Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
1987 FJ60 Dies often
Old Oct 1, 2010 | 07:18 AM
LandBruiserFJ60's Avatar
I have a 1987 FJ60 straight 6, 4spd. And everytime I hit a puddle of water big or small if starts to cut out and then it dies. It takes forever to get started again. I have had to trailer it home manytimes. I dont take this thing of road only on rare occasions. I has died just driving down a road with water on it. It has even I died in heavy rain. I cant make sense of it. Replaced spark plugs and wires, cap and rotor, ignition coil, and i even took an old licsense plate and made a shield for the coil. I thought it was getting wet or somthing. any advice..?
Old Oct 1, 2010 | 08:01 AM
camo31_10.50's Avatar
yep..water is getting to something electrical.
check your grounds!!!
Old Oct 1, 2010 | 10:42 PM
FlyingLow's Avatar
Look at whats wet when it dies. Not overly familiar with 60s but any harness plug going through the fire wall? I wouldn't check grounds first, water provides a better ground. It will provide a ground to a power wire though. Just a guess, not sure if it has a cut off but is there an oil pressure switch (not sender)? Anything else electrical down low on the engine?
Steven.m.paulk
Jun 7, 2020 10:45 AM
buckz6319
Aug 5, 2017 03:50 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Rcbc92
Sep 26, 2015 03:00 PM
toyotasaurus
Sep 24, 2015 03:30 PM
