Starter acting super odd!! help please!
Old Oct 13, 2004 | 07:08 PM
BADNEWSBACK's Avatar
Talking Starter acting super odd!! help please!
I have a 1990 4runner and it has a odd symptom. every know and again when you start it nothing happens and then you have to get out of the car tap the starter with somthing ( not even hard ) and it kicks right over. I bought the thing and the starter seemed new. I got home it wouldnt start so i asked the guy to replace it. he was there that day and i watched him put the new one in and it made no difference! any ideas what it may be????? I was wondering if it needs to be shimmed. i have looked all over and i cant find anything about it.
thanks!
Old Oct 14, 2004 | 06:26 AM
kevin444's Avatar
Was it a genuine toyota one? Or one of those pep boys oem ones?
Old Oct 14, 2004 | 05:56 PM
its from advance i believe... i know they arent that good of quality.
Old Oct 15, 2004 | 07:43 PM
mtnfreak's Avatar
Use Roger Brown's trick of running battery power directly to the starter - it worked for me. You can find it at the end of his 'starter' page. You can get all of the materials at Radio Shack for less than $20. Toyota starter relays are 10x that.
Old Nov 2, 2004 | 12:23 PM
GV27's Avatar
Better late than never......
A starter that is revived by tapping on it is a starter that is on its way to the great beyond! Very common.......
Old Nov 19, 2004 | 11:28 AM
rngrchad's Avatar
Very very true. You either have it shimmed wrong, or the solenoid is acting up. Typically pounding on a starter that has a bad solenoid will get it to crank over. I did this for almost 3 months before mine ended up being completely useless....maybe clean the starter contacts, check for loose connections. Oh yeh, and most of the time it is cheaper to just buy a whole starter than replace the solenoid...at least on older GM models.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
aowRS
Sep 13, 2017 08:22 AM
justdifferentials
14
Jun 11, 2017 08:36 PM
pickle6415
Oct 19, 2015 08:08 AM
93RedKrawler
Sep 25, 2015 04:03 AM
