Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
Automatic vs manual gear box
Old May 26, 2012 | 08:02 AM
Waelguitar's Avatar
Hello every one
I have a fzj80L gnpeka with
- a442f automatic gear box
- 4.55 deffrential ratio (standard tier size 275/70 R 16 ) which I modified original is 4.11 ratio
- part time conversion with dash switch installed
- front weel hubs
I have problems with the automatic gear box so I thought of shifting to manual gear H151F 5 speed.
My concern is the 5th gear ratio in the manual is 0.881 :1 which I think will reduce the car general speed even more than what it is after my reduction from 4.11 to 4.55 deffrential ratio
In the A442F the 4th gear ratio is 1:0.756
Has any one done this shift to manual and faced this problem of general speed reduction
Thanks a lot
Old May 26, 2012 | 08:09 AM
waskillywabbit's Avatar
ih8mud.com
:wabbit2:
Old May 29, 2012 | 06:25 PM
rokblok's Avatar
Going from 4.11 to 4.55 isn't a reduction per say. Its a gear reduction, but will raise RPMs. I would go 5-spd, if it were mine and I had a donor vehicle to get all the necessary parts from.
Old Jul 23, 2012 | 08:22 PM
RJR's Avatar
RJR
The combination of going from 4.11 to 4.56 gears and changing the transmission ratio from 1:756 to 1:881 will give you a 29% change in your top gearing. If, for example, before you were running 3000 rpm at 70mph, after the two changes it would require 3870 rpm for the same speed. That's a pretty big change, and you're right to be thinking twice about it. Maybe change to bigger tires at the same time to better match the new gearing.
Ron
BeMiceElf
Oct 10, 2015 09:40 PM
Tykiller1994
Aug 10, 2015 07:49 PM
rushw
Jul 18, 2015 01:46 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Poncho0206
Jul 10, 2015 06:21 PM
