Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
72 FJ40 Brake advice
Old Sep 9, 2013 | 10:14 AM
wrightdavid9's Avatar
Question 72 FJ40 Brake advice
I've got a 72 FJ40 that I've been working on. I need some help in figuring out why I can't get my brakes to act right. I've replaced all the wheel cylinders, brake lines, master cylinder, & shoes but I can't figure out why I can't get the brakes to work correctly. They work but only after pumping for a few times. I've bled and bled the lines, no leaks, just dumbfounded. Could the new master cylinder be faulty? What else should I check/try?
Old Sep 20, 2013 | 03:03 PM
loosechange's Avatar
Could be leakage into your power booster....any of your reseviors going low yet no external leaking?
Old Jun 6, 2014 | 03:28 AM
Farmhouse's Avatar
Could still be air in the system.
Also, try readjusting all the shoes. If they are adjusted too far in it will take a pump or two to push them out. Adjust them outwards so the shoes are just touching the drum.
Old Jun 19, 2014 | 04:24 PM
TacomaTruckParts's Avatar
Yep..... very important to adjust all the shoes evenly, and as close to the drums as possible.... otherwise it might pull to one side or take a few pumps. i have gotten used to to the 3-pumps to get brakes on my 1970.... Also why I wont let ANYONE drive it... 1 push and you get no brakes ( a pain for the constant adjusting needed), need to pump at least 3 times before any braking action.
Eggslinger
Jun 8, 2019 03:32 PM
Iceman4193
Aug 28, 2015 08:43 PM
accuracy
Aug 4, 2015 08:05 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
CanRunner
Jul 20, 2015 01:29 PM
