Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
1991 landcruiser engine question
Old Jan 27, 2010 | 06:07 PM
VEDAVOO's Avatar
I am looking to buy a 1991 landcruiser localy. I have always wanted to own a fj80 but i do not know alot about them. It seems fairly solid but my concern is about the engine. At an idle it has what sounds like a ticking rocker arm or upper vavle train noise and does speed up with rpm's. I did not know if that is normal for a 3fe engine it has 119000 miles. I know some other straight six motors like a jeep 4.0 has quite a bit a valve train noise and is cosidered to be normal. Any info on what to look for in this vehicle will be a big help.
Old Jan 27, 2010 | 06:19 PM
neoworm0's Avatar
It's a noisy motor. the 91's are pretty underpowered but the motors are bulletproof. If you can though a 93 to 97 are the desirable ones.
You should get on www.IH8MUD.com and read the stickies as well ther eis some good info on Slee's sight.
Old Apr 17, 2011 | 01:38 PM
Lc80series's Avatar
[quote=neoworm0;51347359]It's a noisy motor. the 91's are pretty underpowered but the motors are bulletproof. If you can though a 93 to 97 are the desirable ones.
X2. Try to find a 93-97 with the 1FZ-FE. More power than the 3FE.
Old Sep 22, 2011 | 07:08 PM
Antisvt's Avatar
What kinda longevity are people getting outta the earlier 1rz engines?
bigjstang
Jun 2, 2025 03:56 PM
kazuya2416
Apr 5, 2024 02:17 AM
Colington
Mar 8, 2020 09:51 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
zd92655
Jul 5, 2015 04:25 PM
