FS[MidWest]: OM617 22r/re swap kit
This kit will work with any truck that came with a 22r or 22re.
Has everything you need and then some.
Comes with-
bell housing adapter
drilled flywheel
crank adapter
motor bracket adapters
Low mileage turbo charger
rebuilt injectors
OM617 repair manuals from mercedessource.com
You may need to clearance the oil pan depending on what you put it in, solid axle, ifs ect.
The reason I am selling this is because the engine I had planned to use ended up having a bad bearing.
I just threw in a 22re I had lying around and am trying to recoup some of my losses.
Asking $550 obo, you pay shipping.
located in Rapid City, SD
You can shoot me a PM but its quickest to Email me,
caleb@blackhillsvapors.com
Comes with-
drilled flywheel
crank adapter
rebuilt injectors
Flying91
45
04-11-2024 04:39 PM
XtraCab
04-12-2020 05:25 AM
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
