habanero's 1996 4Runner Build-Up Thread
Old Jan 29, 2015 | 06:40 PM
  #2281
habanero's Avatar
Hot tea.....man, I should've thought to additive it!
Old Jan 30, 2015 | 04:31 AM
  #2282
jason in tn's Avatar
I wonder if you can get the poly bushings out without destroying them. I want poly bushings in my new rack when I put it in and the ones in my old rack aren't that old, I guess for the price it's not a big deal to buy new ones tho. Just thinking out loud lol. Good job as usual hab, it's no fun doing this stuff in the cold.
Old Jan 30, 2015 | 06:38 AM
  #2283
habanero's Avatar
Jason- I started to pull the left side poly bushing out of my old rack....I think it's doable though I didn't finish it did start coming out. I think the trick would be (and what I didn't have) finding something to push the sleeve out first, slightly smaller than the sleeve so it doesn't become the sleeve. After that no worries, right? Two halves and tada.
The hardest one would be that left side because of its length.
Old Jan 30, 2015 | 04:17 PM
  #2284
rworegon's Avatar
Haha, me thinks your brain was too cold and not thinking properly.
Have a great weekend!
Old Jan 30, 2015 | 07:14 PM
  #2285
habanero's Avatar
You're prolly right, rw.
96 4Runner 207,784 miles
Replaced the power steering pump today. I was going to document with pics but it was too messy for the camera and I was too cold (excuses excuses). At least the wind was much lighter and the sun was out for the first part of it. I will throw some pics up later. Just got to flush it and I should be good to go.
Old Jan 31, 2015 | 05:55 PM
  #2286
Awesome hab, another job you can guide me through when the time comes.
Old Feb 1, 2015 | 06:20 AM
  #2287
rworegon's Avatar
Nice you made quick work of the PS pump, Hab.
Well, the rain arrived here in town. Snow on Mt. Hood? No, 37 and rain at 6am and temp not expected to lower. A washout ski season it appears.
Oh well, guess I work on the small boat wiring today and watch the 'Hawks play later today.
Old Feb 1, 2015 | 06:55 AM
  #2288
habanero's Avatar
Waiting for the rain to move out too, looks like I'll get a not-too-rainy window to get that flush done in a little bit. We've not had much in the way of snow here, either, seems like it's been a pretty dry winter.
I don't know nothing about no Seahawks. Or about football. That means I should make a pictorial on it! How to repair....proceed at own risk!
Awesome Jason. Just keep in mind all this stuff is things I'm learning as I go...curiosity and a need to tinker gets me every time.
Old Feb 1, 2015 | 07:11 AM
  #2289
rworegon's Avatar
Three of the many reasons this is such a great thread...learning, curiosity, and the need to tinker!
Old Feb 1, 2015 | 01:58 PM
  #2290
habanero's Avatar
Buttoned up, flushed, double checked my bolts and belts and started it up. NOISE. WD-40 on the pump shaft quiets it right down until it wears off, then noise again. Pfui!
Gotta love A1 Cardone. *angerface*
If anyone's got any ideas..... It didn't sound bad when I got it out of the box and turned it by hand. Bolts all tight, belt not too tight, flushed, steering itself working great. Would it really be my luck to get to do this in winter twice? Ideas?
Old Feb 1, 2015 | 02:24 PM
  #2291
millball's Avatar
Take it for a couple grocery runs, maybe the noise'll quit.
Old Feb 1, 2015 | 03:01 PM
  #2292
rworegon's Avatar
No ideas unfortunately other than the unmentionable....ya' got a bum one possibly.
Old Feb 1, 2015 | 03:33 PM
  #2293
habanero's Avatar
Grocery runs... I know you meant junkyard crawls, millball....
I'm thinking bad one too. What's the odds, even if it is Cardone? They're just so straightforward it's hard to imagine what I could have done wrong. Still, not ruling the me factor out.
Old Feb 2, 2015 | 01:48 PM
  #2294
habanero's Avatar
Know what I did wrong- and it was me, dang it!
The pulley. When I took the nut off I expected to have to use a puller to get the pulley off. Nope, popped right off. When I put it back on I simply lined up the splines and put it on, then tightened the nut. What I failed to do was notice that the shaft has a collar which the pulley must butt up to. Today I tightened it A LOT until it was up against the collar. Seems to have made the horrible loud rattly-squealy noise go away.
How embarrassing. The only good thing about it is that now I know what I should've known in the first place. Once spotted it was a ka-duh moment that's left me face palming all day.
Pfft. Learning as I go...
Old Feb 2, 2015 | 02:20 PM
  #2295
rworegon's Avatar
Hey now, Hab! No need for embarrassment...we've all done something similar at one time or another. Glad you spotted the issue and got 'er fixed.
51 here, rain earlier, mostly clear now. The mountain? More rain!
Old Feb 2, 2015 | 04:01 PM
  #2296
habanero's Avatar
Silly wet mountains, sorry to hear still no slidey sticks for you, rw. 3 degree windchill this morning, 20s for the high.
Ordered a new hood support grommet and two new hood stops for the 96 today.
kinda day.
Other than that little snafu the power steering pump is somewhat messy and pretty easy.
I've got a sucker-outer I used to get the fluid out of the reservoir, then capped the return line barb on the reservoir and plugged the return line with vacuum caps. Then I took the pump off. The release for the belt adjuster is 14mm and in front by the pulley, it's connected to the adjuster bolt underneath the pump.
To flush I used a hose barb that fit into the return line (took the vacuum cap plug out) with a bit of extra hose that I fed into a 2 litre bottle set where I could easily eyeball it. Then I put the front end up on jack stands so the wheels could turn freely, key on engine off, and had the kid slowly turn the steering wheel lock to lock back and forth while I kept the reservoir full and kept an eye on the color of the fluid coming out. When I was satisfied I'd gotten the bubbles and nasty fluid out I pulled the vacuum cap off the return line barb and clamped the return line onto it.
That part went smoothly enough. Actually, it all went pretty smoothly. I did not take the pulley off until after I got the pump out of the truck because of room issues concerning the fan and shroud. Some bolts you will have to get to through the pulley holes.
I'll have to look at the camera to see if I got anything useful.
Old Feb 3, 2015 | 01:18 PM
  #2297
habanero's Avatar
96 4Runner
Hood Cushions part# 90541-15004 (need 2)
Unscrew old, screw in new to needed height
Hood Support Grommet part# 90480-15028
Pop out old (mine fell out), take off of hood support. Snap new into front support, then push hood support in until it's at the proper spot. It goes in kinda tight.
Old Feb 3, 2015 | 01:25 PM
  #2298
habanero's Avatar
Maybe I should've studied my own photos....before, the pulley is clearly against the shoulder
and after, it is not.
Some days are on top of things days, some days, not so much. All is good now, and working great, thank goodness! Maybe if it hadn't been so stupid cold (excuses )....
Old Feb 3, 2015 | 02:46 PM
  #2299
rworegon's Avatar
Yep! Definitely a difference in the pulley location in the photos. Glad it's all good now. The only reasonable explanation for this minor dealio is working in the cold....it's a good excuse....stick with it!
Old Feb 3, 2015 | 04:40 PM
  #2300
habanero's Avatar
I know! I can't believe how off I was and how obvious it was and how blatantly I missed it. A bit of numb-headedness. I'm not typically so cavalier when figuring things out, especially something so simple. Maybe I let 'simple' delude me into carelessness? Maybe several hours in 30 degree weather isn't my thing? I've resolved to be a lot more diligent on the next project. Well that, and a lot warmer!
