Relief valve?
Old May 5, 2005 | 08:19 PM
blainelukens's Avatar
Relief valve?
do any of you know where in the oil pump the relief valve goes? is it inside the timing belt cover or outside the cover. I think mine came out and it is leaking oil any ideas would help it is on a 89 v6 3.0 5 spd
Old May 6, 2005 | 07:16 AM
eric-the-red's Avatar
Looking at the diagram in the manual it looks like it goes straight out the bottom of the oil pump into the pan. If you're leaking oil from the timing cover I would think it's the front crank seal.
LotOMiles
Sep 14, 2015 11:45 PM
ac7822
Sep 11, 2015 08:49 AM
Boomer8404
Sep 10, 2015 09:01 AM
idadan208
Sep 7, 2015 09:06 AM
