vacum/intake or fuel problem??????
Old May 6, 2005 | 07:03 PM
vickers88's Avatar
I just done a motor swap to my truck. (because it kind of went though a little too much water and blew the engine.)
Then engine I put in was a carbed engine but I put all the fuel injection back on. Now I can not find any leak or hoses off. The truck runs just fine as long as the peddale is pressed just the slightest amont. It also will not start unless the pedal is pressed down a bite.
One think I have noticed . when you turn the key to the on position but no start the truck you can hear under the hood like the fuel pump turning on but it does not shut off. I felt the gas line and it feels like it is pumping gas though it but the engine is not running.
Any suggestions where to check first would be great .
Old May 6, 2005 | 07:10 PM
farmerj's Avatar
If you need to touch the throttle, I would measure your TPS and make sure it is adjusted properly.
Old May 8, 2005 | 02:58 AM
84sr5yoty's Avatar
Hmmm. The fuel pump only cylces on while cranking the motor over, then continues to run until the motor stops. It shouldn't be running with the key on engine off. Do you have the fuel pump test connector shorted?
Old May 8, 2005 | 12:02 PM
vickers88's Avatar
the pump test is not shorted. Is there anything else that could cause the pump not to shut of when engine is not running and key is on?
jbv808
Aug 6, 2021 04:47 PM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
gary4runner
Sep 24, 2015 12:53 AM
shisha1999
Jul 13, 2015 11:09 PM
