Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
1988 land cruiser
Old Jan 30, 2018 | 02:42 PM
JoelJustin's Avatar
1988 land cruiser
1988 toyota land cruiser transmission coolant bypass aluminum tube. It runs underneath the front of the crankshaft/oil pan area. What is this part# ?
Old Jan 30, 2018 | 02:43 PM
JoelJustin's Avatar
No After Market parts houses can find any info on this tube. Mine is pitted and leak intermittently.
Old Feb 1, 2018 | 11:20 AM
keycw's Avatar
5 Year Member
youll have much better luck if you post in the appropriate forum. most of the cruiser guys hang out on mud to be honest.
Old Feb 1, 2018 | 11:41 AM
old87yota's Avatar
Can you post a picture or two of the transmission coolant line?
You can try to find the part you are looking for in a diagram from online OEM parts dealers such as Toyota Parts Overstock.
Here is a transmission cooler diagram I found on Toyota Parts Overstock:
If you need more help from people who know Land Cruisers better than we do, head on over to https://www.ih8mud.com/ like keycw said. They are a Land Cruiser centered forum.
Old Feb 1, 2018 | 11:54 AM
keycw's Avatar
5 Year Member
lots of part out cruisers over there also, i assume since you are looking for a tranny cooler part its an automatic, which most likely means fj62? unless youve got an import, more info will help you. there are several tlc guys on pirate4x4.com also
Old Feb 6, 2018 | 03:11 PM
JoelJustin's Avatar
RE: 1988 Toyota Land Cruiser. Hey there fellas and gals...no one seems to know what the part number is for this aluminum tube that wraps around the bottom of the front of the oil pan to carry coolant to the transmission to cool the trans oil. ANYBODY know? (see attached photo)
Thanks,
Joel
Old Feb 6, 2018 | 03:14 PM
JoelJustin's Avatar
1988 Toyota land Cruiser
Old Feb 6, 2018 | 04:44 PM
dropzone's Avatar
Fossilized
moved to correct folder.
You might wanna try ih8mud.com.
Not a lot of LC knowledge here, tons of stuff on the mini trucks & 4runners but not a lot of cruiserheads
Old Feb 6, 2018 | 04:52 PM
highonpottery's Avatar
Why not just replace the whole thing with a flex tube and eliminate all those misc connections for a simpler system?
Really, your best resource for your FJ62 is the 60-series forum over at iH8mud
wyeto
Nov 29, 2017 06:13 AM
NookieMonster
Nov 27, 2017 07:43 PM
fj40Man
Nov 25, 2017 01:49 PM
High Alt Gold Miner
Nov 14, 2017 10:57 AM
