Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
needing a lift kit
Old Jul 14, 2010 | 03:42 AM
joncoey1986's Avatar
needing a lift kit
i have a 85 land cruiser and wonting to put 35 tires on it but i cant find a lift kit for it if anyone can help let me know
Old Jul 14, 2010 | 04:17 AM
waskillywabbit's Avatar
Ih8mud.com
Old Jul 14, 2010 | 07:42 AM
if a lift kit for another truck would work for mine let me know
Old Jul 14, 2010 | 07:58 AM
dropzone's Avatar
Fossilized
toyota landcruiser assoc: http://www.tlca.org/
off the top of my head check out http://www.ironpigoffroad.com/
http://www.man-a-fre.com/
http://landcruiserspecialties.com/
http://www.arbusa.com/
http://www.sor.com/
forgot these guys: http://www.metaltech4x4.com/metaltechnew.html
you 101? I was in the 6th ID LRSD falling out of planes a long time ago
Old Jul 21, 2010 | 10:52 AM
FlyingLow's Avatar
Old Man Emu is about the best around.
Old Jul 31, 2010 | 04:31 PM
fourtrax's Avatar
if you take off the fender flares and add a 4crawler.com 1" body lift. you can run 295/75/16 (34.8") you might rub a little on on a full stuff, but not much. i am running OME heavies, cause i bought the 80 with them on it. a lot of the guys are runnning http://frankies4x4.com/ 3" lift. it has a progressive spring rate which soaks of the little bumps a lot better then the OME's. it is a bit more money but worth it if you want a plush ride. several people have just purchased the springs from frankie and then cut off one loop and gone with some 5150 shocks and slee blue caster correction bushings. as the wabbit mentioned IH8mud.com is your source for cruiser info.
Old Jul 31, 2010 | 07:39 PM
gary_the_4runner's Avatar
try these guys, supposedly comparable to OME
http://www.ironmansuspension.com/index.html
the US, Canadian vendor:
http://store.camel4x4.com/merchant2/
Old Aug 1, 2010 | 04:41 PM
FlyingLow's Avatar
He's got a 1985 60 series. A little different...
NOOOOOOO!!!!!!! Iron man springs should be called Iron Butt springs. They suck! I had them on my 40 when they were first brought in to Canada. Stay away! Horible ride, the rear shackle angle was so bad the guy I bought them from paid to have longer mains built for them.
Old Apr 25, 2011 | 02:31 PM
Lost's Avatar
i ordered my Ome lift kit from cruiseroutfitters.com fair prices , quick delivery and the guys was very knowledgeable.
i got to say: i had a xtra heavy kit (3inch lift) and could not fit 35inch tires whyout some major rubbing. forget about going offroading with some fender mods.
i did soa to fit my 35s, now they look almost too small
Old Apr 26, 2011 | 06:50 AM
FlyingLow's Avatar
Originally Posted by Lc80series
x2 on man-a-fre.
Will you please take note of how old the post is you are replying to? Nobody wants to see 1 year old posts being brought back from the dead.
live4soccer7
Sep 3, 2015 12:29 PM
bowhunter1640
Jul 6, 2015 08:10 PM
rondogracing
Jul 5, 2015 12:32 AM
BigArt70
Jun 30, 2015 09:51 PM
HALMAN
Jun 14, 2002 09:02 PM
