View Full Version : Early Land Cruisers
- Are there any other ways to sell a 1966 landcruiser
- Best search source for used cruiser 4-door pickup (Greece)
- New to me 1993 J78
- Looking for Qualified Mechanic in Rockland, Maine
- Oil migrating from transfert case to transmission
- Fj60/Fj62 Youtube Channel
- 96 Landcruiser FJ80 - Soft Brakes - LSPV
- 87 Land Cruiser
- 1959 FJ25 wiper arms
- Carburetor 1fz
- BJ40 Forward Drive Transfer does not dis-engage to 2H
- Been eyeing an FJ60
- Will a RA61F M/T bolt up to a 1FZ-FE
- How do you determine your Cruiser is North American?
- Need a new radiator
- Help/Poll. What is my lift?
- 1992 Land Cruiser door glass run channels
- transfer case id
- 80 series LC diff lock ecu speed sensor bypass
- 86 Land Cruiser part search
- Dollar Value of F/R diff locks
- 1992 Land cruiser pulls right
- 1988 land cruiser
- Need advice on transmission replacement for 1968 FJ40
- putting 1uzfe in a 91 land cruiser, what is needed.
- New to me '78 FJ40
- How can i save rear frame & spring mounts ?
- 94 FZJ80 rear axle spindle damage
- 1980 Sidewinder question --- please move if I'm in the wrong place!
- Transfercase issue?
- '97 FJ80 lift suggestions
- Yotalockers.com - Elockers for Land Cruisers
- h engine clutch question
- 1986 BJ-40 Diesel died after whoops
- 1988 LC- Window doesn't stay up
- Seat Covers
- 1994 Toyota Land Cruiser burning oil
- Thinking of getting an '82 w/ an LS swap
- HJ60, slow build, with spurts of activity ;)
- New BJ60 owner questions
- 87 landcruiser
- solid axle birfield re assembly
- 1977 FJ40 F2 engine - no fuel in the sight glass
- 93 LC has miss
- Finally joining the cruiser club!
- 2000t4r trade for 89 fj62
- Head gasket
- 88' FJ62 Power Window HELP!!!
- 89 LandCruiser Engine Specs
- Help with '94 Yota LC Price/Purchase
- Which FJ80 and questions
- Any FJ40's out there?
- 97 landcruiser selectable transfer case and manual hubs?
- 94 Land Cruiser help
- CLCC FJ40 raffle truck
- 1978 Landcruiser
- 1974 Toyota Land Cruiser PickUp Diesel Looks Clean
- 69 landcruiser differentials
- Bought a Toyota PTO winch, what else do I need?
- Fj80 diff lock issues
- Found a LC local, owner wants me to make an offer, help!
- Drove my '91 Land Cruiser on dry pavement, now tranny with not engage w/out. HELP!
- BJ60 (HJ60) Roof Headliner
- Most collectible FJ 40 land cruiser years?
- Dome light, wiper motor, dash piece, arm rest
- '93 Cruiser center differential lock switch addition?
- just picked up a 1986 need tips
- Looking to unload these Jump Seats
- Land Cruiser LX
- 1990 FJ62 Question
- Fj40 width - sidewall to sidewall w/ 12.50's
- 72 FJ40 Brake advice
- Early Land Cruiser rear emblem question...
- Landcruiser transfer box query
- FJ40 as a hunting rig?
- 91 Fj80 89 land cruiser radiator compatibility
- FJ80 3FE code 21 issue
- 84 fj60 fuel issue
- fj40 paint job
- New Land cruiser owner!!!
- FJ 55 info/help?
- please help Landcruiser swb FJ71 1995 looking for lockers
- Land Cruiser J55???
- 69 FJ40 - To Be Or Not To Be?
- 1996 Land Cruiser A343F Hesitates on 1-2 shift
- FJ40 Under Dash transfer case info?
- Crossed Over To The Dark Side (FJ80)
- Dallas Cruiser
- Lift/tire combo
- New FJ40 Fiberglass Tops with Built-in Raingutter
- Air Pump Check Valve
- Rotten Egg Smell
- Oil Consumption vs. Oil Leak
- First 80
- Missing starter ground wire for 92 FJ80 3FE
- Steering Box Insert?
- Efi fuse blown low idle
- FJ80 With H1 Recentered wheels and 37
- Help! my fj-62 won't idle!
- Water pump help please?!?
- My new 1979 FJ-40!! Diesel conversion?
- need the trick to get the #1 oil pan out on my '93 fzj-80
- 1980 FJ40 General questions
- Considering getting 93 Land Cruiser
- Price for insurance
- Need advice/input on a 96 Land Cruiser
- 84 fj60 throttle linkage how to connect?
- Automatic vs manual gear box
- First time restoration '78 FJ40
- Newbie landcruiser question
- instructions to remove carb on fj60
- Buying an FJ60 in Central America?
- FJ 80 axle info needed
- Need help asap about buying 1981 FJ45h
- Help! FJ40 advice
- thinking of buying a land cruiser
- Tail gate years?
- 97 LC, 97 Lexus vs 05+ 4runner
- Classic Cruisers in Salida, CO?
- 84 FJ 80(?) question
- my new toy 1970 FJ40
- 1963 and 1972 FJ40's
- Moog Tie rod ends
- What to Pay for 84 LC FJ60
- Engine hesitates when warm.
- bringin' back the LC!
- bob tail 80 series
- panhard rod mount torn from chasis
- '94 anti-lock brakes... don't
- FJ 80 engine swap.
- 95-97 FJ80 buyer advice?
- 84 FJ60 No Fuel/No Start- Fuel gets to carb, ICS Q's
- FJ55 blinker relay
- Just bought a FJ62!
- Serious coolant leak
- FJZ80 rear axel ...CR-MO ????? where??
- How can i improve mpg '92 cruiser
- Fuel leak on FJ62
- My new (old) cruiser.
- 83 fj 60 carb rebuilt and running
- fj60 fender flares?
- fj 60 carb rebuild problem
- 83 fj 60 carb
- 1983 BJ60 Landcruiser
- fj60 spring over lift?
- landcruiser parts?
- FJ45 In VA? need for bumper fitting
- 'Rattling' noise in 1997 4.5l Petrol Landcruiser, Driving me nuts!!
- 1985 Toyota Land Cruiser FJ60 ONT Canada
- Eaton e lockers????
- Keyless Entry Remote Programming Sequence?
- 2000 LandCruiser Running Boards
- cryoscience...stronger, cooler, longer
- Lubricate speedo/cable on '89 Landcruiser
- 1982 FJ60 jerks at cruising speed
- What is the most desirable year FJ40?
- '84 FJ60 chronic brake problems in SF,CA
- 1987 FJ60 Dies often
- $5,000 BJ60 for sale in Texas!!
- Might be a new(old) Land Cruiser owner! but need buying tips
- Help Needed: P0120 Throttle Position Sensor/Switch A Circuit
- My new rhd vx
- Got me a new Land Cruiser
- NEW FJ40 Owner with some questions
- What is this?
- I've got a Job on a '89 Landcruiser and have a question on the rotors?
- 1969 fj40
- 93 cruiser loss of power
- One Busted Tube on F2 Air Injection Manifold
- No AWD on Front Axle, 93 FZJ80
- needing a lift kit
- Rare Fj
- Junkyard Cruiser
- speedometer driven gear removal
- 1976 Toyota FJ55 on bringatrailer.com
- BJ60 Rough Idle
- differential questions
- pulling the cel code ?, 96 land cruiser
- LX450 and lockers...school me.
- 88' FJ62 no fuel being delivered to cylinders
- 1984 FJ60 Land Cruiser is making me mad!
- FJ40 - Engine 14b - Transmission Auto
- goodbye 4Runner, hello Landcruiser
- Need Help IDing This Part! What is it?
- 95 model with hd ft turbo diesel 5 speed
- 82 fj60 diesel wont run
- FJ40 Start help
- New Guy looking at FJ40
- HZJ80 project
- trans check?
- 4.0L power improvement???
- 1996 Land Cruiser (FZJ80) build questions
- Importing an FJ80
- front and rear lockers?
- 1991 fj80 front end squeak while driving.
- land cruiser frame & axles
- Repair Manual
- 1964 FJ40 Questions
- #2 Oxygen Sensor 95 Landcruiser Help
- BJ60 3B headgasket
- 1991 landcruiser engine question
- Best Pre FJ62 Land Cruiser for restoration
- 63 fj 40 ball-joint front axeles
- 85 4runner leafs under 83 landcruzier
- O2 Sensor on 96 Land Cruiser
- Tie rod/Pan hard rod- What is it?
- fj62 wont come out of 4WD
- need help with my fj62
- 1976 fj40
- What Happened to my Labor Day Weekend (FJ40/55 content)
- FJ60 - rear hatch for an '84?
- landcruiser / toyota 4x4 pickup comparison
- 90 landcrusier problems
- FJ60 FJ 62 2 door?
- 78 FJ 40 wont idle
- Drive Flange Number?
- 3FE, auto tranny, t case prices...
- FJ80 axle questions
- Should we DIY- Possibly Trunion Bearng problem
- '94 Landcruiser Adventure O.o
- Need help w/1978 Fj40
- FJ80 tranny differences?
- need fj62 parts
- fj 55 question
- 1970 FJ40 diff question
- 87 FJ60 exhaust related (?) question...
- fj60 mini truck pump
- My collection grows : adopted a '82 BJ60
- FZJ80 Transmission Trouble HELP!! PLEASE!!!
- Need help on price of 1984 FJ60
- 84 FJ60 EGR cooler tube replacement
- 1994 FJZ80 Land Cruiser gauge cluster?
- 94 manual transmission cruiser - rear diff lock?
- Replacing 1997 corroded O2 oxygen Sensor bolts and nuts
- What sub forum for my 94 landcruiser?
- 1988 Land Cruiser FJ Fuel Pump Relay - Where is it?
- Gas mileage for 80's series, How good can it get?
- Where to get body parts?
- Lookey what I found
- landcruiser gen breakdown
- Getting a mid 80's Land Cruiser!
- elock actuators
- Lets see your cruisers!
- Hello all - Looking for FJ62 Parts -
- FJ45 hits America-May 78 vintage mag-Mary fundraiser
- 1970 fj40
- Awesome fj40 for sale in mn
- New FJ60 off ebay.
- Land cruisers owners with 350's!!!!!!!!!!
- 80 series startup issue
