gauge lights
Old Aug 11, 2003 | 03:36 PM
REDYOTA's Avatar
gauge lights
my gauge lights do not respond and the fuse is not blown?????
Old Aug 11, 2003 | 04:03 PM
Yoter's Avatar
Guest
Maybe the dimmer switch is done for? Not sure how to test it but check your local wrecking yard and you might pick one up for pretty cheap being thats the only way I would know to test it.
Old Aug 12, 2003 | 06:18 PM
REDYOTA's Avatar
I installed a cd player and in after I was done I noticed my gauge dimmer would not work but the lights still worked just could not dim or brighten them and that was atleast two years ago.
Old Aug 13, 2003 | 04:20 AM
Yoter's Avatar
Guest
Did you remove the entire dash assembly as I assume you did? I have taken that cover off and forgot to reattach the connector. Its only a few screws on those covers. Take it off and double check.
the1998sr5
15
Jul 14, 2020 08:35 PM
AkitaDog
Sep 1, 2015 08:05 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Nickyodaman
Jul 27, 2015 12:13 AM
Poncho0206
Jul 10, 2015 06:21 PM
