alternator going out?
Old Apr 3, 2005 | 08:37 PM
93bluetoyota's Avatar
I have noticed lately everytime I start my truck it seems like it has a dead battery. The battery was replaced just over 2 months ago and all the fittings are tight. Could my alternator be going out? Thanks
Old Apr 3, 2005 | 08:44 PM
ChickenLover's Avatar
Are they clean? I believe you can take your truck to a place like Kragen and they'll test your alt for free.
Old Apr 4, 2005 | 12:39 PM
YotaJunky's Avatar
You also might have a slow power drain somewhere. Do a search on the forum. I recall someone else having the same symptoms and it turned out that he had lights that stayed on even after the key from the ignition was removed.
Old Apr 4, 2005 | 02:03 PM
ewarnerusa's Avatar
Once you're jumped and running again, are your headlights dim? Do some electrical items like your radio not work? Is your ABS light on? After running for a while and then being shut off, does the truck not start back up easily? These can be signs of the alternator crapping out. Like someone else mentioned, take it into Napa or other car parts store. they can test, although sometimes the alternator needs to be out of the vehicle. And they will try to sell you a new alternator AND new battery.
Old Apr 4, 2005 | 02:05 PM
Yeah my lights get dim when it isn't under a power load. I has trouble starting pretty much everytime I need to start it.
Old Apr 4, 2005 | 02:18 PM
ewarnerusa's Avatar
If the battery is relatively new like you said, and everything's tight and clean......then it does sound like an alternator to me. but I'm no auto-guru! If it is still the original alternator then maybe it's time for a new one.... If you're inclined to do the wrenching yourself, it is typically not a difficult DIY job. I've never done a toyota, but I think it is typically just acouple bolts, wiring harness, and loosening belt tension. then there's my fiancee's Honda civic that only small santa elves could fit their hands in there to work. I have no idea how engines like that are worked on.
Old Apr 5, 2005 | 10:05 PM
frankenrunner's Avatar
Guest
autozone or some other corporate parts supplier can easily test the alt. in the car.
other than that, i suggest checking the alt. to battery power lead for corrosion, which can build up on the cable inside of the casing.
a tell tale sign would be a build up on the positive battery terminal.
i'd also check the alt.'s ground cable for good contact w/it's grounding connections as there may be accumulated build up that would interfer with it's connections.
good luck,
-f-
shooter86314
Jan 7, 2016 07:05 AM
Chicken12
Oct 14, 2015 03:54 PM
fountain
Sep 28, 2015 03:04 AM
SCZIG
Sep 20, 2015 09:00 AM
scheuvront1993
Sep 17, 2015 06:17 PM
