habanero's 1996 4Runner Build-Up Thread
As it was when I bought it in 05
Things were totally worn out. Knew it was time to do something when I put camp showers in the rack, went to jump off the tire I'd stood on to reach and realized my feet were lightly trapped between the body and tire! Granted, there was a lot of weight in/on it, but Doh!
So this is as it currently sits, dirty unwashed little heathen that it is.....
Sonoran Steel System 1.2 lift
Michelin A/T LT285/75r16
And so it begins.
2012:
bye bye bumper gap....
2014
2015
2018
2022
And so it begins.
2012:
2014
2015
2018
2022
The following 2 users liked this post by habanero:
4runningg (07-09-2019),
75w90mantraN (05-18-2020)
Table of contents
Cool part-number web-site:https://toyota-usa.epc-data.com/4run...l/2818/engine/
A vague table of contents of stuff I've done and posted about so I can find it when I need to....updated to pg Page 220 , post 4384 currently.....latest vacation pics 2022
Accelerator Cable replacement 3770-3771 https://www.yotatech.com/forums/f200.../index189.html
A/C condenser 3467-3470https://www.yotatech.com/forums/f200.../index174.html
A/C expansion valve 262, 263, 265, 266https://www.yotatech.com/forums/f200...1/index14.html
Air Bags for the rear suspension 2548https://www.yotatech.com/forums/f200.../index128.html
Air Bag musings with moderate load 2563 https://www.yotatech.com/forums/f200.../index129.html
Air Chuck install in 4xInnovations rear bumper 3956https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index198.html
Air locker, front- Arb lines, switch, solenoid install and notes 3958-3960 https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index198.html
Air locker front Diff lock light in instrument cluster 4006 https://www.yotatech.com/forums/f200.../index201.html
Air Locker front Diff switch 4008-4011, 4015 https://www.yotatech.com/forums/f200.../index201.html
Air Vent Dust Flap post 3604https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index181.html
Alarm install 3829, 3860-3864https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index192.html
Alternator replace with newer junkyard alt with more amps and fewer miles 3288https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index165.html
Antenna, anatomy of a power antenna 2723https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index137.html
Antenna mast replacement 2719https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index137.html
Antenna internals, radio 332https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index17.html
Antenna internals in more detail 2719-2729https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index136.html
Antenna switch, radio 332https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index52.html
Antifreeze 186https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index10.html
Awning 3935https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index197.html
Awning by the Bus Depot 2840https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index142.html
Axle, rear e-locker equipped retrofit 1655, 1756, 1794https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index88.html
Axle shaft, rear, bearing play 2621, 2627, 2631https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index132.html
Axle shaft showing gap between parts 2594https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index130.html
Back-up lights-auxiliary 271, 274, 276. 278https://www.yotatech.com/forums/f200...1/index14.html
Back-up light switch 2948-2849https://www.yotatech.com/forums/f200.../index148.html
Back-up light switch connector 4061 https://www.yotatech.com/forums/f200.../index205.html
Back-up light switch replace and musing 4166 https://www.yotatech.com/forums/f200.../index209.html
Balance beads 3210, how-to 3361https://www.yotatech.com/forums/f200.../index169.html
Ball joint 208, 230- 4 Lower ball joint bolts 59 ft lb and loctite, ball joint bolt 105 ft lbhttps://www.yotatech.com/forums/f200...1/index12.html
Ball joint, lower left, replaced at 218,000 miles and 286,415 milesBall joint, lower right, replaced at 230,000 miles and 278,346 miles
Bell Crank Boot 3797https://www.yotatech.com/forums/f200.../index190.html
Bike fork mount for cargo area 3209https://www.yotatech.com/forums/f200.../index161.html
Bike Fork mount for the cargo area post 3577https://www.yotatech.com/forums/f200.../index179.html
Bike rack- modified 3463https://www.yotatech.com/forums/f200.../index174.html
Blower Motor removal and cleaning 687-690, 1864https://www.yotatech.com/forums/f200...1/index35.html
Blower Motor Resistor 3887https://www.yotatech.com/forums/f200.../index195.html
Body lift 209https://www.yotatech.com/forums/f200...1/index11.html
Body mounts, poly 3262https://www.yotatech.com/forums/f200.../index164.html
Brake Check Valve 3725https://www.yotatech.com/forums/f200.../index187.html
Brakes, front- see Tundrahttps://www.yotatech.com/forums/f200...51/index2.html
Brakes, rear 355, 405https://www.yotatech.com/forums/f200...1/index18.html
Bumper gap fix 684https://www.yotatech.com/forums/f200...1/index35.html
Bumper, front, 4xInnovations 3179-3183, 3188-3189https://www.yotatech.com/forums/f200.../index159.html
Bumper, front, rearranging of sticky outy fender bits, 3188https://www.yotatech.com/forums/f200.../index160.html
Bumper, front 4xInnovations reinforcement for the 96 front frame ends 3269https://www.yotatech.com/forums/f200.../index164.html
Bumper with tire carrier, rear, 4xInnovations 2438https://www.yotatech.com/forums/f200.../index122.html
Bumper- 4x innovations tire carrier bearing and seal number picshttps://www.yotatech.com/forums/f200.../index168.html
Cargo Storage Box Comparison early vs later 3rd gen and retrofit 4291, 4294-4295 https://www.yotatech.com/forums/f200.../index215.html
CB radio 55, 57https://www.yotatech.com/forums/f200...51/index3.html
CB antenna bracket 76https://www.yotatech.com/forums/f200...51/index4.html
CB Mic holder on dash 1457https://www.yotatech.com/forums/f200...1/index73.html
Cell phone dash bracket 2919, 2928-2829https://www.yotatech.com/forums/f200.../index146.html
Center caps painted 289, 473https://www.yotatech.com/forums/f200...1/index15.html
Center Console hidden compartment upgrade 3065, 3066https://www.yotatech.com/forums/f200.../index154.html
Center Console comparison of 96 vs 99 dash center bezel 2380https://www.yotatech.com/forums/f200.../index119.html
Center Console Switch Plate 3857https://www.yotatech.com/forums/f200.../index193.html
Center Console upgrade 3842, 4313 https://www.yotatech.com/forums/f200.../index193.html
Charcoal Canister- Moo box fix 1097https://www.yotatech.com/forums/f200...1/index55.html
Charcoal Canister testing 3641, 3644https://www.yotatech.com/forums/f200.../index183.html
Climate control light 876https://www.yotatech.com/forums/f200...1/index44.html
Climate control fan switch repair 1395https://www.yotatech.com/forums/f200...1/index70.html
Clock fix 361, 4372 https://www.yotatech.com/forums/f200...1/index19.html
Clutch 236, 238, 247, 249, 267https://www.yotatech.com/forums/f200...1/index13.html
Clutch 4016-4017 https://www.yotatech.com/forums/f200.../index201.html
Clutch Hose Replacement 3797https://www.yotatech.com/forums/f200.../index190.html
Clutch master and slave 4239-4240 https://www.yotatech.com/forums/f200.../index212.html
Clutch Pedal pics w/some measuring for auto to manual pedal placement comparison 2550https://www.yotatech.com/forums/f200.../index128.html
Clutch Spring replacement with alternative spring 3897https://www.yotatech.com/forums/f200.../index195.html
Control arm, front, bushings, lower 310, 316, 855https://www.yotatech.com/forums/f200...1/index16.html
Control arm, front, bushings, upper 3366, 3390-3393https://www.yotatech.com/forums/f200.../index170.html
Control arm, rear, lower, replacement using later 3rd gen arm 2057https://www.yotatech.com/forums/f200.../index103.html
Control arm, rear lower replacement- Sonoran Steel 3790https://www.yotatech.com/forums/f200.../index190.html
Control arm, rear lower, clunk 4131-4139, 4181, 4185 https://www.yotatech.com/forums/f200.../index207.html
Control arm, rear, upper replacement 2019, 2055https://www.yotatech.com/forums/f200.../index103.html
Coolant Hoses, Small I.D. 1628, 1663, 1666https://www.yotatech.com/forums/f200...1/index84.html
Coolant recovery tank relocation 2879https://www.yotatech.com/forums/f200.../index144.html
Coolant Reservoir on air box post 3595https://www.yotatech.com/forums/f200.../index180.html
Coolant Temp Sensor 3872https://www.yotatech.com/forums/f200.../index193.html
Coolant Temp sender for gauge, in upper rad hose 1312https://www.yotatech.com/forums/f200...1/index66.html
Cowl Upgrade post 3568https://www.yotatech.com/forums/f200.../index179.html
Cruise Control issue, was stop-light fuse 3900https://www.yotatech.com/forums/f200.../index195.html
Cup Holder, front, arm spring repair 1783https://www.yotatech.com/forums/f200...1/index90.html
Cup holder Center Console repair 3843-3849https://www.yotatech.com/forums/f200.../index193.html
Cup holder, rear, repaired 386https://www.yotatech.com/forums/f200...1/index20.html
CV shafts, boot saga of Doom 151, 300, 301, 310, 354, 359, 360, 375, 377-379, 381, 383, 388, 532https://www.yotatech.com/forums/f200...1/index16.html
CV boot and shaft angle comparrison of stock 99 vs lifted 96https://www.yotatech.com/forums/f200...1/index20.html
CV reboot for manual hubbed taco cvs 2427https://www.yotatech.com/forums/f200.../index122.html
CV shaft- getting one out of a manual-hubbed truck 2489https://www.yotatech.com/forums/f200.../index125.html
CV shaft, lower ball joint, lower ball joint bolts torque numbers: CV shaft torque 174 ft lb, 4 Lower ball joint bolts 59 ft lb and loctite, ball joint bolt 105 ft lb
Dash trim piece, center, removal 361, 1551, 1555https://www.yotatech.com/forums/f200...1/index78.html
Dash trim piece, center, comparison of removal of the 96's vs the 99's- 2380https://www.yotatech.com/forums/f200.../index119.html
Diff breather, rear 355https://www.yotatech.com/forums/f200...1/index18.html
Diff, front bracket bushings 3760, 3766-3767https://www.yotatech.com/forums/f200.../index188.html
Diff, front mount detail 3768https://www.yotatech.com/forums/f200.../index189.html
Dif, front, pulling it apart 3945https://www.yotatech.com/forums/f200.../index198.html
Diff, front replacement 1815, 1822https://www.yotatech.com/forums/f200...1/index91.html
Diff, front seal 360https://www.yotatech.com/forums/f200...1/index18.html
Diff, front Vacuum Line detail 3772https://www.yotatech.com/forums/f200.../index189.html
Diff, Rear 3rd member replacement 2572, 2576, 2578, 2583-2584, 2588, 2590https://www.yotatech.com/forums/f200.../index129.html
Dimmer switch info, innards 3021https://www.yotatech.com/forums/f200.../index152.html
Dimmer info, dash re-lighting, clinometer re-anchoring 3053https://www.yotatech.com/forums/f200.../index153.html
Door Dinger (and beware, also key-in unlock) disable 1511https://www.yotatech.com/forums/f200...1/index76.html
Door Handle, outside 1469-1473https://www.yotatech.com/forums/f200...1/index74.html
Door Jamb Switch 1503-1505https://www.yotatech.com/forums/f200...1/index76.html
Door Lock Module Repair 1467-1476https://www.yotatech.com/forums/f200...1/index74.html
Door Panel removal, front 901-906https://www.yotatech.com/forums/f200...1/index46.html
Door Panel removal, rear 1463-1465https://www.yotatech.com/forums/f200...1/index73.html
Driveshaft zerks 3908https://www.yotatech.com/forums/f200.../index196.html
D-Ring Isolators and spacers 2566https://www.yotatech.com/forums/f200.../index129.html
Dual Batteries 636, 640-642https://www.yotatech.com/forums/f200...1/index32.html
Dual Battery musings 4002 https://www.yotatech.com/forums/f200.../index200.html
Dual Batteries, repair and reinforcement for cracked inner fender due to weight and wiggle and darned washboards 1953https://www.yotatech.com/forums/f200...1/index98.html
Dual Batteries, single voltmeter to read both batteries, with switch 1175https://www.yotatech.com/forums/f200...1/index59.html
E-locker actuator showing locked, unlocked 2589https://www.yotatech.com/forums/f200.../index130.html
E-Locker breather routing 2594https://www.yotatech.com/forums/f200.../index130.html
E-Locker repair 2592-2593, 2596-2599https://www.yotatech.com/forums/f200.../index130.html
E-Locker retrofit 1855, 1861, 1872-1873, 1879, 1881, 1884https://www.yotatech.com/forums/f200...1/index93.html
E-Locker switch- lighting it with dash lights 1938https://www.yotatech.com/forums/f200...1/index97.html
E-locker wiring notes without a locker ecu 1884https://www.yotatech.com/forums/f200...1/index95.html
Exhaust, cat back including new cat 1117https://www.yotatech.com/forums/f200...1/index56.html
Exhaust repair after broken tailpipe 3231https://www.yotatech.com/forums/f200.../index162.html
Extended rear diff breather part numbers 2567https://www.yotatech.com/forums/f200.../index129.html
Fan clutch pulley bracket 4090, 4097 https://www.yotatech.com/forums/f200.../index205.html
Fan Switch for blower repair 1395-1398https://www.yotatech.com/forums/f200...1/index70.html
Fluids 186,253, 3136https://www.yotatech.com/forums/f200.../index157.html
Front Sway Bar Bushing 3837https://www.yotatech.com/forums/f200.../index192.html
Fuel Door how to open from backside, requires panel removal 2246https://www.yotatech.com/forums/f200.../index113.html
Fuel Injectors 3681-3683, 3694, 3733https://www.yotatech.com/forums/f200.../index184.html
Fuel Pump 3430-3432, 3434-3437https://www.yotatech.com/forums/f200.../index172.html
Fuel sender testing 3477https://www.yotatech.com/forums/f200.../index174.html
Fuse block, auxiliary, for the House Battery 1953https://www.yotatech.com/forums/f200...1/index98.html
Fuse block, auxiliary, for the Start Battery 2676https://www.yotatech.com/forums/f200.../index134.html
Fuse block bracket 641https://www.yotatech.com/forums/f200...1/index33.html
Fuse block bracket, new block bracket 2017, 3324https://www.yotatech.com/forums/f200.../index167.html
Gas tank remove 4182-4184 https://www.yotatech.com/forums/f200.../index210.html
Gas tank skid 4250 https://www.yotatech.com/forums/f200.../index213.html
Gas tank strap 3430-3432, 3434-3437https://www.yotatech.com/forums/f200.../index172.html
Gauge add-on and cd changer into ashtray/cubby area 880, 881https://www.yotatech.com/forums/f200...1/index44.html
Gauges, aftermarket, rework gauge holder 2963, 2965 ,https://www.yotatech.com/forums/f200.../index149.html
Gauges, oil, coolant temp, voltage (2 battery), oba pressure 2396https://www.yotatech.com/forums/f200.../index120.html
Gmrs Radio 4355-4356, 4358 https://www.yotatech.com/forums/f200.../index218.html
Gmrs Radio Antenna Install 4360-4367 https://www.yotatech.com/forums/f200.../index218.html
Gmrs and CB Mic holder 4373 https://www.yotatech.com/forums/f200.../index219.html
Grill modulation 158https://www.yotatech.com/forums/f200...51/index8.html
Grill re-modulation musings 2009https://www.yotatech.com/forums/f200.../index101.html
Grill mod re-modded 2032, 2566, 3193https://www.yotatech.com/forums/f200.../index102.html
Hatch cargo door light fix 427-434https://www.yotatech.com/forums/f200...1/index22.html
Hatch glass remove/replace 4180 https://www.yotatech.com/forums/f200.../index209.html
Hatch Latch 430-433https://www.yotatech.com/forums/f200...1/index22.html
Hatch latch maintenance 4157 https://www.yotatech.com/forums/f200.../index208.html
Hatch lifts 3011https://www.yotatech.com/forums/f200.../index151.html
Hatch wiring, body to hatch 261https://www.yotatech.com/forums/f200...1/index14.html
Head Gasket 3661-3680, 3685-3692, 3695-3720, 3726-3748https://www.yotatech.com/forums/f200.../index184.html
Headlight bulb comparison 2917https://www.yotatech.com/forums/f200.../index146.html
Headlight, replace with headlights and corners out of a 99+ 2841https://www.yotatech.com/forums/f200.../index143.html
Headlight, removal, pics on changing bulb (usually done with headlight in truck, from behind, unless dual batteries are in the way) 1061-1065https://www.yotatech.com/forums/f200...1/index54.html
Headlight mount repair 3286-3287https://www.yotatech.com/forums/f200.../index165.html
Heated mirror retrofit 2636, 2639-2645, 2660https://www.yotatech.com/forums/f200.../index132.html
Heater Control valve 3101https://www.yotatech.com/forums/f200...l#post52359228
Heater core o-rings and hvac refresh 4209, 4215, 4217-4220 https://www.yotatech.com/forums/f200.../index211.html
Heater hoses 1666https://www.yotatech.com/forums/f200...1/index84.html
Heater, Rear retrofit 4291, 4341-4345 https://www.yotatech.com/forums/f200.../index218.html
Highbeam Indicator light dimming 3920https://www.yotatech.com/forums/f200.../index196.html
Hitch flipped. One of my first mods so it's not in here. You need a hitch with a bolt-on end to do it.Hitch, front by Warn 1103https://www.yotatech.com/forums/f200...1/index56.html
Hood Cushions, hood support grommet 2297https://www.yotatech.com/forums/f200.../index115.html
Hood light 2199, 2216, 2258https://www.yotatech.com/forums/f200.../index111.html
Hood snort insert bolt and 1 screw placement 4000 https://www.yotatech.com/forums/f200.../index200.html
Horns 102, 106, 115, 575https://www.yotatech.com/forums/f200...51/index6.html
Horns out of an 01 Tundra this time 4001 https://www.yotatech.com/forums/f200.../index200.html
Horn wiring diagram 2792https://www.yotatech.com/forums/f200.../index140.html
Horn, cracked support reinforcement w/heavier GM horn 2566https://www.yotatech.com/forums/f200.../index129.html
Hvac vent repair 3769https://www.yotatech.com/forums/f200.../index189.html
IAC opened and TB butterfly pic 785https://www.yotatech.com/forums/f200...1/index40.html
IAC removal and cleaning 3133-3135https://www.yotatech.com/forums/f200.../index157.html
Ignition coil replaced with junkyard coils out of newer truck 3323https://www.yotatech.com/forums/f200.../index167.html
Ignition Cylinder lighted surround 1871https://www.yotatech.com/forums/f200...1/index94.html
Ignition Coil re-boot 3795https://www.yotatech.com/forums/f200.../index190.html
Inclinometer installed 2745https://www.yotatech.com/forums/f200.../index138.html
Intake hose repair with rescue tape 3755https://www.yotatech.com/forums/f200.../index188.html
Intake Manifold coolant and vacuum lines and part numbers 3720-3724https://www.yotatech.com/forums/f200.../index186.html
Instrument Cluster cleaning 1850https://www.yotatech.com/forums/f200...1/index93.html
Instrument Cluster removal how-to 3607-3608https://www.yotatech.com/forums/f200.../index181.html
Instrument Cluster Trip Odometer replacement 1854https://www.yotatech.com/forums/f200...1/index93.html
Interior lighting color change:1) instrument cluster 2903, 2905, 2908, 2913-2915https://www.yotatech.com/forums/f200.../index146.html
ISR delete for later 3rd gens 3819https://www.yotatech.com/forums/f200.../index191.html
Knock sensors 2832-283Later 3rd gen3https://www.yotatech.com/forums/f200.../index142.html
License Plate light 3836https://www.yotatech.com/forums/f200.../index192.html
Lighter surround 3039https://www.yotatech.com/forums/f200.../index152.html
Land Cruiser Wheels 158https://www.yotatech.com/forums/f200...51/index8.html
Lighter surround bulb repair 3030, 3040-3042https://www.yotatech.com/forums/f200.../index152.html
Lights, light bar, wiring through the roof 220, 263, 274, 276https://www.yotatech.com/forums/f200...1/index14.html
Light bar redone 2017, 3332https://www.yotatech.com/forums/f200.../index167.html
MAF cleaned 300https://www.yotatech.com/forums/f200...1/index15.html
MAF test procedure and wiring schematic for the 96 778https://www.yotatech.com/forums/f200...1/index39.html
MAF mod, replace old with a maf and intake with one from a 99+ junkyard truck 3326-3329https://www.yotatech.com/forums/f200.../index167.html
Manual hub re-grease 2305https://www.yotatech.com/forums/f200.../index116.html
Manual Hub re-seal and grease 3888-3893https://www.yotatech.com/forums/f200.../index195.html
Manual hubs retrofit 1837, 1841https://www.yotatech.com/forums/f200...1/index92.html
Manual Hubs- getting the ABS back and replacing bearings w/drama 2458, 2461,2465, 2468, 2472, 2474, 2479-2480, 2482, 2486, 2488-2490https://www.yotatech.com/forums/f200.../index124.html
Mounts, motor replace 3275-3279https://www.yotatech.com/forums/f200.../index164.html
Mount, transmission replace 3143https://www.yotatech.com/forums/f200.../index158.html
Mud flaps 180, 183, 189, 583https://www.yotatech.com/forums/f200...1/index10.html
Oil Analysis from Blackstone 2791https://www.yotatech.com/forums/f200.../index140.html
Oil Cap gasket 3734https://www.yotatech.com/forums/f200.../index187.html
Oil Cooler 3693https://www.yotatech.com/forums/f200.../index185.html
Oil Dipstick Tube O-Ring replacement 1746-1748https://www.yotatech.com/forums/f200...1/index88.html
Oil Dipstick- measurement: how far it extends below the tube 1749https://www.yotatech.com/forums/f200...1/index88.html
OIl Pan EZ Valve 4378 https://www.yotatech.com/forums/f200.../index219.html
Oil Pan seal 3942-3944https://www.yotatech.com/forums/f200.../index198.html
On Board Air- 2247, 2259-2260, 2345, 2356, 2360, 2365, 2386, 2388-89, 2396https://www.yotatech.com/forums/f200.../index113.html
On-board air connector mounting plate 2777https://www.yotatech.com/forums/f200.../index139.html
On-board air venting and muffin fans cooling 4304, 4312 https://www.yotatech.com/forums/f200.../index216.html
Outlet on back of console 2662https://www.yotatech.com/forums/f200.../index134.html
Panel removal points, panel over the front seat belt 2676https://www.yotatech.com/forums/f200.../index134.html
Parking Brake Cable replacement1369-1379https://www.yotatech.com/forums/f200...1/index69.html
PCV hose 3787https://www.yotatech.com/forums/f200.../index190.html
Phone cradle, 2919-2929https://www.yotatech.com/forums/f200.../index146.html
Plug wires 300https://www.yotatech.com/forums/f200...1/index15.html
Power outlet on rear of center console 2662https://www.yotatech.com/forums/f200.../index134.html
Power outlet in rear cargo area 2809-2814https://www.yotatech.com/forums/f200.../index141.html
Power outlet in rear upper cargo area 3338https://www.yotatech.com/forums/f200.../index167.html
Power outlet in front under right side dash 3340https://www.yotatech.com/forums/f200.../index167.html
Power Steering Filter tear-down 3168https://www.yotatech.com/forums/f200.../index159.html
Power Steering pump guts 2303https://www.yotatech.com/forums/f200.../index116.html
Power steering rack boot replace 1836https://www.yotatech.com/forums/f200...1/index92.html
Power steering rack bushings 488, 517, 2272, 2279https://www.yotatech.com/forums/f200.../index114.html
Power steering rack and pinion 260, 2100https://www.yotatech.com/forums/f200.../index105.html
Power steering rack and pinion AGAIN 2056, 2069, 2076-2077, 2100-2102https://www.yotatech.com/forums/f200.../index104.html
Rear Driveshaft bolts/studs notes 3819https://www.yotatech.com/forums/f200.../index191.html
Roof Rack Baja ¾ length 3926https://www.yotatech.com/forums/f200.../index197.html
Roof rack changing out load bars and close up where wires pass through roof 989https://www.yotatech.com/forums/f200...1/index50.html
Roof rack storage for awning poles 4197 https://www.yotatech.com/forums/f200.../index210.html
Roof without headliner 3414https://www.yotatech.com/forums/f200.../index171.html
Seats, front, replaced with Mazda seats and raised 1" 220, 223, 225, 227https://www.yotatech.com/forums/f200...1/index11.html
Seat bolt nut common problem and how I repaired the driver's side 3317https://www.yotatech.com/forums/f200.../index166.html
Seats, rear, replaced with better oe seats out of newer 3rd gen 2674https://www.yotatech.com/forums/f200.../index134.html
Seat Belts, rear 1787https://www.yotatech.com/forums/f200...1/index90.html
Seat Belt, Driver's front 3114, 3116https://www.yotatech.com/forums/f200.../index156.html
Shifter Boot replacement with newer 3rd gen boot 3813https://www.yotatech.com/forums/f200.../index191.html
Shifter seat bushings, transmission and transfer shifters 2953, 2965https://www.yotatech.com/forums/f200.../index148.html
Shifter shaft gasket clearance after engine mounts 3308https://www.yotatech.com/forums/f200.../index166.html
Skid plate, aftermarket, removal 455 621https://www.yotatech.com/forums/f200...1/index23.html
Sliders, Shrockworks 657https://www.yotatech.com/forums/f200...1/index32.html
Slider length w/pics 1843https://www.yotatech.com/forums/f200...1/index93.html
Snorkel 3507, 3519-3531https://www.yotatech.com/forums/f200.../index177.html
Snorkel Extension 3744https://www.yotatech.com/forums/f200.../index188.html
Spare Tire Fit 31" stock size vs 33" w/pics 2382-83https://www.yotatech.com/forums/f200.../index120.html
Spark plug pictorial 2167https://www.yotatech.com/forums/f200.../index109.html
Speaker replacement 4012-4014 https://www.yotatech.com/forums/f200.../index201.html
Speed Bleeders for brakes 3801https://www.yotatech.com/forums/f200.../index191.html
Speedometer working with speed sensor in transfer case 1934-1936https://www.yotatech.com/forums/f200...1/index97.html
Speed sender out of a Tacoma notes 3144https://www.yotatech.com/forums/f200.../index158.html
Speed sender (VSS) note 4163 https://www.yotatech.com/forums/f200.../index209.html
Starter Contacts, Plunger, really nice work and writeup by Hrt4me 1609https://www.yotatech.com/forums/f200...1/index81.html
Starter Contacts, Plunger, comparison and junkhttps://www.yotatech.com/forums/f200.../index176.html
Steering rack bushings 517, 2279https://www.yotatech.com/forums/f200.../index114.html
Steering rack guide, link to Yukon's thread, musings 1289https://www.yotatech.com/forums/f200...1/index65.html
Steering rack guide, tightening 3550https://www.yotatech.com/forums/f200.../index178.html
Steering shaft pivot and firewall seal 4101,4103, 4105, 4208https://www.yotatech.com/forums/f200.../index211.html
Steering Wheel cover, Wheelskins 3197https://www.yotatech.com/forums/f200.../index160.html
Sunroof cable replacement for stuck cables 4261, 4266-4272 https://www.yotatech.com/forums/f200.../index214.html
Sunroof drain extension 3299-3301https://www.yotatech.com/forums/f200.../index165.html
Sway bar link, front replace with 2nd gen rear links, comparison 1860https://www.yotatech.com/forums/f200...1/index93.html
Sway bar link, rear, replace with 3rd gen front links, 1" longerSway bar bushing, 26mm, damage to poly bushing during wheeling trip 2007https://www.yotatech.com/forums/f200.../index101.html
Switch bulb replacement, hazard and defrost, 1784https://www.yotatech.com/forums/f200...1/index90.html
Taco Box and quadruple sticks 4021-4035 https://www.yotatech.com/forums/f200.../index201.html
Taco Box install write-up for m/t using Marlin’s directions 4037-4039 4042-4043 https://www.yotatech.com/forums/f200.../index202.html
Taco Box transmission coupler stuff, shifter housing note 4112,4116 https://www.yotatech.com/forums/f200.../index206.html
Taco Box triple stick write-up (quadruple because manual trans) 4040-4041, 4043-4045 https://www.yotatech.com/forums/f200.../index202.html
Thermostat new to 21 year old comparrison, 3101https://www.yotatech.com/forums/f200.../index156.html
Throttle body replaced with junkyard TB 3124https://www.yotatech.com/forums/f200.../index157.html
Throttle position sensor replacement 3132https://www.yotatech.com/forums/f200.../index157.html
Through panel connector for start battery fuse block 3307https://www.yotatech.com/forums/f200.../index166.html
Tie rod ends, inner and outer 260https://www.yotatech.com/forums/f200...1/index13.html
Timing belt notes and junk 3097- 3107, 3115https://www.yotatech.com/forums/f200.../index155.html
Timing belt tensioner tool use notes 3103https://www.yotatech.com/forums/f200.../index156.html
Tires, BFG All Terrain T/A KO pic 1893https://www.yotatech.com/forums/f200...1/index95.html
Tires, BFG All Terrain T/A KO2 bottom pic in post 1Tires, Michelin AT2 musings 325https://www.yotatech.com/forums/f200...1/index17.html
Trim retainer part numbers 3271https://www.yotatech.com/forums/f200.../index164.html
Trip Odometer replacement 1854, 3092https://www.yotatech.com/forums/f200...1/index93.html
Tundra front brakes 21, 27, 256, 339-brake pads 4137https://www.yotatech.com/forums/f200...51/index2.html
Turn signals, front at marker light location 499, 502, 511, 514https://www.yotatech.com/forums/f200...1/index25.html
Turn Signals, Side 467, 471, 656, 659, 661, 662, 665, 666https://www.yotatech.com/forums/f200...1/index33.html
Turn signals, front, reflective paint redone 445https://www.yotatech.com/forums/f200...1/index23.html
Ujoint, rear 933https://www.yotatech.com/forums/f200...1/index47.html
Underhood water drain 3309https://www.yotatech.com/forums/f200.../index166.html
Usb port where lighter socket was 4302-4303 https://www.yotatech.com/forums/f200.../index216.html
Vacation 2010, 195-https://www.yotatech.com/forums/f200...1/index10.html
Vacation 2011, 293https://www.yotatech.com/forums/f200...1/index15.html
Vacation 2012, 737https://www.yotatech.com/forums/f200...1/index37.html
Vacation 2013, 1327https://www.yotatech.com/forums/f200...1/index67.html
Vacation 2014, 1975https://www.yotatech.com/forums/f200...1/index99.html
Vacation 2015, 2497https://www.yotatech.com/forums/f200.../index125.html
Vacation 2016, 2849https://www.yotatech.com/forums/f200.../index143.html
Vacation 2017 spring break, 3073https://www.yotatech.com/forums/f200.../index154.html
Vacation 2017 3224https://www.yotatech.com/forums/f200.../index162.html
Vacation 2018 CO/UT 3593-3594, 3622, 3624-3632https://www.yotatech.com/forums/f200.../index180.html
Vacation summer 2020 3963-3989https://www.yotatech.com/forums/f200.../index199.html
Vacation Summer 2022 4377, 4379-4384 https://www.yotatech.com/forums/f200.../index219.html
Valve cover bolt grommet replacement Yotashop and Toyota dealership supplied parts comparison 3958https://www.yotatech.com/forums/f200...ispreloading=1
Valve cover gaskets, clearances 2816-2831https://www.yotatech.com/forums/f200.../index141.html
Valve cover parts list 2835https://www.yotatech.com/forums/f200.../index142.html
Visor, sun, modded Ford Taurus replacement 1894, 1909-1912https://www.yotatech.com/forums/f200...1/index96.html
Visor upgrade 3858https://www.yotatech.com/forums/f200.../index193.html
Voltmeter for dual batteries, single gauge 1175https://www.yotatech.com/forums/f200...1/index59.html
Washer nozzles, 2 stream to 3 stream 2650https://www.yotatech.com/forums/f200.../index133.html
Washer tank mod and chuckles89's version too 3474-3476, 3498-3503https://www.yotatech.com/forums/f200.../index174.html
Wheel bearing, rear, symptoms, bearing musings, info and stuffhttps://www.yotatech.com/forums/f200.../index173.html
Wheel bearing, rear 4053, 4060 https://www.yotatech.com/forums/f200.../index203.html
Windshield washer tank removal and washer pump pics 1711-1715https://www.yotatech.com/forums/f200...1/index86.html
Winch hook holder mod 3543https://www.yotatech.com/forums/f200.../index178.html
Winch stuffed into a 4xInnovations front bumper built for 1" body lift 3471-3473, 3480-3481, 3484, 3492https://www.yotatech.com/forums/f200.../index174.html
Winch power cables front and rear with anderson connectors 2744, 2787https://www.yotatech.com/forums/f200.../index140.html
Winch power cable anderson connectors, getting Ruff Stuff connectors to work with Warn connectors 2839https://www.yotatech.com/forums/f200.../index142.html
Windshield, just for note, didn't put it in 2848https://www.yotatech.com/forums/f200.../index143.html
photoleif (05-11-2021)
Awww. Thanks guys!
Thule playpen clamps to the rack and locks on. It's a little tall, but the price was sweet ($125 barely used) so I can't complain and I know the camp showers won't flop out.
I wish I could do a front receiver bumper, rear w/receiver and spare carrier maybe. That's not going to happen anytime in the near future.
I've got all the necessaries for the tundra brakes sitting here on the floor (doing that tomorrow, I think) and am thinking a cb might be a handy little gadget, or at least fun.
More recovery gear next. Better skid(s) and then sliders would have to be after that but I've pretty much spent all my dough so I'll have to wait until I make more. Considering that moderate trails is the worst I've done and I don't get to do them all that much I have time.
It's been a very slow process!
Hab so glad to see this thread. If you make it out to Colorado next year LET US KNOW. You pay for the steel and we can fab up whatever you need, prolly in a weekend with all the help we could get!
Subscribed!!
Subscribed!!
Thanks so much, Molly!. I'll try to remember to holler when we head out there again. I'm not sure it'd be safe to drive past your door again without saying hello at least.
We don't stay in one place more than a day or two and I'm too slow on the tandem to be fun to mtn bike with but wouldn't mind doing a little driving or hiking.
A little lift wheel well before and after, with empty cargo area....
Front before: 35"
Front after: 39.5"
Rear before: 34.5
Rear after: 39.5"
Those pics are with the 265/70r16 so add another inch to the height.
Front before: 35"
Front after: 39.5"
Rear before: 34.5
Rear after: 39.5"
92 Toy's right, it is getting bigger!
are these old shots or is this something you are doing now?
did the rear sag? was that still a problem with that year or was it just loaded down in that one pic?
the 265's make a big difference. my brother in law has a 4runner i believe a 98? minus the running boards and has 265's on it and it looks perfectly proportioned.
BTW...what does "system 1.2 covered in flu germs mean"? was that a dealer option?
Did this in early November 09
Yes on the rear sag. It wasn't too noticeable until stuff went in the back....and I carry a lot of stuff. In the middle pic it was seriously loaded down and had about 120# of bike and rack hanging off the back as well. Toyota did a recall on the rear springs some time ago, the previous owner had them done according to Toyota but that was over 100,000 miles ago. The truck currently has 206,331 miles on it.
Mine came with 265's and now has 285's (last pic in first post). I agree, the 265's without the lift looked good to me. At first the 285's looked a little large, but I got used to them.
It means I watch little kids for a living and they share so I had the flu when I was installing the Sonoran Steel 1.2 lift. Can't stand laying around in bed, not at all.
Looks good Hab.
Btw Happy Birthday a few days ago... I was going to post a special thread about it with a cake and all but I got busy and missed the day.
Best wishes and many more in any case.
My birthday was a few days ago? Mmmmm, cake. You've not missed it so now I'm expecting cake in just under 3 weeks!
I must've done somethin' wrong, but I think I fixed it.
If I've not missed it then a cake you shall have...
Those rear coils on those runners are so well known for giving the 2nd gen a saggy ass.
And yes you do have to say hello. I am UBER slow on my mountain bike so I wouldn't mind taking it slow. Troy and I have talked a lot about a tandem. Would love to hear more about how you guys like yours.
And when IS your birthday I just made troy a chocolate pound cake, to get us through his week of freezing cold wrenching and measuring we gotta do to finish Ron!
You'll get a kick out of this web site for sure! http://cakewrecks.blogspot.com/
