Turns Over, but no dice.
Old 04-28-2005, 03:58 AM
Jays4Runnin's Avatar
Went to go start the car this morning, turns over, but dosent catch. Any prognosis's from the truck gods? Decently new spark plugs.
I should also mention that it has been moist and rainy here lately. Could it be water in the distibuter cap?
Jays4Runnin is offline
Old 04-28-2005, 07:00 AM
TRunner's Avatar
yes it could... It could be lots of things actually. Do you mind adding a bit of detail to the term "doesn't catch"? Is there any fire or stutter or does it just spin with no fire? Is there any fuel smell when you are cranking it? What type of plugs?
TRunner is offline
Old 04-28-2005, 09:00 AM
4Crawler's Avatar
Any hints as to what type vehicle and engine you are talking about?
4Crawler is offline
Old 04-28-2005, 09:05 AM
My99's Avatar
haha.. this guy's one for vagueness. I'm assuming since he implies (and thus knows) that it's got a distributor, it's a pre 3G. Take off the distributor cap, get you some WD 40, spray in there, wipe it out, make sure all condensation is gone, put it back on, fire up the truck and don't shut it off for at least 10-15 minutes to make sure everything dries up. Your seal on the cap is probably bad, and if you fire it up and shut it back off momentarily, the radiator fan will blow more moisture in there. Let everything get warmed up and burn all that steam off before you shut it down.
My99 is offline
Old 04-28-2005, 09:28 AM
jimbo74's Avatar
maybe, maybe not..... i have found that a lot of people have no idea what kind of ignition system they have and everyone jsut assumes they have a disrtibutor when the fact of the matter is distributors are on their way out and a lot of manufacturers are now using a distributorless ignition system
jimbo74 is offline
Old 04-28-2005, 10:17 AM
My99's Avatar
Thus i prefaced my whole explanation with him having a PRE 3rd gen. Although I don't know for sure if the distributors lasted the whole way through the 2nd generation or not...I know the early years had them.
My99 is offline
Old 04-28-2005, 10:18 AM
Bigkahuna808's Avatar
Mine was doing that for the longest time. It was my idel control valve
Bigkahuna808 is offline
Old 04-28-2005, 01:54 PM
Sorry
92 3VZ
Yes spark plugs are a year old
wires are new 6 mo.
Old 04-28-2005, 02:12 PM
eric-the-red's Avatar
While you've got that distributor cap off checking for moisture crank the engine and watch the rotor, if it's not turning then it's a broken timing belt. If that's OK check for spark at the plugs and also the coil. If you have spark then listen for the fuel pump when you first turn the ignition on.
You have to systematically eliminate possible problems until you find the cause.
eric-the-red is offline
okamikai
04-30-2018 10:19 PM
Shoua
13
05-22-2016 05:19 AM
Dakotaneu
08-15-2015 07:24 AM
JHalcyonM
08-04-2015 01:19 PM
Hamonacracker
07-17-2015 08:33 AM
Quick Reply: Turns Over, but no dice.
