habanero |
01-18-2010 08:52 AM |
Table of contents
Cool part-number web-site:https://toyota-usa.epc-data.com/4run...l/2818/engine/
A vague table of contents of stuff I've done and posted about so I can find it when I need to....updated to pg Page 220 , post 4384 currently.....latest vacation pics 2022
Accelerator Cable replacement 3770-3771 https://www.yotatech.com/forums/f200.../index189.html
A/C condenser 3467-3470https://www.yotatech.com/forums/f200.../index174.html
A/C expansion valve 262, 263, 265, 266https://www.yotatech.com/forums/f200...1/index14.html
Air Bags for the rear suspension 2548https://www.yotatech.com/forums/f200.../index128.html
Air Bag musings with moderate load 2563 https://www.yotatech.com/forums/f200.../index129.html
Air Chuck install in 4xInnovations rear bumper 3956https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index198.html
Air locker, front- Arb lines, switch, solenoid install and notes 3958-3960 https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index198.html
Air locker front Diff lock light in instrument cluster 4006 https://www.yotatech.com/forums/f200.../index201.html
Air Locker front Diff switch 4008-4011, 4015 https://www.yotatech.com/forums/f200.../index201.html
Air Vent Dust Flap post 3604https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index181.html
Alarm install 3829, 3860-3864https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index192.html
Alternator replace with newer junkyard alt with more amps and fewer miles 3288https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index165.html
Antenna, anatomy of a power antenna 2723https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index137.html
Antenna mast replacement 2719https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index137.html
Antenna internals, radio 332https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index17.html
Antenna internals in more detail 2719-2729https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index136.html
Antenna switch, radio 332https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index52.html
Antifreeze 186https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index10.html
Awning 3935https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index197.html
Awning by the Bus Depot 2840https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index142.html
Axle, rear e-locker equipped retrofit 1655, 1756, 1794https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index88.html
Axle shaft, rear, bearing play 2621, 2627, 2631https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index132.html
Axle shaft showing gap between parts 2594https://www.yotatech.com/forums/f200/habaneros-1996-4runner-build-up-thread-201751/index130.html
Back-up lights-auxiliary 271, 274, 276. 278https://www.yotatech.com/forums/f200...1/index14.html
Back-up light switch 2948-2849https://www.yotatech.com/forums/f200.../index148.html
Back-up light switch connector 4061 https://www.yotatech.com/forums/f200.../index205.html
Back-up light switch replace and musing 4166 https://www.yotatech.com/forums/f200.../index209.html
Balance beads 3210, how-to 3361https://www.yotatech.com/forums/f200.../index169.html
Ball joint 208, 230- 4 Lower ball joint bolts 59 ft lb and loctite, ball joint bolt 105 ft lbhttps://www.yotatech.com/forums/f200...1/index12.html
Ball joint, lower left, replaced at 218,000 miles and 286,415 milesBall joint, lower right, replaced at 230,000 miles and 278,346 miles
Bell Crank Boot 3797https://www.yotatech.com/forums/f200.../index190.html
Bike fork mount for cargo area 3209https://www.yotatech.com/forums/f200.../index161.html
Bike Fork mount for the cargo area post 3577https://www.yotatech.com/forums/f200.../index179.html
Bike rack- modified 3463https://www.yotatech.com/forums/f200.../index174.html
Blower Motor removal and cleaning 687-690, 1864https://www.yotatech.com/forums/f200...1/index35.html
Blower Motor Resistor 3887https://www.yotatech.com/forums/f200.../index195.html
Body lift 209https://www.yotatech.com/forums/f200...1/index11.html
Body mounts, poly 3262https://www.yotatech.com/forums/f200.../index164.html
Brake Check Valve 3725https://www.yotatech.com/forums/f200.../index187.html
Brakes, front- see Tundrahttps://www.yotatech.com/forums/f200...51/index2.html
Brakes, rear 355, 405https://www.yotatech.com/forums/f200...1/index18.html
Bumper gap fix 684https://www.yotatech.com/forums/f200...1/index35.html
Bumper, front, 4xInnovations 3179-3183, 3188-3189https://www.yotatech.com/forums/f200.../index159.html
Bumper, front, rearranging of sticky outy fender bits, 3188https://www.yotatech.com/forums/f200.../index160.html
Bumper, front 4xInnovations reinforcement for the 96 front frame ends 3269https://www.yotatech.com/forums/f200.../index164.html
Bumper with tire carrier, rear, 4xInnovations 2438https://www.yotatech.com/forums/f200.../index122.html
Bumper- 4x innovations tire carrier bearing and seal number picshttps://www.yotatech.com/forums/f200.../index168.html
Cargo Storage Box Comparison early vs later 3rd gen and retrofit 4291, 4294-4295 https://www.yotatech.com/forums/f200.../index215.html
CB radio 55, 57https://www.yotatech.com/forums/f200...51/index3.html
CB antenna bracket 76https://www.yotatech.com/forums/f200...51/index4.html
CB Mic holder on dash 1457https://www.yotatech.com/forums/f200...1/index73.html
Cell phone dash bracket 2919, 2928-2829https://www.yotatech.com/forums/f200.../index146.html
Center caps painted 289, 473https://www.yotatech.com/forums/f200...1/index15.html
Center Console hidden compartment upgrade 3065, 3066https://www.yotatech.com/forums/f200.../index154.html
Center Console comparison of 96 vs 99 dash center bezel 2380https://www.yotatech.com/forums/f200.../index119.html
Center Console Switch Plate 3857https://www.yotatech.com/forums/f200.../index193.html
Center Console upgrade 3842, 4313 https://www.yotatech.com/forums/f200.../index193.html
Charcoal Canister- Moo box fix 1097https://www.yotatech.com/forums/f200...1/index55.html
Charcoal Canister testing 3641, 3644https://www.yotatech.com/forums/f200.../index183.html
Climate control light 876https://www.yotatech.com/forums/f200...1/index44.html
Climate control fan switch repair 1395https://www.yotatech.com/forums/f200...1/index70.html
Clock fix 361, 4372 https://www.yotatech.com/forums/f200...1/index19.html
Clutch 236, 238, 247, 249, 267https://www.yotatech.com/forums/f200...1/index13.html
Clutch 4016-4017 https://www.yotatech.com/forums/f200.../index201.html
Clutch Hose Replacement 3797https://www.yotatech.com/forums/f200.../index190.html
Clutch master and slave 4239-4240 https://www.yotatech.com/forums/f200.../index212.html
Clutch Pedal pics w/some measuring for auto to manual pedal placement comparison 2550https://www.yotatech.com/forums/f200.../index128.html
Clutch Spring replacement with alternative spring 3897https://www.yotatech.com/forums/f200.../index195.html
Control arm, front, bushings, lower 310, 316, 855https://www.yotatech.com/forums/f200...1/index16.html
Control arm, front, bushings, upper 3366, 3390-3393https://www.yotatech.com/forums/f200.../index170.html
Control arm, rear, lower, replacement using later 3rd gen arm 2057https://www.yotatech.com/forums/f200.../index103.html
Control arm, rear lower replacement- Sonoran Steel 3790https://www.yotatech.com/forums/f200.../index190.html
Control arm, rear lower, clunk 4131-4139, 4181, 4185 https://www.yotatech.com/forums/f200.../index207.html
Control arm, rear, upper replacement 2019, 2055https://www.yotatech.com/forums/f200.../index103.html
Coolant Hoses, Small I.D. 1628, 1663, 1666https://www.yotatech.com/forums/f200...1/index84.html
Coolant recovery tank relocation 2879https://www.yotatech.com/forums/f200.../index144.html
Coolant Reservoir on air box post 3595https://www.yotatech.com/forums/f200.../index180.html
Coolant Temp Sensor 3872https://www.yotatech.com/forums/f200.../index193.html
Coolant Temp sender for gauge, in upper rad hose 1312https://www.yotatech.com/forums/f200...1/index66.html
Cowl Upgrade post 3568https://www.yotatech.com/forums/f200.../index179.html
Cruise Control issue, was stop-light fuse 3900https://www.yotatech.com/forums/f200.../index195.html
Cup Holder, front, arm spring repair 1783https://www.yotatech.com/forums/f200...1/index90.html
Cup holder Center Console repair 3843-3849https://www.yotatech.com/forums/f200.../index193.html
Cup holder, rear, repaired 386https://www.yotatech.com/forums/f200...1/index20.html
CV shafts, boot saga of Doom 151, 300, 301, 310, 354, 359, 360, 375, 377-379, 381, 383, 388, 532https://www.yotatech.com/forums/f200...1/index16.html
CV boot and shaft angle comparrison of stock 99 vs lifted 96https://www.yotatech.com/forums/f200...1/index20.html
CV reboot for manual hubbed taco cvs 2427https://www.yotatech.com/forums/f200.../index122.html
CV shaft- getting one out of a manual-hubbed truck 2489https://www.yotatech.com/forums/f200.../index125.html
CV shaft, lower ball joint, lower ball joint bolts torque numbers: CV shaft torque 174 ft lb, 4 Lower ball joint bolts 59 ft lb and loctite, ball joint bolt 105 ft lb
Dash trim piece, center, removal 361, 1551, 1555https://www.yotatech.com/forums/f200...1/index78.html
Dash trim piece, center, comparison of removal of the 96's vs the 99's- 2380https://www.yotatech.com/forums/f200.../index119.html
Diff breather, rear 355https://www.yotatech.com/forums/f200...1/index18.html
Diff, front bracket bushings 3760, 3766-3767https://www.yotatech.com/forums/f200.../index188.html
Diff, front mount detail 3768https://www.yotatech.com/forums/f200.../index189.html
Dif, front, pulling it apart 3945https://www.yotatech.com/forums/f200.../index198.html
Diff, front replacement 1815, 1822https://www.yotatech.com/forums/f200...1/index91.html
Diff, front seal 360https://www.yotatech.com/forums/f200...1/index18.html
Diff, front Vacuum Line detail 3772https://www.yotatech.com/forums/f200.../index189.html
Diff, Rear 3rd member replacement 2572, 2576, 2578, 2583-2584, 2588, 2590https://www.yotatech.com/forums/f200.../index129.html
Dimmer switch info, innards 3021https://www.yotatech.com/forums/f200.../index152.html
Dimmer info, dash re-lighting, clinometer re-anchoring 3053https://www.yotatech.com/forums/f200.../index153.html
Door Dinger (and beware, also key-in unlock) disable 1511https://www.yotatech.com/forums/f200...1/index76.html
Door Handle, outside 1469-1473https://www.yotatech.com/forums/f200...1/index74.html
Door Jamb Switch 1503-1505https://www.yotatech.com/forums/f200...1/index76.html
Door Lock Module Repair 1467-1476https://www.yotatech.com/forums/f200...1/index74.html
Door Panel removal, front 901-906https://www.yotatech.com/forums/f200...1/index46.html
Door Panel removal, rear 1463-1465https://www.yotatech.com/forums/f200...1/index73.html
Driveshaft zerks 3908https://www.yotatech.com/forums/f200.../index196.html
D-Ring Isolators and spacers 2566https://www.yotatech.com/forums/f200.../index129.html
Dual Batteries 636, 640-642https://www.yotatech.com/forums/f200...1/index32.html
Dual Battery musings 4002 https://www.yotatech.com/forums/f200.../index200.html
Dual Batteries, repair and reinforcement for cracked inner fender due to weight and wiggle and darned washboards 1953https://www.yotatech.com/forums/f200...1/index98.html
Dual Batteries, single voltmeter to read both batteries, with switch 1175https://www.yotatech.com/forums/f200...1/index59.html
E-locker actuator showing locked, unlocked 2589https://www.yotatech.com/forums/f200.../index130.html
E-Locker breather routing 2594https://www.yotatech.com/forums/f200.../index130.html
E-Locker repair 2592-2593, 2596-2599https://www.yotatech.com/forums/f200.../index130.html
E-Locker retrofit 1855, 1861, 1872-1873, 1879, 1881, 1884https://www.yotatech.com/forums/f200...1/index93.html
E-Locker switch- lighting it with dash lights 1938https://www.yotatech.com/forums/f200...1/index97.html
E-locker wiring notes without a locker ecu 1884https://www.yotatech.com/forums/f200...1/index95.html
Exhaust, cat back including new cat 1117https://www.yotatech.com/forums/f200...1/index56.html
Exhaust repair after broken tailpipe 3231https://www.yotatech.com/forums/f200.../index162.html
Extended rear diff breather part numbers 2567https://www.yotatech.com/forums/f200.../index129.html
Fan clutch pulley bracket 4090, 4097 https://www.yotatech.com/forums/f200.../index205.html
Fan Switch for blower repair 1395-1398https://www.yotatech.com/forums/f200...1/index70.html
Fluids 186,253, 3136https://www.yotatech.com/forums/f200.../index157.html
Front Sway Bar Bushing 3837https://www.yotatech.com/forums/f200.../index192.html
Fuel Door how to open from backside, requires panel removal 2246https://www.yotatech.com/forums/f200.../index113.html
Fuel Injectors 3681-3683, 3694, 3733https://www.yotatech.com/forums/f200.../index184.html
Fuel Pump 3430-3432, 3434-3437https://www.yotatech.com/forums/f200.../index172.html
Fuel sender testing 3477https://www.yotatech.com/forums/f200.../index174.html
Fuse block, auxiliary, for the House Battery 1953https://www.yotatech.com/forums/f200...1/index98.html
Fuse block, auxiliary, for the Start Battery 2676https://www.yotatech.com/forums/f200.../index134.html
Fuse block bracket 641https://www.yotatech.com/forums/f200...1/index33.html
Fuse block bracket, new block bracket 2017, 3324https://www.yotatech.com/forums/f200.../index167.html
Gas tank remove 4182-4184 https://www.yotatech.com/forums/f200.../index210.html
Gas tank skid 4250 https://www.yotatech.com/forums/f200.../index213.html
Gas tank strap 3430-3432, 3434-3437https://www.yotatech.com/forums/f200.../index172.html
Gauge add-on and cd changer into ashtray/cubby area 880, 881https://www.yotatech.com/forums/f200...1/index44.html
Gauges, aftermarket, rework gauge holder 2963, 2965 ,https://www.yotatech.com/forums/f200.../index149.html
Gauges, oil, coolant temp, voltage (2 battery), oba pressure 2396https://www.yotatech.com/forums/f200.../index120.html
Gmrs Radio 4355-4356, 4358 https://www.yotatech.com/forums/f200.../index218.html
Gmrs Radio Antenna Install 4360-4367 https://www.yotatech.com/forums/f200.../index218.html
Gmrs and CB Mic holder 4373 https://www.yotatech.com/forums/f200.../index219.html
Grill modulation 158https://www.yotatech.com/forums/f200...51/index8.html
Grill re-modulation musings 2009https://www.yotatech.com/forums/f200.../index101.html
Grill mod re-modded 2032, 2566, 3193https://www.yotatech.com/forums/f200.../index102.html
Hatch cargo door light fix 427-434https://www.yotatech.com/forums/f200...1/index22.html
Hatch glass remove/replace 4180 https://www.yotatech.com/forums/f200.../index209.html
Hatch Latch 430-433https://www.yotatech.com/forums/f200...1/index22.html
Hatch latch maintenance 4157 https://www.yotatech.com/forums/f200.../index208.html
Hatch lifts 3011https://www.yotatech.com/forums/f200.../index151.html
Hatch wiring, body to hatch 261https://www.yotatech.com/forums/f200...1/index14.html
Head Gasket 3661-3680, 3685-3692, 3695-3720, 3726-3748https://www.yotatech.com/forums/f200.../index184.html
Headlight bulb comparison 2917https://www.yotatech.com/forums/f200.../index146.html
Headlight, replace with headlights and corners out of a 99+ 2841https://www.yotatech.com/forums/f200.../index143.html
Headlight, removal, pics on changing bulb (usually done with headlight in truck, from behind, unless dual batteries are in the way) 1061-1065https://www.yotatech.com/forums/f200...1/index54.html
Headlight mount repair 3286-3287https://www.yotatech.com/forums/f200.../index165.html
Heated mirror retrofit 2636, 2639-2645, 2660https://www.yotatech.com/forums/f200.../index132.html
Heater Control valve 3101https://www.yotatech.com/forums/f200...l#post52359228
Heater core o-rings and hvac refresh 4209, 4215, 4217-4220 https://www.yotatech.com/forums/f200.../index211.html
Heater hoses 1666https://www.yotatech.com/forums/f200...1/index84.html
Heater, Rear retrofit 4291, 4341-4345 https://www.yotatech.com/forums/f200.../index218.html
Highbeam Indicator light dimming 3920https://www.yotatech.com/forums/f200.../index196.html
Hitch flipped. One of my first mods so it's not in here. You need a hitch with a bolt-on end to do it.Hitch, front by Warn 1103https://www.yotatech.com/forums/f200...1/index56.html
Hood Cushions, hood support grommet 2297https://www.yotatech.com/forums/f200.../index115.html
Hood light 2199, 2216, 2258https://www.yotatech.com/forums/f200.../index111.html
Hood snort insert bolt and 1 screw placement 4000 https://www.yotatech.com/forums/f200.../index200.html
Horns 102, 106, 115, 575https://www.yotatech.com/forums/f200...51/index6.html
Horns out of an 01 Tundra this time 4001 https://www.yotatech.com/forums/f200.../index200.html
Horn wiring diagram 2792https://www.yotatech.com/forums/f200.../index140.html
Horn, cracked support reinforcement w/heavier GM horn 2566https://www.yotatech.com/forums/f200.../index129.html
Hvac vent repair 3769https://www.yotatech.com/forums/f200.../index189.html
IAC opened and TB butterfly pic 785https://www.yotatech.com/forums/f200...1/index40.html
IAC removal and cleaning 3133-3135https://www.yotatech.com/forums/f200.../index157.html
Ignition coil replaced with junkyard coils out of newer truck 3323https://www.yotatech.com/forums/f200.../index167.html
Ignition Cylinder lighted surround 1871https://www.yotatech.com/forums/f200...1/index94.html
Ignition Coil re-boot 3795https://www.yotatech.com/forums/f200.../index190.html
Inclinometer installed 2745https://www.yotatech.com/forums/f200.../index138.html
Intake hose repair with rescue tape 3755https://www.yotatech.com/forums/f200.../index188.html
Intake Manifold coolant and vacuum lines and part numbers 3720-3724https://www.yotatech.com/forums/f200.../index186.html
Instrument Cluster cleaning 1850https://www.yotatech.com/forums/f200...1/index93.html
Instrument Cluster removal how-to 3607-3608https://www.yotatech.com/forums/f200.../index181.html
Instrument Cluster Trip Odometer replacement 1854https://www.yotatech.com/forums/f200...1/index93.html
Interior lighting color change:1) instrument cluster 2903, 2905, 2908, 2913-2915https://www.yotatech.com/forums/f200.../index146.html
ISR delete for later 3rd gens 3819https://www.yotatech.com/forums/f200.../index191.html
Knock sensors 2832-283Later 3rd gen3https://www.yotatech.com/forums/f200.../index142.html
License Plate light 3836https://www.yotatech.com/forums/f200.../index192.html
Lighter surround 3039https://www.yotatech.com/forums/f200.../index152.html
Land Cruiser Wheels 158https://www.yotatech.com/forums/f200...51/index8.html
Lighter surround bulb repair 3030, 3040-3042https://www.yotatech.com/forums/f200.../index152.html
Lights, light bar, wiring through the roof 220, 263, 274, 276https://www.yotatech.com/forums/f200...1/index14.html
Light bar redone 2017, 3332https://www.yotatech.com/forums/f200.../index167.html
MAF cleaned 300https://www.yotatech.com/forums/f200...1/index15.html
MAF test procedure and wiring schematic for the 96 778https://www.yotatech.com/forums/f200...1/index39.html
MAF mod, replace old with a maf and intake with one from a 99+ junkyard truck 3326-3329https://www.yotatech.com/forums/f200.../index167.html
Manual hub re-grease 2305https://www.yotatech.com/forums/f200.../index116.html
Manual Hub re-seal and grease 3888-3893https://www.yotatech.com/forums/f200.../index195.html
Manual hubs retrofit 1837, 1841https://www.yotatech.com/forums/f200...1/index92.html
Manual Hubs- getting the ABS back and replacing bearings w/drama 2458, 2461,2465, 2468, 2472, 2474, 2479-2480, 2482, 2486, 2488-2490https://www.yotatech.com/forums/f200.../index124.html
Mounts, motor replace 3275-3279https://www.yotatech.com/forums/f200.../index164.html
Mount, transmission replace 3143https://www.yotatech.com/forums/f200.../index158.html
Mud flaps 180, 183, 189, 583https://www.yotatech.com/forums/f200...1/index10.html
Oil Analysis from Blackstone 2791https://www.yotatech.com/forums/f200.../index140.html
Oil Cap gasket 3734https://www.yotatech.com/forums/f200.../index187.html
Oil Cooler 3693https://www.yotatech.com/forums/f200.../index185.html
Oil Dipstick Tube O-Ring replacement 1746-1748https://www.yotatech.com/forums/f200...1/index88.html
Oil Dipstick- measurement: how far it extends below the tube 1749https://www.yotatech.com/forums/f200...1/index88.html
OIl Pan EZ Valve 4378 https://www.yotatech.com/forums/f200.../index219.html
Oil Pan seal 3942-3944https://www.yotatech.com/forums/f200.../index198.html
On Board Air- 2247, 2259-2260, 2345, 2356, 2360, 2365, 2386, 2388-89, 2396https://www.yotatech.com/forums/f200.../index113.html
On-board air connector mounting plate 2777https://www.yotatech.com/forums/f200.../index139.html
On-board air venting and muffin fans cooling 4304, 4312 https://www.yotatech.com/forums/f200.../index216.html
Outlet on back of console 2662https://www.yotatech.com/forums/f200.../index134.html
Panel removal points, panel over the front seat belt 2676https://www.yotatech.com/forums/f200.../index134.html
Parking Brake Cable replacement1369-1379https://www.yotatech.com/forums/f200...1/index69.html
PCV hose 3787https://www.yotatech.com/forums/f200.../index190.html
Phone cradle, 2919-2929https://www.yotatech.com/forums/f200.../index146.html
Plug wires 300https://www.yotatech.com/forums/f200...1/index15.html
Power outlet on rear of center console 2662https://www.yotatech.com/forums/f200.../index134.html
Power outlet in rear cargo area 2809-2814https://www.yotatech.com/forums/f200.../index141.html
Power outlet in rear upper cargo area 3338https://www.yotatech.com/forums/f200.../index167.html
Power outlet in front under right side dash 3340https://www.yotatech.com/forums/f200.../index167.html
Power Steering Filter tear-down 3168https://www.yotatech.com/forums/f200.../index159.html
Power Steering pump guts 2303https://www.yotatech.com/forums/f200.../index116.html
Power steering rack boot replace 1836https://www.yotatech.com/forums/f200...1/index92.html
Power steering rack bushings 488, 517, 2272, 2279https://www.yotatech.com/forums/f200.../index114.html
Power steering rack and pinion 260, 2100https://www.yotatech.com/forums/f200.../index105.html
Power steering rack and pinion AGAIN 2056, 2069, 2076-2077, 2100-2102https://www.yotatech.com/forums/f200.../index104.html
Rear Driveshaft bolts/studs notes 3819https://www.yotatech.com/forums/f200.../index191.html
Roof Rack Baja ¾ length 3926https://www.yotatech.com/forums/f200.../index197.html
Roof rack changing out load bars and close up where wires pass through roof 989https://www.yotatech.com/forums/f200...1/index50.html
Roof rack storage for awning poles 4197 https://www.yotatech.com/forums/f200.../index210.html
Roof without headliner 3414https://www.yotatech.com/forums/f200.../index171.html
Seats, front, replaced with Mazda seats and raised 1" 220, 223, 225, 227https://www.yotatech.com/forums/f200...1/index11.html
Seat bolt nut common problem and how I repaired the driver's side 3317https://www.yotatech.com/forums/f200.../index166.html
Seats, rear, replaced with better oe seats out of newer 3rd gen 2674https://www.yotatech.com/forums/f200.../index134.html
Seat Belts, rear 1787https://www.yotatech.com/forums/f200...1/index90.html
Seat Belt, Driver's front 3114, 3116https://www.yotatech.com/forums/f200.../index156.html
Shifter Boot replacement with newer 3rd gen boot 3813https://www.yotatech.com/forums/f200.../index191.html
Shifter seat bushings, transmission and transfer shifters 2953, 2965https://www.yotatech.com/forums/f200.../index148.html
Shifter shaft gasket clearance after engine mounts 3308https://www.yotatech.com/forums/f200.../index166.html
Skid plate, aftermarket, removal 455 621https://www.yotatech.com/forums/f200...1/index23.html
Sliders, Shrockworks 657https://www.yotatech.com/forums/f200...1/index32.html
Slider length w/pics 1843https://www.yotatech.com/forums/f200...1/index93.html
Snorkel 3507, 3519-3531https://www.yotatech.com/forums/f200.../index177.html
Snorkel Extension 3744https://www.yotatech.com/forums/f200.../index188.html
Spare Tire Fit 31" stock size vs 33" w/pics 2382-83https://www.yotatech.com/forums/f200.../index120.html
Spark plug pictorial 2167https://www.yotatech.com/forums/f200.../index109.html
Speaker replacement 4012-4014 https://www.yotatech.com/forums/f200.../index201.html
Speed Bleeders for brakes 3801https://www.yotatech.com/forums/f200.../index191.html
Speedometer working with speed sensor in transfer case 1934-1936https://www.yotatech.com/forums/f200...1/index97.html
Speed sender out of a Tacoma notes 3144https://www.yotatech.com/forums/f200.../index158.html
Speed sender (VSS) note 4163 https://www.yotatech.com/forums/f200.../index209.html
Starter Contacts, Plunger, really nice work and writeup by Hrt4me 1609https://www.yotatech.com/forums/f200...1/index81.html
Starter Contacts, Plunger, comparison and junkhttps://www.yotatech.com/forums/f200.../index176.html
Steering rack bushings 517, 2279https://www.yotatech.com/forums/f200.../index114.html
Steering rack guide, link to Yukon's thread, musings 1289https://www.yotatech.com/forums/f200...1/index65.html
Steering rack guide, tightening 3550https://www.yotatech.com/forums/f200.../index178.html
Steering shaft pivot and firewall seal 4101,4103, 4105, 4208https://www.yotatech.com/forums/f200.../index211.html
Steering Wheel cover, Wheelskins 3197https://www.yotatech.com/forums/f200.../index160.html
Sunroof cable replacement for stuck cables 4261, 4266-4272 https://www.yotatech.com/forums/f200.../index214.html
Sunroof drain extension 3299-3301https://www.yotatech.com/forums/f200.../index165.html
Sway bar link, front replace with 2nd gen rear links, comparison 1860https://www.yotatech.com/forums/f200...1/index93.html
Sway bar link, rear, replace with 3rd gen front links, 1" longerSway bar bushing, 26mm, damage to poly bushing during wheeling trip 2007https://www.yotatech.com/forums/f200.../index101.html
Switch bulb replacement, hazard and defrost, 1784https://www.yotatech.com/forums/f200...1/index90.html
Taco Box and quadruple sticks 4021-4035 https://www.yotatech.com/forums/f200.../index201.html
Taco Box install write-up for m/t using Marlin’s directions 4037-4039 4042-4043 https://www.yotatech.com/forums/f200.../index202.html
Taco Box transmission coupler stuff, shifter housing note 4112,4116 https://www.yotatech.com/forums/f200.../index206.html
Taco Box triple stick write-up (quadruple because manual trans) 4040-4041, 4043-4045 https://www.yotatech.com/forums/f200.../index202.html
Thermostat new to 21 year old comparrison, 3101https://www.yotatech.com/forums/f200.../index156.html
Throttle body replaced with junkyard TB 3124https://www.yotatech.com/forums/f200.../index157.html
Throttle position sensor replacement 3132https://www.yotatech.com/forums/f200.../index157.html
Through panel connector for start battery fuse block 3307https://www.yotatech.com/forums/f200.../index166.html
Tie rod ends, inner and outer 260https://www.yotatech.com/forums/f200...1/index13.html
Timing belt notes and junk 3097- 3107, 3115https://www.yotatech.com/forums/f200.../index155.html
Timing belt tensioner tool use notes 3103https://www.yotatech.com/forums/f200.../index156.html
Tires, BFG All Terrain T/A KO pic 1893https://www.yotatech.com/forums/f200...1/index95.html
Tires, BFG All Terrain T/A KO2 bottom pic in post 1Tires, Michelin AT2 musings 325https://www.yotatech.com/forums/f200...1/index17.html
Trim retainer part numbers 3271https://www.yotatech.com/forums/f200.../index164.html
Trip Odometer replacement 1854, 3092https://www.yotatech.com/forums/f200...1/index93.html
Tundra front brakes 21, 27, 256, 339-brake pads 4137https://www.yotatech.com/forums/f200...51/index2.html
Turn signals, front at marker light location 499, 502, 511, 514https://www.yotatech.com/forums/f200...1/index25.html
Turn Signals, Side 467, 471, 656, 659, 661, 662, 665, 666https://www.yotatech.com/forums/f200...1/index33.html
Turn signals, front, reflective paint redone 445https://www.yotatech.com/forums/f200...1/index23.html
Ujoint, rear 933https://www.yotatech.com/forums/f200...1/index47.html
Underhood water drain 3309https://www.yotatech.com/forums/f200.../index166.html
Usb port where lighter socket was 4302-4303 https://www.yotatech.com/forums/f200.../index216.html
Vacation 2010, 195-https://www.yotatech.com/forums/f200...1/index10.html
Vacation 2011, 293https://www.yotatech.com/forums/f200...1/index15.html
Vacation 2012, 737https://www.yotatech.com/forums/f200...1/index37.html
Vacation 2013, 1327https://www.yotatech.com/forums/f200...1/index67.html
Vacation 2014, 1975https://www.yotatech.com/forums/f200...1/index99.html
Vacation 2015, 2497https://www.yotatech.com/forums/f200.../index125.html
Vacation 2016, 2849https://www.yotatech.com/forums/f200.../index143.html
Vacation 2017 spring break, 3073https://www.yotatech.com/forums/f200.../index154.html
Vacation 2017 3224https://www.yotatech.com/forums/f200.../index162.html
Vacation 2018 CO/UT 3593-3594, 3622, 3624-3632https://www.yotatech.com/forums/f200.../index180.html
Vacation summer 2020 3963-3989https://www.yotatech.com/forums/f200.../index199.html
Vacation Summer 2022 4377, 4379-4384 https://www.yotatech.com/forums/f200.../index219.html
Valve cover bolt grommet replacement Yotashop and Toyota dealership supplied parts comparison 3958https://www.yotatech.com/forums/f200...ispreloading=1
Valve cover gaskets, clearances 2816-2831https://www.yotatech.com/forums/f200.../index141.html
Valve cover parts list 2835https://www.yotatech.com/forums/f200.../index142.html
Visor, sun, modded Ford Taurus replacement 1894, 1909-1912https://www.yotatech.com/forums/f200...1/index96.html
Visor upgrade 3858https://www.yotatech.com/forums/f200.../index193.html
Voltmeter for dual batteries, single gauge 1175https://www.yotatech.com/forums/f200...1/index59.html
Washer nozzles, 2 stream to 3 stream 2650https://www.yotatech.com/forums/f200.../index133.html
Washer tank mod and chuckles89's version too 3474-3476, 3498-3503https://www.yotatech.com/forums/f200.../index174.html
Wheel bearing, rear, symptoms, bearing musings, info and stuffhttps://www.yotatech.com/forums/f200.../index173.html
Wheel bearing, rear 4053, 4060 https://www.yotatech.com/forums/f200.../index203.html
Windshield washer tank removal and washer pump pics 1711-1715https://www.yotatech.com/forums/f200...1/index86.html
Winch hook holder mod 3543https://www.yotatech.com/forums/f200.../index178.html
Winch stuffed into a 4xInnovations front bumper built for 1" body lift 3471-3473, 3480-3481, 3484, 3492https://www.yotatech.com/forums/f200.../index174.html
Winch power cables front and rear with anderson connectors 2744, 2787https://www.yotatech.com/forums/f200.../index140.html
Winch power cable anderson connectors, getting Ruff Stuff connectors to work with Warn connectors 2839https://www.yotatech.com/forums/f200.../index142.html
Windshield, just for note, didn't put it in 2848https://www.yotatech.com/forums/f200.../index143.html
