Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
87 landcruiser
Old Jan 29, 2016 | 02:02 PM
854runnerhunter's Avatar
87 landcruiser
Hi everyone. I'm having some issues starting an 87 landcruiser.
Here's my attempt;
I have an 87 samurai that has been sitting for a few years and it wouldn't start. So I talked to my father in law here was his suggestion;
open the carb slowly pour an ounce of gas and turn the engine over for a few seconds, it worked and ran for a couple seconds until gas in carb was used up(his words to get everything to wake slowly wake up) do it a few more times each time adding a little more gas into the the carb.
˟˟˟˟ it worked! Right on I'll try this on the landcruiser! It worked on the samurai it'll definitely work on the landcruiser. NOPE!!! The engine is turning but won't fire up. New battery, the starter is turning but won't start up.
The 87 is in great shape inside and out was well taken care of but had sat for a 5-6 years without being ran.
Any suggestions?
Old Jan 29, 2016 | 02:56 PM
donomite49's Avatar
Got spark?
Old Jan 29, 2016 | 03:02 PM
Originally Posted by donomite49
Got spark?
I don't know. I'm as green as a mechanic can come.
As I look into the carb as the vehicle is turning, I do not see a spark
Old Jan 30, 2016 | 04:47 AM
donomite49's Avatar
No, check for spark at the spark plugs.
Lay the plug on the engine to ground it, and turn the engine over, you can see better if it's dark.
Old Jan 30, 2016 | 09:08 AM
No spark
Old Jan 30, 2016 | 10:02 AM
Wire
Originally Posted by 854runnerhunter
No spark
I guess i found the issue. Damn rats
Old Jan 30, 2016 | 11:08 AM
Any advice on replacing this part? I looked up the parts and I can't seem to find where it is sold with the coil and ignitor together
Old Jan 30, 2016 | 03:23 PM
donomite49's Avatar
Can you repair the wire? Soldering and heat shrink to cover and seal is the best way to fix it.
Even a temporary fix will get you running till you can do a more permanent repair.
Got a pull a part in your area?
Old Jan 30, 2016 | 03:31 PM
I'll look into it. I live in Sacramento there must be one nearby.
As far as soldering, it may be possible, I've never done it before but I catch on quick.
Old Jan 30, 2016 | 04:00 PM
donomite49's Avatar
YouTube has videos for everything...
Old Feb 17, 2016 | 06:40 AM
StangBanger's Avatar
I know you found your problem but if your pouring gas into the carb and turning it over id be careful trying to look down into the carb. A backfire would leave your face like charcoal. Good luck getting it going.
Mason King
Dec 16, 2015 12:29 AM
ward
Dec 10, 2015 10:35 AM
KTLaw
Dec 6, 2015 03:50 AM
Warren Morris
Nov 25, 2015 03:29 AM
Jonny246
Nov 12, 2015 03:28 PM
