Transfer case Help
Old Jun 30, 2013 | 05:23 AM
rookie6319's Avatar
Transfer case Help
I have a 94 dxl 5spd 4x4 I went out behind the house the other day to try the 4x4 out and only have rear wheels spinning so i thought the hubs may be messed up...I still have low gear and high gear but the front wheels will not spin
I pulled it into the garage jacked it up and here is what i found
if i lock the front hubs in and have the transfer case in 4 Low and spin the front tires the axles and front shaft will turn....but if i spin the rear tire only the rear shaft turns...when i unlock the front hubs the front spin free like they should
I have no noise coming from the transfer case and no front end noise
just wondering if any one has had this issue or may be able to tell me where to start so i can get this fixed....also would it be better to rebuild the transfer case if needed or buy another one
Thanks for your advice and any info
Old Jun 30, 2013 | 08:22 AM
aztoyman's Avatar
Does the shifter feel normal? Sounds like it isn't moving the shift rail into 4wd.
There is one rail for 2-4 and one for hi lo. Has it ever been apart?
If case is stock there should be an interlock pin between the shift rails. Sometimes it gets lost and the stock single shifter can come out of the notch on the shift rail and it wont move it. The shifter flops around funny though.
If the shift rails are moving something is wrong internally. The roll pin may have fallen out of the shift fork or something broke.
Drain the oil and see if any metal is present in oil. You'd think you would have some noise if major internal damage.
Old Jun 30, 2013 | 08:23 AM
aztoyman's Avatar
You can also remove the shifter and move the rails with a screw driver to see.
Old Jun 30, 2013 | 09:39 AM
rookie6319's Avatar
yes everything feels normal like you were saying i should have noise if it was something major that is what threw me off when i was looking at everything...I will try pulling the shifter off and let you know what i find if anything Thanks
Old Jun 30, 2013 | 09:43 AM
BigBluePile's Avatar
No need to double post bro......
https://www.yotatech.com/forums/f115...estion-270464/
Old Jun 30, 2013 | 11:29 AM
aztoyman's Avatar
I just re read your post about spinning the front and rear wheels. Did you try to turn the drive shaft with it up on stands?
If you have it in 4wd and up on stands, if you grab and rotate the drive shaft, both the front and rear should turn.
If they don't, the 4wd shift collar may not be moving to engage 4wd. Or something is broke inside.
I'm also assuming 4cy gear drive t-case. If it's a V6 chain type case I'm giving you bad info.
Old Jun 30, 2013 | 06:36 PM
rookie6319's Avatar
big blue pile the only reason i re posted this in this forum is because I posted in the wrong one and didn't know if anyone would reply out of the other forum and I don't know how to delete a post
AZtoyman I did turn the drive shafts while it was up in the air and only one would turn at a time while engaged in 4wd
Old Jun 30, 2013 | 08:19 PM
No worries, you can send a message to a moderator to delete or merge responses into a single thread. I was simply trying to make sure others would see that and post into the OTHER thread.
Old Jul 1, 2013 | 12:37 PM
rookie6319's Avatar
this is what i found when i removed the shifter..the transfer case is in 4 low not 4 high and what is the spring to
Old Jul 1, 2013 | 02:31 PM
rookie6319's Avatar
another thing that i noticed is the fork on the right side looking at the pic will spin up and down I am thinking this could be the problem but i have no clue
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Phantez
Sep 30, 2015 08:24 AM
Toys4parts
Sep 26, 2015 01:56 PM
