What kind of fluid goes into the ......
Old Nov 15, 2004 | 06:04 AM
havic's Avatar
transfer case and front differential? I changed the rear differential fluid and I put in 80/90 gear oil, took almost 3 qt's. Do I put the same type into them as well? Also, how many qt's would I need for the transfer case and front diff?
Old Nov 15, 2004 | 06:18 AM
evilcow's Avatar
80/90 also. Not sure how much.
Old Nov 15, 2004 | 07:51 AM
Sac State's Avatar
Wesson, or Canola is low in trans-fats.
Old Nov 15, 2004 | 08:24 AM
Ilovemountains's Avatar
I used Mobile 1
full synthetic gear lube in my diffs, but my auto transfer case uses ATF...
Old Nov 15, 2004 | 12:11 PM
havic's Avatar
Thanks. Does Wesson have 80/90?
Old Nov 15, 2004 | 12:58 PM
VolcomTacoma's Avatar
Look in your owners manual if you have it. It tells you exactly what oil you need to use.
Old Nov 21, 2004 | 06:30 PM
Brew's Avatar
My 91 4x4 pickup takes GL5 in the rear and GL4 in the front...all I know of...my tranny takes GL5 also
Old Nov 27, 2004 | 07:51 PM
alanbobalan's Avatar
i checked my transfer case oil recently and it was pratically empty. it took one and a half bottles of gear oil to fill it back up again. i'm not sure exactly how much was in a bottle. there's no telling how long it's been like that. i hadn't checked my transfer case oil since i've had the truck. eeek. i know this is probably a really bad thing. any comments??? any input would be nice. thankssssssssssssssssss.
old87yota
Sep 9, 2015 12:39 PM
86 87 4Runners
Sep 5, 2015 06:02 AM
eggens
Sep 5, 2015 12:16 AM
Scatterbrain
Sep 3, 2015 06:46 PM
86 87 4Runners
Sep 2, 2015 03:54 AM
