another 3.0 problem
Old Apr 8, 2005 | 01:28 PM
93cagedyota's Avatar
another 3.0 problem
My truck will run fine unti it warms up. After it is warm it wont idle. It will rev up fine but when u let off the gas it wont idle. Anyone know what i should do. When it is doing this it sound like it is sucking way to much air or something. Thank you
Old Apr 8, 2005 | 02:25 PM
ChickenLover's Avatar
You should clean your throttle body. If you think it sounds like it's sucking too much air, you might have an afm problem ( but I seriously doubt it). Poor idle can be attributed to every component associated with ignition, fuel delivery, and air intake. It's time for you to start narrowing it down.
Old Apr 8, 2005 | 02:31 PM
ace's Avatar
ace
check for a vacumn leak at one of the many vacumn lines
tobylab
Jan 18, 2016 07:06 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
tobylab
Jul 12, 2015 12:53 PM
Coreyr384
Jul 10, 2015 11:13 AM
