I need engine help
Old Aug 1, 2008 | 04:41 PM
  #121
just a 22re's Avatar
you cant spin the cam by hand? but the motor spins freely by hand? then theres a leak or a bent valve somewhere the crank should be hard to spin by hand
Old Aug 1, 2008 | 04:44 PM
  #122
wrnchplr's Avatar
Can't turn cam but with a socket and a 1/2" drive I can get the crank to turn over.....guess I'll pull the head and inspect for bent valves. I spent a ton having them rebuilt!!!!!
  #123
Djlarroc's Avatar
Originally Posted by wrnchplr
Thanks.
No problem buddy. Good luck w/whatever you decide to do. Especially if you try to mod some motor mounts. Did you also read the issue w/the tranny?
Oh, almost forgot something...
Link?
Old Aug 1, 2008 | 04:47 PM
  #124
DeathCougar's Avatar
The 3VZ is a non-interference engine, even without a belt you should not have bent valves.
Old Aug 1, 2008 | 04:51 PM
  #125
wrnchplr's Avatar
Link?
The link is dead. someone found my little stash and photobucket removed them sorry man.
well I am at a loss as to the problem. the thing was turning over just fine was just about started then comes a funny noise and it won't turn over now.
Old Aug 1, 2008 | 04:55 PM
  #126
yes
dc they are not a inter motor but he did shave the heads and plained the block WITH OUT a bigger head gasket thats where i think he hit but nit bad just a little tink and its over thats why i say i think he bent a valve
Old Aug 1, 2008 | 05:15 PM
  #127
wow i so got him mixed up with the other thread 22re one lol hes the one that shaved his head! my bad
but you never know
check out all the vlaves very closly and see if there anything out of the wrong in there a seal could have failed and got stuck in there or anything else at the same time!
Old Aug 1, 2008 | 06:04 PM
  #128
wrnchplr's Avatar
I got the head off, there is no damage to any of the valves. I did find the cam was not centered. I had a line bore done (machine shop said I needed it) and it looks like they F-ED it up. the cam has chewed the hell out of the front bearing and also the rear. there are grooves so deep I can feel them with my nail.....
Old Aug 1, 2008 | 06:08 PM
  #129
ouch!!!! take it back to them and tell them they fed it up and have them fix it now!!!!!
Old Aug 1, 2008 | 06:11 PM
  #130
wrnchplr's Avatar
Yeah I'm going to....In the mean-time I need to get this pig running. I got a set of heads with ~160 k they didn't smoke so I might throw me on tell this all gets worked out.
tell then.....
Old Aug 1, 2008 | 06:15 PM
  #131
yeah sounds like a good idea there buddy oh wait we have been for a long time now lol
Old Aug 1, 2008 | 06:32 PM
  #132
wrnchplr's Avatar
mummm nothing like a shot to make the worries go away......
Old Aug 1, 2008 | 06:44 PM
  #133
lol you gotta love everclear!
Old Aug 1, 2008 | 06:46 PM
  #134
wrnchplr's Avatar
Man I can't stand that stuff!! to many Irish car bombs...
Old Aug 1, 2008 | 08:31 PM
  #135
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
I'm SO not going there...........! There's never too much for a proper Irishman.....lol
Old Aug 1, 2008 | 09:00 PM
  #136
Djlarroc's Avatar
Ah well too bad. Hope you get this engine running man. Good luck!
Old Aug 1, 2008 | 09:01 PM
  #137
76ANTHONY's Avatar
tell then.....
115 in the garage, same here and i just waxed the entire black beast, fock im melting..... anyway, im glad you found out what happened, so tomorrow you gonna do the head swap and start it right up, right????????
Old Aug 1, 2008 | 09:21 PM
  #138
After all this, I really hope she fires up, for his sake, and his sanity!!!! Good luck dude!
Old Aug 1, 2008 | 09:27 PM
  #139
wrnchplr's Avatar
Thanks man....
Yeah going to head swap and see what happens...I got the ac on so it should be cool for a long day of wrnchin.....
Old Aug 1, 2008 | 09:50 PM
  #140
I'll trade ya the rainy cold weather we've had here in Washington, for your 100+ degree heat
