rustED's 86' V8-Runner Build-up Thread
Old Aug 23, 2014 | 08:45 PM
  #1061
rustED's Avatar
Originally Posted by Gizler00
Awesome progress ED!! The dash can be tricky at first, but once you know where all the hidden bolts and nuts are, it goes pretty fast.
Thanks Mark. I really was not looking forward to pulling the dash pad, but like you said once you know where to find all nuts and bolts, its pretty easy. I wish I had the $30, I'd buy that dash pad off CL, its the same color as mine and in perfect shape, mines all cracked, lol.
Old Aug 25, 2014 | 12:08 PM
  #1062
rustED's Avatar
I got some of te wiring finished, just waiting to get some NPT fitttings to adapt my oil and water sending units, and wire them up. The Volts gauge is working, and the oil and water temp gauges illuminate, still need to hook up the wire to the light circuit so that the gauges dim down by 50% when the headlights are turned on. Here's afew pics.
Kind of hard to tell, but I painted the stereo trim bezel, it was grey, painted it black, it matches the rest of the interior trim better now
^^^The gauges have 7 different colors to choose from, kinda crappy pic, but gives you an idea
Old Aug 25, 2014 | 02:56 PM
  #1063
liveoffroad's Avatar
wow, turned out very nice! looks like a factory inclinometer at first glance!
Old Aug 25, 2014 | 04:32 PM
  #1064
Gizler00's Avatar
Looks great ED! I love the idea I having actual gauges to monitor the engine rather than trust the factory guessing gauges. Haha
Old Aug 25, 2014 | 06:08 PM
  #1065
rattlewagon's Avatar
Love the gauges!
Old Aug 26, 2014 | 11:35 AM
  #1066
rustED's Avatar
Thanks man! I had thought about trying to find an old inclinometer housing to mount the gauges in, but this pod only cost $10...I wasn't expecting to have to modify it this much though, lol
Old Aug 26, 2014 | 11:49 AM
  #1067
rustED's Avatar
Thanks Mark! I agree, it will be nice to be able to accurately keep tabs on what going on. I can't wait to get the rest of the gauges hooked up and working, hopefully tomorrow. I think I might eventually get a matching Tach, I was going to get an SR5 gauge cluster, but I think a matching Glow Shift tach would be pretty sweet.
Old Aug 26, 2014 | 11:55 AM
  #1068
rustED's Avatar
Love the gauges!
Thanks, I appreciate it!
Old Aug 26, 2014 | 03:50 PM
  #1069
Gizler00's Avatar
I think the matching tach would be awesome!!!!
Old Aug 26, 2014 | 04:46 PM
  #1070
chukarhunt's Avatar
Looks great rusted!! I am still trying to figure out a pod location for mine. Seems to sit ok at the corner of the dash for now.
Old Aug 26, 2014 | 11:14 PM
  #1071
Terrys87's Avatar
Looks great and I would feel much more comfortable with actual gauges as well. The factory gauges makes you wonder at times.
Old Aug 27, 2014 | 09:01 AM
  #1072
rustED's Avatar
Yeah, I think so too! GlowShift makes a 2-1/8 diameter and a 3-3/4" diameter one, I think id probably go with the bigger one. It cost $99, so it will be down the road before I getit, I need to get my new radiator in first, lol.
Thanks chuckarhunt!
Thanks Terry! I agree, I'll feel much more comfortable driving once I get these gauges functioning!
Old Aug 27, 2014 | 11:56 AM
  #1073
rustED's Avatar
Well I lucked out on the oil pressure gauge, I removed the old oil pressure gauge line from the engine block, the old gauge had the actual oil line that ran to the gauge, anyway the reducer fitting was the same thread size as what I needed to install the new oil sending unit, so I was able to install it and get the oil pressure gauge working. I was getting 75lbs of pressure idling, I think that will do!
^^^ I had to bend the fuel hard line out of the way, it ran right where the oil sending unit needed to go. Man I need to clean up my engine bad, back when I had the remote oil filter setup, one of the fitting to the hose that ran to the filter/adapter plate had a small leak, my electric fans blew the oil everywhere, glad I was able to eliminate that remote filter setup, now I just need to clean up the engine compartment!!!
Now I just need to go get the right fitting to install the water temp probe, and I need to run one wire to hook into my headlight switch to so the gauges dim at night.
Old Aug 27, 2014 | 05:38 PM
  #1074
rustED's Avatar
Gauges are finished, and everything is working as it should. The fitting I needed to adapt the 1/8 NPT threads on the probe over to 3/8 NPT threads on the intake manifold cost me $2.50. Then I hooked up the dimmer wire into the fuse block and tied into the tail lights, so now the gauges dim when the headlights are turned on.
It kind of sucked, I came home from getting the threaded adapter, and I went to move my 4 runner into the shade because it was getting hot out, and I forgot that I had removed the old probe from the intake...ended up blowing antifreeze all over the engine compartment, had to get a bunch of rags to soak up all the puddles that filled up around the intake! Now I got to deal with burnt antifreeeze smell until it all burns off, lol.
Old Aug 27, 2014 | 05:57 PM
  #1075
kornhuskerwizard's Avatar
Nice gauges,by the way 75lbs oil pressure at idle is great!
Old Aug 27, 2014 | 06:21 PM
  #1076
rustED's Avatar
Thanks Chris! im pretty happy with how they turned out. Now I need to get some LED's for the speedo, gas gauge and heater controls and color match everything!
Old Aug 28, 2014 | 02:28 PM
  #1077
Go to superbriteleds.com,I picked mine up for like $16.hardest part is getting thespeedo cable unplugged and reinstalled correctly,iI also want them on my inclinometer.
Old Aug 30, 2014 | 01:38 AM
  #1078
Terrys87's Avatar
Don't feel bad ED, I did was setting the timing and had a ratchet and socket on the crankshaft and got everything done and went to start the truck and I heard a thunk. I knew instantly what I had done. Left that ratchet and socket on the crankshaft and did not hear it floor. I looked for 30 minutes trying to find it. Finally found it in the fan shroud between the it and the radiator, both pieces was there, what are the odds of that happening? Great to see you got the gauges working.
Chris...Unsnapping the speedometer cable at the fire wall and down by the exhaust cover just near the steering column makes getting the cluster out so much easier by giving you a lot of slack to push the cluster out of its location.
Old Sep 1, 2014 | 12:43 PM
  #1079
rustED's Avatar
Sweet, thanks Chris for the site, that is pretty cheap to upgrade the dash lights, I want their replacement LED dome light too... one of these days I need to swap in the rear view mirror from my old 85' parts truck, it would be a nice feature having the additional dome light in the mirror, I seen Terry do that on one of his builds, I don't understand why Toyota didn't have them like that on the 4 runners from the factory!
Ha, ha, well at least it didn't do any damage to your radiator!!!
Thats a good tip on the speedometer Terry, I haven't pull one out yet, I'll have to keep that trick in mind!
Old Sep 1, 2014 | 02:01 PM
  #1080
I have done this!!!
That's a great idea!!!
