PDA
View Full Version : Engines - Transmissions
Pages : [1] 2
  1. FS [PacSoWest]: 3vz and 2wd auto trans sf bay area
  2. FS [PacNorWest]: Offenhauser 6361 20R intake like new! $250
  3. WTB [GreatLakes]: carb
  4. FS [NorAtl]: r150 manual trans / tcase/ pedals from 3.0
  5. FS [SouthEast]: New genuine Toyota OEM 3RZ 8-port head 11101-79276
  6. FS [GreatLakes]: 22RE Performance motor and Marlin drivetrain
  7. FS [PacSoWest]: Marlin Crawler L52
  8. FS [SouthEast]: 3.4 Swap 4WD Auto Transmission/ECU/Harness
  9. FS [NorAtl]: Om617 and doomsday diesel swap parts!
  10. FS [PacSoWest]: WTS: VF1A transfer case (Elk Grove, CA)
  11. WTB [PacSoWest]: Looking for w56 transmission and RF1A transfer case
  12. FS [NorRock]: Junk 3vz and parts make offer
  13. FS [WestCanada]: Some odds and ends to clean out.
  14. FS [SouthEast]: 22RE Fuel injection parts (SC)
  15. FS [MidWest]: 4l60 built trans with Downey Toyota Gear Tcase adapter/23 spline output shaft. $500
  16. WTT [International]: R151f Trans - transfer box
  17. WTB [SouthEast]: W59 bellhousing
  18. WTB [SouthCent]: SBF to W56 bell housing
  19. FS [PacSoWest]: 3VZE Cooling fan with complete shroud used OEM V6
  20. FS [PacNorWest]: Trail-Gear™ RF1A Transfer Case Shifter w/ Base Toyota
  21. FS [PacNorWest]: Top shift conversion kit Trail Gear KIT A
  22. FS [SouthEast]: 3.4 Engine/Trans/Transfer
  23. FS [NorRock]: FOR SALE 22R 1987 Timing Chain Cover $25
  24. WTB [NorRock]: WTB cold start injector time switch
  25. FS [PacSoWest]: FS: 2004 1grfe Engine and Transmission (2wd automatic)
  26. FS [FourCorners]: Marlin HD trans mount for pickup/ early 4runner
  27. FS [PacNorWest]: Clutch Kit-Standard Kit Fenco NU31197 Toyota pickup 4runner
  28. FS [GreatLakes]: Aisin TKT-016 Timing Belt Kit New in Box
  29. WTB [PacNorWest]: Super Charger Nose Cone Assembly?
  30. FS [SouthCent]: 20R engines - rebuilt - Austin,TX
  31. FS [SouthEast]: R150F Trans and TCase low mileage
  32. FS [SouthCent]: FS new engine parts
  33. FS [SouthEast]: 22R OEM Emissions Equipment Set + Aisan 2BBL Carburetor
  34. FS [PacSoWest]: WTB 1985-1988 Auxiliary Air Idle Valve
  35. FS [PacSoWest]: 3vze Clutch kit and Short Throw Shifter
  36. FS [PacSoWest]: 22RE and 5VZ engine mount spacers
  37. FS [PacSoWest]: A340h 170k miles - 500$
  38. WTB [PacSoWest]: WTB - smog pump brackets and hardware ‘84 22r
  39. WTB [MidWest]: 4 or 5 speed for 1980 toyota truck
  40. WTB [PacNorWest]: 22re rebuildable block
  41. FS [PacSoWest]: 8" 4.88 diff
  42. FS [MidAtl]: R151F Trans and Bellhousing
  43. FS [PacNorWest]: 1980 om617
  44. WTB [SouthCent]: VF1A transfer case needed
  45. FS [PacSoWest]: Toyota 2.28 T Case + TG Adaptor
  46. WTB [NorAtl]: W59 first gear and synchro
  47. FS [MidWest]: MN: 1992 Chevy 4.3/4L60 swap kit
  48. FS [MidWest]: 20r Parts, L43 and Transfercase from an '80
  49. FS [SouthEast]: 2wd 5-speed transmission FS in northeast Ga $450
  50. FS [PacNorWest]: 85 22r motor for sale
  51. FS [MidWest]: Trail-Gear Trail-Creeper Dual Transfer Case Adapter BRAND NEW & Two Gear Drive Cases
  52. WTT [East Canada]: Ford 302 swap parts - everthing you need to make it a 302!
  53. FS [MidWest]: ENGNBLDR Street RV Head and 261 Cam. Texas. $350
  54. FS [MidAtl]: FS: DENSO air/fuel ratio & oxygen sensors - 3rd gen 4Runner
  55. FS [MidAtl]: R150/tcase and shifters
  56. FS [PacSoWest]: Bud Build - dual Tcase cross member
  57. WTB [SouthEast]: 22RE ENGINE-to-TRANS braces needed, 86
  58. FS [PacSoWest]: 3ZV-FE MAF and airbox adapters.
  59. FS [MidAtl]: 95 V6 engine 116K miles in ne PA
  60. FS [SouthEast]: Brand new reman Supra AFM
  61. WTB [SouthEast]: Throttle Position Sensor 89452-22090 TPS
  62. FS [NorAtl]: complete 3rz swap $650
  63. FS [SouthEast]: In need of a Transmission! 91 Toy 22RE
  64. FS [SouthCent]: Offenhauser Signal Plane Intake/Weber 32/36
  65. FS [SouthCent]: LCE Street Headers 82-84
  66. FS [SouthCent]: 1982 Toyota 4x4 RF1A transfer case
  67. FS [SouthCent]: 1982 Toyota 4x4 L52 Transmission
  68. FS [SouthCent]: FS: 1982 22r Toyota Long Block, 162,000ish miles
  69. FS [SouthEast]: 1992 Toyota 3.0 upper intake $80.00
  70. FS [SouthEast]: 1992 toyota 3.0 distributor $80.00
  71. FS [SouthEast]: 1992 4runner cold start injector $30.00
  72. FS [SouthEast]: 1992 Toyota 3.0 igniter $40.00
  73. FS [PacSoWest]: Free...A340H Throttle valve cable
  74. FS [GreatLakes]: 99 3.4 v6. Erie pa
  75. FS [MidAtl]: 88 SR5 Cluster, 20R Offenhauser intake
  76. FS [PacNorWest]: NEW toyota 23 spline 4.7 gears
  77. FS [SouthCent]: Weber side drafts, header, and ignition setup for Toyota 22R / 22RE
  78. FS [NorAtl]: Stock 22R carb off 1987 Pickup
  79. FS [SouthEast]: 22RE Fuel Hose w/Damper
  80. FS [PacNorWest]: R155f 37,500 miles w/ bell for 2TR 500 OBO
  81. FS [MidWest]: 22re Fuel Injecotrs
  82. FS [GreatLakes]: 3vze Toyota Cylinder Heads 1988 - 1995 3.0 V6 Pickup 4runner - New
  83. FS [PacNorWest]: 3.0 Head
  84. FS [MidAtl]: 5VZ Supercharged Drop out with full exhaust (3rdgen T4R)
  85. FS [PacSoWest]: 3VZ leftover
  86. WTB [MidWest]: 1990 w56 Transmission Clutch Hub No. 2
  87. WTB [SouthEast]: 81-83 Diesel "L" Engine Camshaft
  88. FS [SouthEast]: New 22r/e parts- Engnbldr Street RV head, LCE Adjustable cam gear, Rocker Shafts, etc
  89. FS [SouthEast]: 2rz 5 speed
  90. FS [SouthEast]: 4.3 tbi harness/computer
  91. FS [PacNorWest]: Toyota and Lexus ECU/ FZJ80 elocker axle complete or part out!
  92. FS [SouthEast]: 1993 Lexus LS400 For Sale V8 Baby!
  93. WTB [GreatLakes]: Airbox from a 3.4l Taco/runner
  94. FS [NorAtl]: toyota 3.4L - 200$
  95. FS [PacNorWest]: A340H auto trans Bay Area CA $250
  96. FS [PacNorWest]: WTB 20R head East WA/ID
  97. WTB [PacNorWest]: need 22re bottom end
  98. FS [SouthCent]: $60 - 3VZE injectors ready to rebuild - Austin, TX
  99. FS [PacSoWest]: $29.00 - ACCELERATOR CABLE LINKAGE from 1982 22R - San Diego, California
  100. FS [PacSoWest]: AISAN CARBURETOR from 1982 22R - San Diego, California
  101. FS [PacSoWest]: $35.00 - INTAKE MANIFOLD from 1982 22R - San Diego, California
  102. FS [PacSoWest]: SMOG/EMISSION PARTS from 1982 22R Desmog - San Diego, California
  103. FS [MidWest]: Aiding electric choke carb
  104. FS [MidWest]: w56 top shift transmission and gear drive tcase
  105. WTB [PacSoWest]: 2002 tacoma transmission (97-2008)
  106. WTB [PacSoWest]: 2002 tacoma transmission (97-2008)
  107. FS [GreatLakes]: 1994 3VZ-E, and Auto Transmission: Coldwater Michigan
  108. WTB [PacSoWest]: Budbilt single case crossmember
  109. FS [MidWest]: 2WD transmission 97 4runner, 138K miles
  110. WTB [PacSoWest]: Doug Thorley 3.0 long tube headers and aftermarket cams
  111. FS [PacNorWest]: Marlin Crawler 1,200# Clutch (22re, 1993-1995) - $140
  112. FS [PacNorWest]: 3VZE injectors
  113. WTB [SouthEast]: A/C Compressor for '87 4Runner 22R-E
  114. WTB [FourCorners]: A340H Auto Trans/T-Case front yoke/flange (companion flange)
  115. FS [SouthEast]: A340f
  116. WTB [SouthEast]: A340f
  117. FS [PacNorWest]: WTS: Weber 32/36 DGEV Carburetor - Burlington, WA
  118. FS [GreatLakes]: [Michigan] Manual and Auto Transmissions - R150, A340H, A340F 2wd & 4x4
  119. FS [SouthEast]: top shift tcase sale or trade
  120. FS [MidAtl]: For Sale LC Engineering 22RE EGR Block Off Kit
  121. FS [GreatLakes]: 1992 22RE Complete Engine Fully Dresed
  122. FS [PacSoWest]: Circuit opening relay(fuel pump relay) Orange County, California
  123. FS [GreatLakes]: [Michigan] Early style 79-84 22R engine
  124. FS [PacNorWest]: 3.4L Supercharger w/URD 7th kit
  125. FS [SouthCent]: Marlin Rebuilt W56 Transmission - Never Installed
  126. WTB [PacNorWest]: 3.4L supercharger
  127. FS [SouthEast]: 3rz LC header , header only no other parts 175.00
  128. FS [NorAtl]: Top shift transfercase
  129. FS [PacNorWest]: 22R for sale post 3rz swap
  130. FS [NorAtl]: Misc.Toyota Parts
  131. FS [MidAtl]: For Sale: OEM Toyota Igniter for 22RE
  132. FS [FourCorners]: 7mge bellhousing and clutch
  133. FS [MidAtl]: OEM Nippon Denso Distributor for 1993 22RE $50 Shipped
  134. WTB [MidAtl]: Hi/Lo shift fork
  135. FS [MidAtl]: 22re block and head and more
  136. WTB [SouthCent]: Idle Air Control Valve PN:22230-35010 22re
  137. WTB [SouthCent]: L50 or L52 Transmission
  138. FS [GreatLakes]: 2.7 3rz complete swap
  139. FS [NorAtl]: LCE W56-C Short Shifter Kit with shifter and base
  140. WTB [SouthEast]: 96-02 4runner 3.4, auto, 4x4, rear driveshaft
  141. WTB [PacSoWest]: W56-B/A needed
  142. FS [SouthEast]: WTB automatic transmission for 4x4 88 pickup
  143. FS [MidAtl]: Landcruiser FJ40/60 Motor & Transmissions/T-Case Barter for aftermarket items.? Penn.
  144. FS [PacSoWest]: Trail Gear Tacoma Adapter for duals/gear driven t-case
  145. WTB [SouthCent]: 22r for 1987 pickup
  146. WTB [WestCanada]: WTB Manual trans reverse sensor pigtail
  147. FS [NorAtl]: Stock 22R carb
  148. FS [PacNorWest]: 3.0 cylinder heads for sale
  149. FS [MidWest]: Offroad Solutions 3.4 Swap Crossover Pipe (new style) w/ manifolds
  150. FS [SouthEast]: 1982 toy 4x4 22r head needed- 84-85 HEAD for sale
  151. FS [SouthEast]: 20R Engine
  152. FS [SouthCent]: 2002 3.4 v6 engine, wiring harness, and computer
  153. FS [SouthCent]: W56-B 5-speed transmission
  154. FS [NorAtl]: 22RTE Upper and Lower Intake and fuel rail
  155. WTB [NorAtl]: Looking for 5 speed 4x4 tranny
  156. FS [FourCorners]: Rebuilt 22R turn key, Show Low, AZ
  157. FS [SouthEast]: Complete Auto to 5spd swap (W-56B)
  158. FS [FourCorners]: WTB: 1st Gen (grey) 3.4L Supercharger Parts
  159. FS [SouthCent]: 3.4L engine $1300 firm
  160. FS [PacSoWest]: FS: K&N High Performance Replacement Air Filter - V8s - 4runner,tundra,sequioa
  161. WTB [PacSoWest]: 3.) Engine long block for cheap
  162. FS [SouthEast]: OM617 Engine + Adapter Plate
  163. FS [NorAtl]: 22RTE Exhaust Manifold
  164. FS [SouthCent]: Clinton, Ms 39056 1UZ to R150 swap bellhousing, few other random small things
  165. FS [MidAtl]: 1988 5 Speed Transmission and Xfer Case
  166. FS [SouthCent]: 22RE Engine, transmission, tcase from 87 4Runner
  167. FS [GreatLakes]: 1985 22re
  168. FS [MidAtl]: FJ40 Motors/Trans./T-cases Pennsylvania $250 & up
  169. FS [SouthCent]: Early ('81-84) 22R heads for sale - Performance and stock!
  170. FS [MidWest]: Early 22r block for rebuild! $100
  171. FS [MidWest]: Forward shift EFI case MN
  172. FS [MidWest]: Rf1a early top shift case $150 Mn
  173. FS [MidWest]: EFI W56 higher mileage $150
  174. FS [MidWest]: Carbed w56 very nice! $250
  175. FS [PacNorWest]: 22R/E OEM timing cover
  176. FS [SouthEast]: 3rz, swap parts, etc.
  177. FS [MidWest]: 22rte Parts
  178. FS [MidWest]: NIB 22re ENGNBLDR main bearings
  179. FS [MidAtl]: Weber 32/36 for a 22R
  180. FS [MidAtl]: Landcruiser 2F motor (Bare motor) + Transmission Pennsylvania
  181. FS [NorAtl]: FS: NYC 1987 4x4 22RE Engine and Auto Trans
  182. FS [MidAtl]: '86 22R complete motor
  183. FS [NorAtl]: 3.0 v6 engine parts.
  184. WTT [International]: 22re Original turbo system
  185. WTB [MidWest]: top shift transfer case shifter RF1A
  186. WTB [PacSoWest]: Need 3vze
  187. FS [PacSoWest]: FS: A340 transmission and t/case Lancaster Ca
  188. FS [SouthCent]: 2rzfe engine
  189. FS [SouthCent]: 3.0 K&N 57-9006 intake kit
  190. FS [MidAtl]: 92 22re afm and dizzy
  191. WTB [PacNorWest]: w56 c manual trans with t-case and drivelin
  192. FS [PacNorWest]: Parting out 96 5VZ-FE engine. Cracked heads, but everything else is good!
  193. FS [GreatLakes]: 22RE performance and stock parts (pic heavy)
  194. FS [MidWest]: 2001-02 Tacoma/4Runner M/T Harness 3.4
  195. FS [PacNorWest]: T100 auto trans/tcase - Bay area, CA
  196. FS [FourCorners]: Parting out 85-95 22R
  197. FS [SouthCent]: 1st Gen Downey air filter with pipe and MAF
  198. FS [MidWest]: OM617 22r/re swap kit
  199. FS [PacNorWest]: 89 W56-C with T-Case/Clutch Portland OR
  200. FS [SouthCent]: 22RE Garage Sale
  201. FS [MidAtl]: 3VZE ECU and Ignitor
  202. FS [SouthCent]: parting out a 3.0
  203. WTB [SouthEast]: White coolant temp sensor, t-stat housing
  204. FS [FourCorners]: Used 22R distributor w/ newer cap, rotor and wires
  205. FS [FourCorners]: Seized 22R/E Long Block w/ extras
  206. FS [FourCorners]: Almost new Engn Bldr Street RV Head and 261C Torker Cam
  207. WTB [PacSoWest]: HELP! iso 22r/re head
  208. FS [SouthEast]: EGR and PAIR system - COMPLETE, CLEAN, AND PERFECT!!!
  209. FS [FourCorners]: W59 for sale
  210. MARCH 2015 ADMIN NOTICE: Post years & model instead of 1st, 2nd, 3rd gen in ad titles
  211. FS [MidWest]: FS central Iowa 3.0 3VZ-E, 3.4 5VZ, OM617, manual trans, tcase, many parts
  212. FS [PacNorWest]: WTB - W56 transmission
  213. FS [PacNorWest]: 1979 20r and L52 trans
  214. FS [FourCorners]: 3vze parts, 2wd auto trans, top shift t-case...
  215. FS [MidWest]: 3.0L V6 engine and multiple transmissions
  216. FS [MidWest]: 3.4 5vze complete 60k 1400obo
  217. WTB [PacNorWest]: I want a forward-shift W56
  218. FS [MidAtl]: 5VZ-FE Part out - Prices Listed with parts - Chesapeake, VA
  219. FS [NorAtl]: R150 Trans/tcase
  220. FS [SouthCent]: HD Marlin Crawler trans mount
  221. FS [MidWest]: 4x4 Labs OM617 to Toyota W56 Adapter and 35lb Flywheel- Nebraska/Kansas
  222. WTB [FourCorners]: toyota 3.4 drill guide
  223. FS [PacNorWest]: 3.0 V6... What would you pay?
  224. FS [PacNorWest]: LCE Performance: Holley 350 to 22R adapter, $20, Evans,WA
  225. WTB [SouthEast]: W56 Top Shift
  226. FS [MidAtl]: NIB 22RE Engnbldr ring/ bearing set, 22RE manifold + tb + EFI stuff
  227. FS [PacNorWest]: Complete 22re core
  228. FS [SouthCent]: 3.0 V6 Engine Parts. CHEAP!!
  229. FS [SouthCent]: For Sale Eng Bldr street rv head and OEM valvetrain
  230. FS [SouthCent]: 22RE Big bore throttle body and late model straight neck upper plenum $250
  231. FS [FourCorners]: AEM FIC 6 piggyback ECU and Boomslang plug-n-play wiring harnesss 98-00 Taco/4Runner
  232. FS [FourCorners]: New OBX Header and mid-pipe for 22R/E
  233. FS [MidWest]: 3rd Gen Injectors
  234. FS [SouthCent]: 22re 22rte SteedSpeed turbo manifold
  235. FS [MidWest]: 3.4 Cylinder Heads, TB & 3.0 accessories
  236. FS [PacSoWest]: 96-02 Transfer case skid plate NEW
  237. WTB [MidAtl]: WTD - 3rd gen transmission
  238. FS [MidAtl]: 94 22re engine/ parts
  239. FS [NorAtl]: 22R Parting out (S.W.Penn)
  240. FS [NorAtl]: 22RE,W56 Transmission and T-Case FOR SALE (S.W.Pa)
  241. FS [MidAtl]: Toyota Truck 4runner Rock Crawler Parts
  242. FS [MidWest]: Central CO: 1980 20r +tranny $250 o.b.o
  243. FS [SouthEast]: 22re parts
  244. FS [PacNorWest]: Tacoma r150f Transmission 5speed
  245. WTB [GreatLakes]: looking for w56 w/case
  246. FS [SouthEast]: *Hard to find* 22R/E A/C Compressor Brackets
  247. FS [SouthEast]: selling misc.Toyota/chevy drive train parts
  248. FS [SouthEast]: WTS Toyota and chevy drive train parts
  249. WTB [NorAtl]: Need a bell housing.
  250. WTB [PacSoWest]: '86 22RE Block and Head + Accessories FREE
