Auto Tranny Problems - Newby
Old Apr 8, 2005 | 05:39 PM
Metricsocket's Avatar
Hi everyone!!
OK, so I have read many of the threads on tranny problems, but still can't seem to find an answer. I have a 1986 SR5 Pickup 4X4 with a 2.4 L Turbo and an Automatic transmission with the Normal/Power option. My problem is as follows - at random intervals when I stop at a red light my tranny stays in what seems to be high gear. I have to manually drop it into low gear so I can move. As well, it does the same thing when I put it into drive first thing, sometimes. I also drive with the overdrive off. I took it to the local tranny garage and they said they couldn't find anything wrong and to bring it in when it acts up again.
I am getting a second opinion on their assessment.
Should I get a tranny flush?
Should I drive with the overdrive on or off - I do mostly city driving?
Any help or suggestions would be greatly appreciated! Thanks everyone!
Old Apr 10, 2005 | 07:49 AM
Originally Posted by Metricsocket
Hi everyone!!
OK, no one is interested...
I went and got a full tranny flush with the detergent. they said my pump pressure was low, but by the end of the flush it increased a little. Is there any way to have them increase the pump pressure?
Have a good one!!!
Old Apr 11, 2005 | 06:57 AM
89_4runner's Avatar
I wouldn't take your truck back to the same tranny garage. I think they were more interested in taking your money than solving the problem.
This sounds like a common problem with Aisin A340 series autos. The problem is likely one of your shift solenoids is clogged. There are several threads I have replied to covering this same issue. Try searching again with "shift solenoid". If no luck I will look up the threads again.
The shift solenoids are about $50 US. and are not difficult to change. Worst case you can buy them and take them to a mechanic to change for you.
Old Apr 11, 2005 | 06:11 PM
Thanks for your help, I appreciate it. I have had this problem for a few months now, and you are the only one who has any idea as to what the problem could be.
Again, thanks!
Old Apr 11, 2005 | 09:22 PM
89_4runner's Avatar
You're welcome. Post a reply to say how it turns out.
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
