rustED's 86' V8-Runner Build-up Thread
Old Feb 23, 2015 | 06:00 AM
  #1421
SqWADoosh's Avatar
Well I'll be darned! That is the most fancy shmancy spaceship radiator I've ever seen! Lol. How you doing brother? Man, I sure wish I could see this thing in person
Chef you keep saying you want to see Ed and BBP in person. I guess you know what that means. Trip to Washington buddy! We'll show you a good time in the roots and the mud guaranteed! I'd love to see your truck in person as Ruby is the inspiration for my little red headed hooker.
Ed when are those meats coming in man?!?!? I dig the old Ford and new rad. I got my aluminum ebay rad put in weekend before last. Need to update my build thread. Hope everything is good with you brother. Coming to Moab? I'll keep asking until you say yes...
Old Feb 23, 2015 | 10:54 AM
  #1422
Gizler00's Avatar
Just been working and staying busy. My 4runner is down, needs a timing chain set replaced, I have the parts, just need to find the time. Now that I have the pickup, I won't feel so overwhelmed to get the 4runner done, I can just take my time, and get my new radiator put in while I'm at it. How have you been?[/QUOTE]
I have been good as well. Busy and now even busier trying to get ready for this World of Wheels show.
I did not know that your runner was down. Sorry to hear that. I understand how hard it is to find the time.
Old Mar 3, 2015 | 02:37 PM
  #1423
rustED's Avatar
Originally Posted by liveoffroad
nice score ed! i love old trucks (though i myself am partial to the early 70's chevy's) that thing will be great to have around
thanks! I like the old Chevys as well, but couldn't pass it up for that price!
Originally Posted by CamTom12
Nice truck! I had a bumpside highboy for a few years that I loved. Never would have sold it but I had to move.
Thanks! I really like the bumpsides, I saw a clean 70 shortbox on CL for $1750 that I would have bought in a second if I would have had enough money. It was gone the first day!
No update on the tires yet....I probably should send them another email
I like your pics from the WOW show, you and your students have done an awesome job on that truck!
Yeah its still hard for me to get motivated it was nice and sunny out today, but was still cold, I can't wait until it warms up a little more! I did get a little bit of work done on the Runner today, I'll have a small update a little later.
Old Mar 3, 2015 | 03:59 PM
  #1424
rustED's Avatar
So I've been doing some head scratching trying to figure out how to mount the Synergy hood pins that I got. They are constructed a little differently the other hoodpins, instead of the hood mounting plate just getting screwed down with sheetmetal screws, these use a poly grommet that actually goes through the hood, which requires a 1" size hole be drilled through the hood for the grommet to fit into, and then the pin goes through the grommet when you shut the hood. Instead of screws, it uses a hex headed bolts and a nylock nuts, so you have to be able to access them from the underside of the hood in order to tighten them down. Well every spot I tried to mount the hood pin to the core support the pin would have gone through some of the structural support on the underside of the hood, which would have required me to cut out some of that structure in order to have access to tighten up the nylock nuts. Here's a couple pics of the hood pins. If you look at the backside of the poly grommet in the second pic you can see how the grommet needs a large 1" hole for it to fit through.
^not to thrilled about using a hole saw on my hood!
This is what I came up with to avoid having to cut out a large structural area under the hood to gain access to the nylock bolts. I just used a piece of scrap angle and cut it at a angle and drilled some holes at each end, and bolted it to the inner fender and core support. I used already existing factory threaded bolt holes to mount the peices of angle. Then I figured out where I wanted the pin to come through the hood where it wouldn't effect any of the hoods under structure.
^^^ once I get it all how I want it I'll go back an paint the angle pieces so it matches better, either red or black. On the passenger side the battery was in the way of mounting the peice of angle, luckily I remember that the optima was sitting on a one inch spacer, so I removed it and lowered the battery down. I will have to go back and modify the battery hold down bracket that I made to work with the lowered battery.
Old Mar 3, 2015 | 04:19 PM
  #1425
SqWADoosh's Avatar
What is the reason for the hood pins?
Old Mar 3, 2015 | 04:40 PM
  #1426
rustED's Avatar
I need to make room for my thicker aluminum radiator, shroud and electric fan, so I'm cutting out enough core support to make it all fit. I will be losing the hood latch, so I had to go with hood pins.
Old Mar 4, 2015 | 03:59 AM
  #1427
SqWADoosh's Avatar
Ahhhh gotcha.
Old Mar 8, 2015 | 11:42 AM
  #1428
twistedyota's Avatar
Why don't. U just replace the hex bolts with self tappers?
Old Mar 20, 2015 | 09:25 AM
  #1429
liveoffroad's Avatar
lookin good ed. you get it all put together yet?
Old Mar 20, 2015 | 10:38 AM
  #1430
bump530's Avatar
Im curious to see the hood pins finished. I had just planned to cut out the support under the hood some.
Old Mar 27, 2015 | 10:16 AM
  #1431
rustED's Avatar
I may do that, it would be easier.
Hey buddy. no I haven't worked on it lately, been sick, working OT, and just haven't gotten ambitious enough to get back on it. Hopefully next weekend!
Yeah Im curious to see them finished too, lol. I wish I had one of those dimple die hole flaring tools and a press, I would like to make a plate for the corners instead of just the piece of angle iron, I have an idea in my head of how I want it to look, just not the tools to pull it off.
Old Mar 31, 2015 | 07:26 PM
  #1432
rustED's Avatar
Hood pins installed
Finally an update with pics!
^^^no turning back now!
^^^got the other angle iron bracket installed. I made these out of some scrap I had laying around, the bigger holes were already there, I may go back and make a new one for this side someday, im just runningreally low on metal scrap, so I couldn't get to picky, I will also eventually paint these red. I had to remove the windshield washer fluid reservoir to install the bracket. I may try to relocate it to the driverside.
^^^here's what the underside of the hood looks like. I would have like the hood pins to be located lower and towards the front of the hood more, but by going this route I avoided having to cut into any of the hood supports.
I'm pretty happy with the end results. I highly recommend the Poly Performance hood pins. If anyone else uses these, be sure not to over tighten the nylock nuts, just snug them down. Over tightening might cause the poly bushing to suck the hood down creating a dent. These are high quality, no metal on metal contact, and are worth the extra money IMHO. Thanks goes out to bump530, if it wasn't for him mentioning these in his build thread, I would have probably gone with a lesser quality set.
Old Apr 1, 2015 | 04:42 AM
  #1433
bump530's Avatar
The install looks good. I still haven't ordered any more mine just yet.
Old Apr 3, 2015 | 04:26 PM
  #1434
Redeth005's Avatar
Clean install ED. Good Work! I take it you have good space for the battery right?
Old Apr 4, 2015 | 10:40 AM
  #1435
SqWADoosh's Avatar
I just realized looking at those pictures...where the hell is your battery hiding?
Old Apr 4, 2015 | 11:56 PM
  #1436
rustED's Avatar
thanks! You better hurry up and order you some, sounds like you're going to need them pretty quick!
Thanks Richard. I still have space for the battery in the stock location, my Optima had a 1" spacer attached to the bottom, I just had to remove the spacer, to make room for it. Also I need to modify my battery hold down bracket to work with the battery sitting 1" lower.
Ha, ha. I pulled it out when I took those pics, just haven't reinstalled it yet.
Old Apr 7, 2015 | 06:26 PM
  #1437
rustED's Avatar
Got the radiator mocked into place today. I had to trim some of the grill on the inside to make the grille fit in the stock location. I'm going to have to cut out a little of the hood support so the hood won't hit the radiator cap and close all the way. In the 4th pic, I had a rusty old piece of 1" square tube, it will fit perfect beneath the original core cross support, I just need to find a longer peice, then I can bolt it in.
Old Apr 7, 2015 | 06:50 PM
  #1438
bump530's Avatar
Looks good man. You had to push it out a pretty good ways. Is it going to interfere with winch mounting? Btw, I ordered my hood pins finally lol
Old Apr 7, 2015 | 07:18 PM
  #1439
rustED's Avatar
Thanks. Yeah it's going to interfere with remounting the bumper/winch. I had to cut the top 2 tabs off the stock crossmember that the winch mount bolts to. I guess I'll have to cross that bridge when I come to it, might have to do a full on custom bumper build...I'm open to any suggestions!
EDIT: Glad to hear you got your hood pins ordered!
Old Apr 7, 2015 | 07:35 PM
  #1440
SqWADoosh's Avatar
Looks great ED.
