22R cold engine valve clearance
Old Aug 15, 2003 | 10:40 PM
whitesell7's Avatar
does anyone know the valve clearance settings for a cold 22R engine? I am putting mine back together and want to get it right without having to warm it up and then do it again. Any ideas?
I know that doing it hot is the correct way, I just want it to start and run properly while it warms up. If .008/.010 is correct for a warm engine would .006/.008 be good to start with on a cold engine?
Any help would be appreciated.
Robert
Old Aug 16, 2003 | 12:20 AM
loyota33's Avatar
that is a safe assumption IMHO
Old Aug 16, 2003 | 08:33 AM
Arnold's Avatar
Actually, it's .012 not .010. I've checked the clearances both hot and cold and the clearances remained the same.
Old Aug 20, 2003 | 12:02 PM
whitesell7's Avatar
Thanks for the info. I just set them at .008/.012, bolted it up and started it up. Ran/runs fine. I did have a problem with the EGR, so I just turned off its vacuum at the carb and that fixed that. Thanks again
Old Aug 20, 2003 | 08:40 PM
1877's Avatar
actually
Actually it's .007 and .011 cold but what difference does .001 make anyways.
Old Aug 22, 2003 | 05:35 AM
PirateFins's Avatar
Ok dumb question is that inches or mm??
Old Aug 22, 2003 | 05:59 AM
Arnold's Avatar
That's in inches. According to the factory manual the clearances should be .008/.012 but mine are set at .007/.011 since the engine runs quieter at those settings.
Old Aug 22, 2003 | 08:30 AM
1877's Avatar
fsm
According to the FSM it is .008 and .012 but that is with the engine warm, .007 and .011 would be the cold setting's. However you can set it at .007 and .011 hot without any negitave effects, as Arnold mentioned it seems to quite it down a little.
bigjstang
Jun 2, 2025 03:56 PM
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
razorman8669
Jul 12, 2015 12:13 PM
87blyota
Jul 10, 2015 04:31 AM
