Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
1970 FJ40 diff question
Old May 1, 2009 | 07:11 AM
3pointsmach's Avatar
I have a stock '70 FJ40 that has self-destructed the rear diff., and need to look for a replacement. Are the front and rear diff's the same, and interchangeable? The look the same externally.
Old May 6, 2009 | 03:51 PM
FlyingLow's Avatar
Yup they are the same. Fronts are generally better because they are less used but sometimes guys want more money for them. Make sure you get the right ratio. The 410 has some numbers stamped on the outside of the ring gear that calculate out to 410, the 377 has nothing on it. Ones thicker ring gear but I can't remember which. You will most likely need a 410 but check what you have before you buy a new one. Good luck.
Old May 8, 2009 | 07:08 AM
Thanks for the info. Found one, bought it, installed it. On the road again----.
jaretstuff
Aug 4, 2015 02:08 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
