rustED's 86' V8-Runner Build-up Thread
Old Oct 29, 2014 | 03:29 PM
  #1261
rustED's Avatar
What up Chef!
Old Oct 29, 2014 | 03:52 PM
  #1262
rustED's Avatar
More steering pump questions...
Today I went to try to find a bolt to plug off the port in the steering pump where the vaccum/air valve is supposed to go. I had a real hard time finding the correct size metric bolt to fit the threaded port but finally found one. But they only had the bolt in one length. So heres what I got going on. I bought a small O-ring, the bolt, and a nut. I plan to snug the bolt (red one in the pic) down against the O-ring then tighten the nut down against the steering pump housing. Here's a pic of what I'm talking about:
What do you guys think, do you think it will leak, do you think I should try putting some RTV on the threads of the bolt?
Old Oct 29, 2014 | 04:52 PM
  #1263
kornhuskerwizard's Avatar
I dunno,lotta pressure.just have to try it and see.
Old Oct 30, 2014 | 06:00 AM
  #1264
85sr5excab's Avatar
Are u sure that hole doesn't have tapered pipe threads? If so u should be able to find a plug at a decent parts store. Otherwise I would cut the bolt to the correct length a do away with the nut altogether. If u do cut the bolt take a grinder with a cut off wheel and grind a little chamfer on the end of the threads to clean up the end of it so it will start properly. Good luck ed, ur getting closer.
Old Oct 30, 2014 | 09:15 PM
  #1265
twistedyota's Avatar
Another way is to put the nut on the bolt then cut the threads and then take the nut off, and it will clean the threads up also.
Old Oct 31, 2014 | 08:32 AM
  #1266
Redeth005's Avatar
^ do what he said. That worked for me.
Old Oct 31, 2014 | 01:27 PM
  #1267
Weld it!!
Old Nov 1, 2014 | 04:29 PM
  #1268
rustED's Avatar
Painted my power steering brackets today. The factory Toyota ones are I painted silver. I ran out of paint, so the bracket I built to adapt the Toyota brackets to the 302 I painted black.
^^^the tab sticking up is for my coil bracket to bolt to, since I had to relocate it.
Old Nov 1, 2014 | 07:31 PM
  #1269
Looks good
Old Nov 2, 2014 | 04:39 PM
  #1270
Nice!!
Old Nov 2, 2014 | 06:48 PM
  #1271
Gizler00's Avatar
Looking good ED!!
Old Nov 3, 2014 | 07:07 PM
  #1272
Yota's Avatar
mighty fine work sir.
Old Nov 3, 2014 | 11:33 PM
  #1273
rustED's Avatar
Originally Posted by twistedyota
Looks good
Nice!!
Originally Posted by Gizler00
Looking good ED!!
Thanks fellas, hopefully I'll have the power steering all finished wednesday!
Old Nov 4, 2014 | 12:02 AM
  #1274
Terrys87's Avatar
I have been tied up lately, was going to do a write up on my 85 installing the power steering on it and still haven't made it to it yet. My pictures of the other hoses didn't turn out to well. I can get those if you need them. The bottom hose off of the pump goes to the square metal tubing on the gear box.
The top hose off of the pump goes to the bottom of the tank.
Old Nov 6, 2014 | 02:55 PM
  #1275
nvwiggins's Avatar
Hey Ed just wondering if you're running a stock Toy fuel pump or a higher volume pump?
Old Nov 6, 2014 | 03:13 PM
  #1276
rustED's Avatar
I pulled the stock Toyota electric fuel pump out of the gas tank, and swapped in the fuel pickup tube/screen out of my 85' Toyota parts truck, and I'm just running a mechanical fuel pump that was on the 302 when I got it, I'm assuming it's just a stock mechanical pump.
Old Nov 6, 2014 | 04:26 PM
  #1277
rustED's Avatar
Thanks for the pics Terry, those came in handy! It's been a couple years since I took the PSP off, couldn't remember where everything went, lol.
Old Nov 6, 2014 | 05:08 PM
  #1278
rustED's Avatar
POWER STEERING IS DONE!!!
Here's some pics. I was to lazy, I just used that bolt and nut like in the previous pic to plug off that air/vaccum port, so far no leaks. Test drove it, it feels so awesome being able to steer with ease!!!
^^^I might go back and add a triangle shaped gusset bracket just to make the idiler/tensioner pulley a little more rigid, there is a bolt hole on the end that I can run a bolt through, might be overkill.
Old Nov 6, 2014 | 05:13 PM
  #1279
I'll drink to that Ed!!!good for you!!!
Old Nov 6, 2014 | 05:16 PM
  #1280
rustED's Avatar
Thanks Chris!
