My first leak
Old Apr 21, 2005 | 05:21 AM
Lance's Avatar
My first leak
I have a small red oil leak out the front of the engine. It left two drip marks close to each other on the driveway. This is the first leak I have. I have 2 pics of where it's leaking, would someone host these for me temporarily?
So what would leak red oil from the front? It feels like transmission fluid, it's not as thick as gear oil. It's definitely oil, so coolant is out.
Thanks
Old Apr 21, 2005 | 05:25 AM
rimpainter.com's Avatar
If its red and it's oil, it's ATF.
Old Apr 21, 2005 | 05:39 AM
Lance's Avatar
But from the front of the engine? It's right below the drive belts.
Old Apr 21, 2005 | 05:45 AM
Well you say it's oil, so that is what I have to go on. Normally a red liquid from the front of the motor would have water pump written all over it, but if you are positive it is thick (oil) then that is the only other thing it could be.
Can you pressure wash the engine and try to track down the source?
Old Apr 21, 2005 | 05:50 AM
My99's Avatar
...power steering fluid perhaps? THat'd be red.
Old Apr 21, 2005 | 06:08 AM
Good point, maybe that's it.
Old Apr 21, 2005 | 08:41 AM
Duec66's Avatar
Yeah its probably power steering fluid. When I replaced the radiator in mine I took the hoses off the passenger side bottom, and the same red oil liquid came out. I figured it ran through the radiator to cool off .
You might want to check the hoses where they conect to the radiator for the leak. Or pressure wash the power steering pump and check that.
Old Apr 21, 2005 | 08:52 AM
Lance's Avatar
Thanks for all the help. I'll be checking on it tonight.
I have 2 pics, can someone posts these? These give a good view of where it's leaking.
Old Apr 21, 2005 | 09:04 AM
Just sign up for Monty or another pic hosting site.
Old Apr 21, 2005 | 09:28 AM
Lance's Avatar
Now that didn't hurt.
It dripped down onto the white plastic.
This is viewing from the front laying on the ground.
A little far back view
Old Apr 21, 2005 | 08:16 PM
Duec66's Avatar
Never mind the radiator idea. That looks like its coming from under your water pump. No clue
Old Apr 22, 2005 | 04:51 AM
I agree.
Old May 3, 2005 | 04:25 AM
gohawks's Avatar
hmmmmm I have the same problem, dripping red oily fluid under the passenger side front of engine. At first I thought it was only happening when I parked on an incline. Last night however I parked flat and there was a drip of the fluid about the size of a quarter.
I've found a couple of other posts referring to this. Did anyone come up with an answer??
1988 4Runner 3.0 Auto
Old May 3, 2005 | 05:30 AM
YotaJunky's Avatar
sounds like power steering fluid to me.
Troy
Old May 3, 2005 | 05:35 AM
gohawks's Avatar
isn't it on the wrong side to be power steering? mine drips on passenger side....really i have no idea lol.....anyone??
Old May 3, 2005 | 06:28 AM
YotaJunky's Avatar
my powersteering is on the passenger's side.
Old May 3, 2005 | 09:26 AM
gohawks's Avatar
yeah i'm pretty much an idiot, the power steering is on the left side....something (presumably the somthing to do with the power steering) is leaking red fluid. It is running down that bottom passenger side of that plate thingy under the front of the truck. I checked the power steering fluid and it appeared to be full....so who knows. I guess i'll just hope it stops lol
he's gone
7
Dec 3, 2019 07:08 AM
4runnerjunk
Aug 22, 2015 09:06 AM
accuracy
Aug 4, 2015 08:05 PM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
