clutch install
Old Sep 7, 2003 | 01:46 PM
Mrbowdeadly's Avatar
clutch install
Hey guys,
Never installed a clutch on a toyota before. Wanted to know any and all advice/instructions anyone could offer. Thanks in advance.
Jason
Old Sep 7, 2003 | 02:54 PM
Shane's Avatar
Have you ever done a clutch on any other vehicle? Replace both the throw-out and pilot bearings while you're in there, and have the flywheel resurfaced so the new disc doesn't chatter. Good time to flush the hydraulic system as well, and be prepared to replace the slave if it starts to leak after the new clutch.
Old Sep 7, 2003 | 05:20 PM
clutch
Yes,
I have done a clutch install on a ford ranger six cylinder. The only major difference is that it was not four wheel drive. The only problem I ran into was the quick disconnect for the hydrolic line. I didn't know it was a quick disconnect and I cut it. So.......I don't want to make any stupid mistakes on this one that make my job harder. I appreciate the response.
Jason
Old Sep 7, 2003 | 05:31 PM
Shane's Avatar
Don't have to disconnect the slave cylinder at all for this one, just remove the bolts so you can push it out of the way.
Old Sep 8, 2003 | 02:24 AM
Do I drop the rear driveshaft first, then unbolt the transfer case? Do I have to drop the front driveshaft? Do I have to unbolt the t-case from the crossmember? I have a bunch of questions. I really appreciate your help.
Jason
Old Sep 8, 2003 | 05:56 AM
Shane's Avatar
Remove both driveshafts, secure tranny jack, unbolt crossmember from frame (can leave connected to transmission) and lower tranny so you can get to the top two bellhousing bolts first. You'll need a couple long extensions to reach them, then remove the remaining bolts and remove the transmission. No need to drain oil or seperate the transfer case, but you'll want to remove the shifters before starting.
Old Sep 8, 2003 | 01:14 PM
Shane,
You are the man. Thanks for the tips, sounds pretty hassle free. I was wondering whether or not to tackle it, but I think I will. Really appreciate it, thanks.
Jason
Old Sep 8, 2003 | 06:40 PM
Victor's Avatar
Leave the transfer case and tranny bolted together. The balance point is way back - I usually get the jack under the transfer case and have a friend lower the jack while I lower the front of the tranny bench press style. The tranny/transfer combo is a heavy mother so take all precautions.
Old Sep 9, 2003 | 02:05 AM
Victor,
Thanks for the tip, I was going to try it by myself. I will enlist some help and locate a tranny jack.
Jason
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
1996Taco
Jul 20, 2015 12:02 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
