I need engine help
Old Jul 31, 2008 | 10:45 PM
  #101
just a 22re's Avatar
yes we did lol but yeah hows she coming along?
)now if that dont fit the old title!)
Old Aug 1, 2008 | 07:07 AM
  #102
76ANTHONY's Avatar
welllllllllllllllllllllllll???? did ya get that biatch runnin?????
Old Aug 1, 2008 | 10:39 AM
  #103
grant526's Avatar
Do you still have the dizzy from the old motor? If you still can't get it to go, maybe you can try the old one in he new block?
Old Aug 1, 2008 | 10:53 AM
  #104
wrnchplr's Avatar
Originally Posted by DeathCougar
Aww damn they changed the title.
No worries, those of us who helped recieved our just rewards
I know how rude
LOL!! that sure does fit....
No it still wont run. getting close but still no...
I did change the dizzy and that didn't help. it seems to want to start when it;s retarted way past the #1 post. I am going back out to try a few more things.
Old Aug 1, 2008 | 10:55 AM
  #105
wrnchplr's Avatar
Hope that's working for you!
It's encouraging to hear you sound so eager and excited about it. : )
It is working nicely for me haven't work for months. I could get used to this if I could find some way to keep money in the bank and still stay at home.....
I was ready to throw the thing in the trash tell it started to tease me about starting.
Old Aug 1, 2008 | 11:20 AM
  #106
wrnchplr's Avatar
Well guys I think that might be it. I was cranking her over and she was right there then I heard a metal click (like something breaking) and the cranking slowed. now the started sounds very labored. I have a really hard time getting it to turn over by hand. Me think there are now broken rings or bearings.
Old Aug 1, 2008 | 11:22 AM
  #107
wrnchplr's Avatar
once got busy in a burger king bathroom
good stuff
Old Aug 1, 2008 | 11:49 AM
  #108
76ANTHONY's Avatar
did your starter break????????????????????
Old Aug 1, 2008 | 11:51 AM
  #109
wrnchplr's Avatar
It's fine that problem is in the engine.
Old Aug 1, 2008 | 11:55 AM
  #110
76ANTHONY's Avatar
ummmmmmmmm isnt that a fresh rebuild???? ruuuutrooooohhhhh
Old Aug 1, 2008 | 12:58 PM
  #111
wrnchplr's Avatar
It is a fresh rebuild.....I pull the timing cover and found the left cam had moved 3 teeth. I removed the belt to find the crank turns over just fine, the right cam just fine. the left cam no move.....hummm sucked a valve? broke a shim?? F-IT I am hauling to the storage shed and installing a 22re in my 95....
ANYONE KNOW WERE A LINK IS FOR THIS SWAP??
Old Aug 1, 2008 | 01:33 PM
  #112
Djlarroc's Avatar
https://www.yotatech.com/forums/f116...omical-143002/
https://www.yotatech.com/forums/f116...e-swap-132464/
https://www.yotatech.com/forums/f116...e-swap-122554/
These are what I found through a brief search.
Old Aug 1, 2008 | 01:41 PM
  #113
ouch you jumped a tooth and bent a valve! damn i was hoping we were going to see a vid of this thing doing a 15 block burner!!
Old Aug 1, 2008 | 02:42 PM
  #114
76ANTHONY's Avatar
hey dammit, get in there and pull that valvecover dammit, this fricken things gonna fricken run dammit!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 1, 2008 | 02:57 PM
  #115
wrnchplr's Avatar
that was the plan!! I even filled the tank with jet fuel
I am thinking it's a bent valve, I don't know how it could just jump some teeth...I can't afford to have the head rebuild. guess it's time to pull out the and make some motor mounts for a 22-re.
Old Aug 1, 2008 | 03:00 PM
  #116
wrnchplr's Avatar
I'll get right on that some time after school....I don't have the funds to rebuild a head. I got all my cash tied up in moving and tuition. I have 3 runners one with a bad front axle but a strong 22-re and 2 with bad 3.0's so I am going to fab up some mounts and make it work......
Old Aug 1, 2008 | 03:05 PM
  #117
76ANTHONY's Avatar
thats not workin for me. pull the valve cover and see if one of the bolts came loose and wound up under the cam, commmme on you almost got it there
Old Aug 1, 2008 | 03:13 PM
  #118
wrnchplr's Avatar
yeah but to pull the valve cover I gots to take off the intake and that is a PITA!
I would like to know what happed so I guess...ONLY DOING THIS SO YOU WILL SIMMER DOWN It's like 115 in the garage right now so i'll get on that once the A/C cools things down a bit...
Old Aug 1, 2008 | 03:15 PM
  #119
wrnchplr's Avatar
Thanks.
Old Aug 1, 2008 | 04:30 PM
  #120
wrnchplr's Avatar
I pulled the valve cover and there is no signs of anything wrong. all the bearing still have grease and all the shims are intact. looks like it's time to pull the head.
