flywheel torque, and clutch face direction on 3.slow
Old Apr 8, 2005 | 06:14 PM
Eric's Avatar
I cannot find the torque specs in the haynes manual on flywheel torque.
also usually the clutch dist will say which direction it should be facing, mine does not... one side is flatt all the way across, and the other side has a raised center just inside the clutch disc. should the raised center face the flywheel or the pressure plate...
here is a bad attemt at a quick diagram
a. flywheel
__----__
pressure plate
b. flywheel
--____--
pressure plate
so option a or b?
Old Apr 8, 2005 | 06:42 PM
fadetoblack72's Avatar
If you are talking about the hooking the flywheel to the crankshaft I know a 22re is 80 FT/LBS. Not sure about a 3.0 but I would imagine it to be the same. Not sure about the other question. Sorry. http://personal.utulsa.edu/%7Enathan...fsm/index.html Try that fsm.
Old Apr 8, 2005 | 07:18 PM
dstrick32's Avatar
On the clutch disc the flat side toward the flywheel and the torque for flywheel bolts are 65 ft lbs, pressure plate bolts are 14 ft lbs!!!
Eric's Avatar
that manual is great!
torque is 65fl/lbs
clutch disc is installed as option "b"
thanks for your help!
jasonty
41
Dec 23, 2018 01:00 PM
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
Sep 4, 2015 09:27 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
