more aisin problems
Old Apr 27, 2005 | 06:32 PM
hill's Avatar
more aisin problems
has anyone had problems installing aisin....
i took one side apart today....put it back together, and now the 4x4 engages, but the tire rocks up and down...
arrgh frustrated....just about off to a shop to get it looked at.
Old Apr 27, 2005 | 06:42 PM
AW1090's Avatar
I don't understand....rocks up and down as in the suspension or....when you mounted the tire did you not get it back on the lugs all the way? I'm confused as to what's happening....
Old Apr 27, 2005 | 07:58 PM
hill's Avatar
when i have the hubs locked and not in 4x4 its screwed....something isnt aligning...
it would be like if there were a large bump on one location of a circle and as that part contacted the ground there was a bouncing over the lump....its sounds terrible!!!
If i unlock the hubs...no problems at low speeds, but there is still a small vibration again...
frustration is making me want to just take it to a mechanic....plus working outside tonight the temperature was dam as cold....
i guess im just trying to vent
Old Apr 27, 2005 | 09:34 PM
AW1090's Avatar
you've check everything else and know it's your hubs...right? That's cool....just take it apart and start over. I know it sucks.....do you have any pics of your assembly?
Old Apr 27, 2005 | 09:42 PM
DudeBud's Avatar
are they IFS hubs
Old Apr 28, 2005 | 05:19 AM
hill's Avatar
yes, 100% IFS hubs... it seriously seems like the driver side hub is 100% installed properly... its the Passenger side that is making terrible noise, and doing crazy things in 4x4.
Old Apr 28, 2005 | 06:03 AM
cabbage's Avatar
Wheel bearing preload not adjusted right? Just a thought...
Old Apr 28, 2005 | 07:30 AM
hill's Avatar
its in the shop as we speak getting an alignment.... i asked the guys to take a look at the hub fore me...
Ill report back when i pick it up.
Old Apr 28, 2005 | 09:47 AM
hill's Avatar
damaged axel from a crack in my cv boot.....$800.00 cost to fix....
"im grabbing my ankles bent over as we speak"
Old Apr 28, 2005 | 10:11 AM
DudeBud's Avatar
do it your self
Old Apr 28, 2005 | 10:21 AM
Eric's Avatar
how does a crack in the CV boot damage an axle?
Old Apr 28, 2005 | 10:24 AM
hill's Avatar
what the shop said is that the cvs are leaking, and the axel is leaking and contaminated and crap
Old Apr 28, 2005 | 11:19 AM
AgRunner06's Avatar
You've got to be kidding me. Did you really pay for that? Can you explain any better what they said? CVs = front, Axle = back. Even if you need new CV shafts, it won't cost $800. I've heard Sears will put in a reman for $200.
Did you do the install? Maybe you really messed something up. I've had my Aisins off a couple times and never had any problems. It shouldn't be that hard to find the problem once you tear it apart.
do it your self
Do what he said.
Old May 2, 2005 | 03:49 PM
LOCKnGO's Avatar
Do what he said.
There is no way the CV can leak into the hub! CV's cost $69.89 EA at just about any auto parts store. it takes about twenty minutes to change them.
jaretstuff
Aug 4, 2015 02:08 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
Jonny246
Jul 24, 2015 12:37 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
1996Taco
Jul 20, 2015 12:02 AM
