finally, i was able to restart the engine.
so my question is, why did i stall out and why couldn't i restart? prior to this, and after this incident i can start the engine just fine. maybe this is something simple, yet just some knowledge i haven't picked up yet along my wheeling way, but i am curious why this happened and maybe a way to prevent this from happening again given a similar situation...
Old Apr 10, 2005 | 08:36 PM
KevyWevy's Avatar
weird. only thing that comes to mind for me is if you were low on gass, it could have all sloshed away from the intake, but i doubt that.
Old Apr 11, 2005 | 08:16 AM
Robinhood150's Avatar
sounds like out of gas.
Old Apr 11, 2005 | 08:46 AM
terryjmatthew's Avatar
When you turn the steering to the stops, doesn't it drop the idle speed?
Still doesn't explain not being able to restart?
Old Apr 11, 2005 | 09:05 AM
calrockx's Avatar
about the out of gas idea...i had just under a 1/4 tank, so i didn't think of that. it's low, but i didn't think it's that low enough to cause such a problem
Old Apr 11, 2005 | 09:34 AM
Albuquerque Jim's Avatar
I'm going with the low gas too. If you were at an extreme angle then the (1/4 tank) approx. 4 gallons left in the tank could have been all to the front so the pick up couldn't reach it.
Its a safe rule to alway fill up prior to wheelin'. Who knows when you have to spend the night on the trail or share fuel with somone else who has run out.
Old Apr 11, 2005 | 06:02 PM
KevyWevy's Avatar
yeah, if you only had a 1/4 tank that could definetly do it.
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Jnkml
Jul 6, 2015 01:20 PM
