Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
Steering Box Insert?
Old Oct 7, 2012 | 02:07 PM
fasternu_674's Avatar
I am needing the flare seat for the return line on the steering box. Looks like a mushroom when removed. Anyone know what these are or where I can get one? I need one ASAP. Have a trip planned next week. Sits down inside the steering box. Thanks.
Old Oct 8, 2012 | 06:29 AM
rokblok's Avatar
Isn't it cast/machined into the box? I'm trying to picture exactly what you're working on, so I could be way off base...
Old Oct 8, 2012 | 11:39 AM
No it is a small brass piece that inserts into the box. Look like 2 pieces in the lower right hand corner. http://lee-powersteering.com/rebuild-misc.htm Waiting on a call from them. They are the only ones that seem to know anything about them. The piece is what accepts the flare fitting for both your pressure and return lines. It is supposed to be press fit but mine must have been a little loose cause they fall right out.
Old Oct 8, 2012 | 08:13 PM
rokblok's Avatar
That's interesting. Is this a factory Toyota box? Or Sag conversion?
Mind if I ask what we are working on?
Old Oct 9, 2012 | 07:00 AM
Factory Box, most people don't know these things are in there. I am doing a power steering conversion on a suzuki samurai. Using the FJ60 box for clearance. Also have toy axles under it so toy steering bolts right up.
Old Oct 9, 2012 | 07:10 AM
sandigan's Avatar
I have several FJ60/62 boxes on the shelf. If Lee doesn't have what you are looking for, I could tap one of the fittings out for you to get you going. Give me a call if Lee doesn't have what you need. (619)251-8052.
Thanks.
delmert
Sep 30, 2015 04:34 PM
I8URSVT
Sep 3, 2015 11:42 AM
Gone Fission
Aug 24, 2015 04:59 AM
zombie_stomp
Aug 17, 2015 05:29 PM
basfire
Aug 14, 2015 07:58 PM
