Vaccum Help V6
Old Apr 25, 2005 | 10:57 AM
DubJunkE's Avatar
Vaccum Help V6
Anyone know where to get a detailed diagram or pics of the Vaccum line setup on the 3vze. Mine was dismantled while I was not around several months ago and now it's very difficult to put back together. I appreciate any help.
Thanks
Trevor
Old Apr 25, 2005 | 11:54 AM
Marc's Avatar
I can email you the diagram if you provide an email address.
Old Apr 25, 2005 | 12:03 PM
DubJunkE's Avatar
sacrifist@aol.com
Thanks that would be awsome.
Old Apr 25, 2005 | 08:59 PM
mtnfreak's Avatar
I've got an FSM for the '89 4Runner 3.0. If you can specify what sytem or part you need info on I can scan the appropriate pages and send them to you.
Old Apr 26, 2005 | 08:10 AM
DubJunkE's Avatar
Im having trouble sorting out the lines that run off of the passenger side of the plennum. There's a cluster of about 6 (2 sets of 3 lines)small lines all about the same size, then there is a vertical line of about 4 or five larger lines (varying size,maybe vaccum, not sure) but Im trying to get all of these sorted out. If you have anything that you think would help Id greatly appreciate it. If you need more info let me know Ill try to describe it better.
Thanks
Old Apr 26, 2005 | 07:33 PM
mtnfreak's Avatar
Got two things for you - 1 photo & 1 scan.
There are a couple of double hoses to be hooked up. Sorry I didn't have time to trace mine and give you a better description. Not sure if it makes a difference which hose goes where.
Hope this helps.
Old Apr 26, 2005 | 08:01 PM
4Crawler's Avatar
Old Apr 27, 2005 | 05:49 AM
DubJunkE's Avatar
That looks like some good info, thanks for everyones replies Im going to try to get it all worked out this after noon.
Old Apr 27, 2005 | 04:35 PM
DubJunkE's Avatar
Got her all straight and back on the road this afternoon, thanks for everyones help here's a pic for fun
the_supernerd
Oct 1, 2015 09:20 PM
87toy pickup
Sep 7, 2015 06:42 PM
93toyoguy
Aug 31, 2015 08:02 AM
Valvoman
Jun 28, 2015 02:45 PM
SpeedyJ
Sep 6, 2006 04:45 PM
