Gas Pedal Sticking
Old May 12, 2005 | 10:13 AM
BBrown's Avatar
Gas Pedal Sticking
The gas pedal on my 2000 4Runner often sticks when you first push on the gas pedal to start moving, not during acceleration. I checked out the cable and can't see any glaring problems. Has anyone had a similiar problem? Any suggestions? Thanks
Old May 13, 2005 | 11:37 AM
boogyman's Avatar
sounds like the spring on the pedal might be catching, or gunked up? if not that, check the throttle body. it may need a good cleaning
Old May 17, 2005 | 07:39 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Clean your throttle body. There should be a write-up about it. The varnish tends to cause the butterfly valve to stick and it usually breaks free when you first touch the accelerator and then is usually ok while your driving. It'll stick again after sitting for awhile. It's easy to do and will save you about $60 from having the stealer do it.
smthwsn357
May 1, 2024 07:28 AM
AppalachianOffRoader
Aug 12, 2015 12:55 PM
HollieJayyy
Aug 9, 2015 07:59 AM
D.B.T. 87 4x4
Jul 20, 2015 04:51 PM
