Carb cleaner vs throttle body cleaner---same thing?
Old Sep 10, 2003 | 03:40 PM
Bob_98SR5's Avatar
Guys,
I'm going to clean out my throttle body sometime before I leave for my business trip (its theraputic to work on the 'runner). Anyways, I went to Autozone and they had 2 STP products, one called "Carb cleaner" and one called "Throttle Body Cleaner". Naturally, I picked up the Throttle Body cleaner. However just getting back to the office and reading some past threads, one or two of you mentioned that the Toyota manual calls for the use of Carb cleaner.
So what's the deal? Are they the same product, but different names? That's my guess and this is all marketing b.s. Or is there really a difference? If so, should I return the TB cleaner and buy the Carb cleaner?
Bob
Old Sep 10, 2003 | 03:47 PM
AgRunner06's Avatar
Post
I don't know what the difference is. I just used the throttle body cleaner and it worked great for me.
Have Fun
Old Sep 10, 2003 | 03:59 PM
AznSky's Avatar
actually the thing I used was labeled carb cleaner / throttle body cleaner. So I was guessing it was the same thing. Worked fine for me. No warning lights or anything, and got rid of all the carbon deposits inside.
Old Sep 10, 2003 | 04:54 PM
3.4v6's Avatar
someone posted that carb cleaner is recomended by Toyota . .. i use carb cleaner to clean my TB.
Old Sep 11, 2003 | 07:30 PM
HaveBlue's Avatar
You'll want to use throttle body cleaner. Carb cleaner is more harsh on the sensors around the TB because it is formulated to remove heavy varnishes found in carburetors.
Old Sep 11, 2003 | 08:19 PM
Bob_98SR5's Avatar
guys,
can i use the TB cleaner on that thin MAF wire too? that is the one im' really worried about.
bob
Old Sep 12, 2003 | 06:03 AM
HBoss's Avatar
I suppose carb cleaner is more potent than TB cleaner, but I used it on my TB & my MAF. No problems here. Warning: results may very.
smthwsn357
May 1, 2024 07:28 AM
kazuya2416
Apr 5, 2024 02:17 AM
Jun 1, 2021 01:51 PM
raiderhawks00
Jul 8, 2015 06:23 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
