I am located in Starksboro VT. I have a 1996 3rz from my Tacoma that I just removed for a diesel swap. It has 180k on it and runs perfectly. Uses no oil whatsoever. The engine was run up to temp and removed on 1/26/19, and is stored inside my shop.
I bought the truck in April and drive it back from Reno Nevada, so it has never seen road salt. There is still factory yellow zinc on engine fasteners and no bolts are ever stuck on this truck.
Comes with ECU, all engine sensors, flywheel, clutch (clutch is worn, good for mock-up only), and w59 bell housing. I can include the factory wiring harness too. I did need to take a few wires out of it for my swap (reverse lights, coolant gauge, 4x4 indicator) but it and can be used to make this engine run.
