Engines - Transmissions Place above type items here
FS[WestCanada]: Some odds and ends to clean out.
Old Aug 4, 2023 | 04:47 AM
davefarr's Avatar
22RE 1990ish 4runner. Coolant piping, wiper motors, relays, cold start injector, knock, etc. spares but untested. Make an offer + actual shipping
Old Sep 9, 2025 | 11:46 AM
CHUKKI's Avatar
5 Year Member
Question "Cold Start Injector"
Hello Mr. Farr, the "cold start injector" is that also known as the "Temperature Sensor" or the "Thermo-Time Switch II ?" Were they right underneath the front side of the EFI plenum?
Are they in working order? Will they work on a 1988 22RE 4x4 Pickup? Chukki in Nashville, TN
Old Sep 9, 2025 | 02:59 PM
davefarr's Avatar
Hi, parts came off a running engine- I changed to a standalone ecu so I no longer use this. You will have to go on RA and do your research and if there are numbers on these parts I can give you those if they are on the part. I don't know what group of years are compatible these are 1990ish. The cold start injector is a supplemental fuel injector that goes on the drivers side of the upper plenum behind the throttlebody. I believe it had it's own black temp sensor at the front of the lower intake by the thermostat beside the green ecu temp sensor.. That's all I can tell you.
wadester33
Sep 29, 2021 04:09 AM
shoes138
May 28, 2007 12:09 PM
