rustED's 86' V8-Runner Build-up Thread
Old Oct 22, 2014 | 07:07 PM
  #1241
775Toy's Avatar
Your a beast man , no ps ! Geez.
Great job on ps bracket. Now all you need is ac ...
Old Oct 22, 2014 | 08:58 PM
  #1242
85sr5excab's Avatar
Looks good ed. Power steering will make a huge difference.
Old Oct 23, 2014 | 01:39 AM
  #1243
Terrys87's Avatar
Bet you are liking the power steering. I have done the same in the past like the wire nut. If it is your daily driver and you got to get to work, got to do what you have to. I have been there several times.
Old Oct 23, 2014 | 05:37 AM
  #1244
Gizler00's Avatar
Great work ED!! Nothing like making your own brackets with spare metal!!
You will be doing the 1 finger steer in no time.
Old Oct 24, 2014 | 06:56 AM
  #1245
liveoffroad's Avatar
Nice work ed. with your steering all done i expect to see you joining me in moab come spring...
Old Oct 25, 2014 | 09:12 AM
  #1246
rustED's Avatar
Thanks man, I don't know why I put it off for so long, it will be nice when it's finished!...Ha, ha, AC would be nice, but I can get by with the wing windows and the top off. I hope to have a DIY soft top by next summer! AC is a necessity where you live!!!
Thanks buddy, can't wait to have it finished, hopefully today!
Hi Terrry. I agree, it's difficult to work on your rigs when it's your DD. Hopefully I can get a work truck someday, still working on the wife on that one! I plan on completely re-wiring my electric fan when I install my new radiator and 14" fan, hopefully pretty soon!
Old Oct 25, 2014 | 09:25 AM
  #1247
rustED's Avatar
Thanks Mark. Yeah it's nice having some scrap metal laying around, I've almost used all my 1/4" thick plate steel that I had left from my winch mount. It will be nice to steer with one finger, can't wait to have it finished, hopefully I'll get it done today, just need to make a gusset, weld it on, drill 2 more holes, buy the right size belt and some power steering fluid, hook up 2 lines, and bleed the system.
Thanks bud! That would be awesome to be able to go to moab! My rig would still need some work to be able to follow you around ,I still need some lockers...4.7 t-case gears would be nice too!
Old Oct 25, 2014 | 09:49 AM
  #1248
rustED's Avatar
This past Thursday I went to Spokane to the Auto wrecking yard to get some parts for my wife's Durango to fix the driverside front where I hit the deer.
I went online and ordered a front fender with fender flare(used) chrome grill (used) grill mounting bracket (new), headlight/turn signal assembly (used), fog lamp (new), AC condenser (new). They had all the used parts pulled and waiting for pickup the next day. Kinda takes the fun out of it, but was very convenient, especially since the kids were with us. Parts total came to $360 not too bad, the cheapest estimate we got to have it fixed was over $2100!
That was my first trip to the yard in a aleast a 2-3 years, I definitely want to go back, next time for some yota parts!
^^^Before pic
^^^replaced the grill, and had to relief cut the fender so I could hammer out most of the dent before I could get the headlight to fit back in.
^^^ I still need to mount the AC condenser and recharge the system, fix one radiator mount, install the fog lamp, fix the bumper bracket (because the bumper is slightly pushed in and the driverside front tire rubs the bumper a little when turning) Also need to take the replacement fender in and get it painted to match.
Old Oct 25, 2014 | 10:12 AM
  #1249
Terrys87's Avatar
Those deer are going to make a body man out of you yet.lol Really, you did a great job in getting it looking 10 times better then it was and got it driveable again. Great job!!!
Old Oct 25, 2014 | 02:09 PM
  #1250
rustED's Avatar
Cool
Ha, Ha, thanks Terry! It does look a lot better, but I'm no body man, I'll leave that job to the pro's like you! My body tools consisted of a claw hammer, a big crow bar, a grinder with a skinny cut off wheel, a drill and a couple blocks of wood, lol! But like you said, at least it's driveable, and I have the rest of the parts needed to finish it, minus painting the fender.
Old Oct 25, 2014 | 02:20 PM
  #1251
rustED's Avatar
Power steering pump question...help!
I was looking at my steering pump, and there are two threaded fittings, a bigger one and a smaller one, and there is a return line that just has hose clamps on it. I can't figure out what goes to the smaller threaded fitting, I have the return line, coming from the bottom of the reservoir, and the bigger threaded pressure line coming from the steering box, but can't find a smaller threaded line for the other one.
I'm looking in my Haynes manual, and it only shows 2 lines like what I have, so what goes to that third threaded hole on the pump? I feel kinda dumb, but I haven't even looked at any of these parts in over 2 years, lol. Thanks guys for any help!
Old Oct 25, 2014 | 02:45 PM
  #1252
twistedyota's Avatar
My yotatech app keeps crashing everytime I try to add a pic, but on my 87 p/s pump I hhave a return line and feed line on the side, and a small treaded area on top for the vacuum control
Old Oct 25, 2014 | 06:04 PM
  #1253
rustED's Avatar
Thanks twisted. So it just has some vacuum lines that go to it like pictured below in the Haynes manual? I totally don't remember removing anything like that back when I did the engine swap... guess I'll have to try to find another one.
Old Oct 25, 2014 | 06:41 PM
  #1254
Yes, the vacuum lines go to a screw valve that is conected to the upper intake plenum. I believe its a vacuum assist when idleing.
Old Oct 25, 2014 | 06:51 PM
  #1255
rustED's Avatar
Thanks for the info! now I just need to find me one!
Old Oct 25, 2014 | 09:37 PM
  #1256
I've seen people remove the vacuum lines and plug the ports and have others say no matter how far they turn the screw on the intake in or out they see no difference in the pump. So with that you should be able to just be able to put a plug or a small bolt with oring and be fine
Old Oct 25, 2014 | 09:55 PM
  #1257
Terrys87's Avatar
I drove my 3rd gen today as it has a trailer hitch and my 86 does not. I will try and look at it tomorrow to see the routing system. You also have a power steering cooler that sticks thru the core support. I don't see it in the picture. It is just a U shaped metal tube that catches air behind the grill.
When I converted the 86 pickup from a 22r to a 22re, the 22rs do not have vacuum lines running off of the pumps. The 22re does. I was concerned that was going to be an issue about it lugging down when turning the steering wheel. It made no difference. I also found a thread where someone had removed their vacuum lines from their 22re power steering pump and did not have any issues as well.
I did a little test on my truck and just plugged the lines to see how it would effect the running of it. I really am not sure what the purpose of the vacuum lines are for the power steering. I know it is supposed to assist and possibly raise the motors rpms a little when turning. I think you could get away with out using those lines if you did not want to hook them up.
Old Oct 26, 2014 | 04:11 PM
  #1258
rustED's Avatar
Cool, I was hoping there was a way around running the vaccum lines, thanks man!
Thanks for the info Terry, I do still have the power steering cooler, I for the life of me can't figure out what I did with that vacuum controller though! I wish I had the 22R version of the pump instead, lol. Hopefully I can find a course threaded metric bolt here locally so I can plug that off. I thought about just buying the vacuum controller and just plugging off the vaccum ports, but the cheapest one I could find was $48 on eBay!
EDIT** ran across some useful info that's related, figured I'd post a link here; https://www.yotatech.com/forums/f116...ok-out-121440/
And another:
https://www.yotatech.com/forums/f2/b...78/index2.html
Old Oct 26, 2014 | 05:49 PM
  #1259
kornhuskerwizard's Avatar
Power steering!!!
Old Oct 26, 2014 | 09:13 PM
  #1260
ChefYota4x4's Avatar
Thanks Mark! Well if I can't figure something out with the core support, I might just have to go this route:
Holy, ....whaaaaat? Lol...
