How to change power steering fluid?
Old Dec 4, 2004 | 08:03 PM
arielb1's Avatar
Thanks for you time and your help. I have looked at archieves but cannot find. I got so much help from my last thread, I thought I would try to push my luck, being in Las Vegas and all.
I have a 1994 4runner. The steering fluid has never been changed. It currently has 110k miles. How do you change the power steering fluid? I have changed all the other fluids. This one I need help on.
I have changed fluids in my Accord, but I look at the 4runner and haven't got a clue.
Thank you for teaching me...Ariel
Old Dec 4, 2004 | 08:13 PM
nunsa's Avatar
Truth being, I never changed my p/s fluid and I have 305,000 miles on my beast, if you want to change it, you need a turkey baster it works great, suck all the old fluid out of there and replace it, start your rig w/the cap off and turn your wheels r to l and she is purged, check fluid replace cap! Good as new!
G/L
Old Dec 4, 2004 | 09:13 PM
arielb1's Avatar
Thank you...will try this weekend. Anyone else have another idea? Thanks again.
Old Dec 5, 2004 | 01:19 PM
1. Jack up the front of the truck.
2. Take a turkey baster or other smallish tube to suck up as much of the old fluid as possible.
3. Remove the return line from the reservoir (it has the simple screw-down pipe clamp) and place this line in a jar.
4. Plug the end of the nipple on the reservoir (not the return line).
5. Fill the resevoir to the correct level.
6. Turn the steering wheel right/left to pump out the old stuff.
7. Keep a watch on how much comes out into the jar and add that much back as you go along. Soon the fluid coming out will look like the new stuff that you are pouring in.
8. When your satisfied, reconnect the return line, fill the reservoir, start it up, turn the steering wheel r/l a few times then recheck the level.
9. Dump the old fluid in with the oil for recycling.
Best of Luck
Andrew
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
cars-guy
Jul 11, 2015 07:51 PM
jon.r
Jul 11, 2015 03:34 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
